  • 5
Message 1 of 10
Issues with Hub 3
I’m posting this on behalf of an elderly friend who has been having issues with her wifi after a power cut recently. No devices are able to connect to the internet (a laptop, iPhones, Samsung phone etc). I have tried restarting the router by holding the button down for a minute or so, after giving this 10-15 minutes to work there is no difference. I have also tried turning the router on and off, this has made no difference. Obvious things like the socket are fine, all wires are connected properly etc. I tried ringing Virgin Media and all that happened was the automated person ran tests and said all was fine and the router should be restarted, which I couldn’t say that I’ve tried doing. The box isn’t new and has been set up for a while. The main light is showing as yellow flashing and the other two green lights are showing occasionally. Any advice on how to fix this? Thanks in advance!
  • 24.45K
  • 1.4K
  • 3.11K
Message 2 of 10
Re: Issues with Hub 3
Do a 60 second pinhole reset on the hub
  • 5
Message 3 of 10
Hi, I’ve tried this and given it about 10-15 minutes for it to work but nothing has changed, apart from it makes the yellow light flash with no other lights showing
  • 24.45K
  • 1.4K
  • 3.11K
Message 4 of 10
Which one of these is it:
https://www.virginmedia.com/help/virgin-media-no-wifi-connection-hub3
  • 5
Message 5 of 10
The yellow bottom light mainly is solid with occasional flashing. The two green internet arrows also occasionally come on for 10s or so before disappearing for another 10 minutes
  • 24.45K
  • 1.4K
  • 3.11K
Message 6 of 10
We’d need to see some stats/logs from the hub
  • 5
Message 7 of 10
Okay, how would I go about this?
When the automated person ran remote tests it said that the box was working and it just needed to be reset
  • 24.45K
  • 1.4K
  • 3.11K
Message 8 of 10
You need to login to the hubs admin pages to get them.
  • 5
Message 9 of 10
Surely I can’t do that without being connected to the wifi though?
  • 24.45K
  • 1.4K
  • 3.11K
Message 10 of 10
Plug directly into the router with an Ethernet device
