on 17-11-2022 20:36
Hello everyone! Hoping to get some help here. Having issues with Playbase randomly dropping out / not being found / being found but unable to set up. I think Pkaybase is faulty as no issues with any other devices and done every Sonos fix I can find. However, they want me to check this with Virgin:
1) Check if 2.4GHz WiFi is on.
2) If possible, give 5GHz WiFi a different name than the 2.4 variant. For example, add "-5G" to the name.
3) Check if the WiFi mode is set to "BGN". Other options are often BG and GN.
4) The "AP Isolation" (or "Client Isolation") setting must be off. (This setting is rarely available)
5) Adjust the WiFi channel from automatic to channel 1, 6 or 11.
6) The security mode must be set to WPA2 with AES Encryption.
7) Turn on UPNP if it is off.
😎 Make sure the 2.4GHz WiFi bandwidth is 20MHz, 20 / 40MHz or 40MHz is not supported
9) Set DNS server to primary 8.8.8.8 and secondary to 8.8.4.4
10) Enable multicast
Know the answers to some of these but I assume 1) I have to login to the settings site to check or change things (192...etc) and 2) changes could mess up other devices? Not a novelist but the jargon is over my head so welcome help from anyone with similar issues or better yet a fix! Thank you.
Answered! Go to Answer
on 18-11-2022 15:16
on 18-11-2022 15:16
on 18-11-2022 20:46
Thanks John. I do have a mesh but Sonos insist on the above steps before giving me any more help. The Playbase has the same issues using the mesh. Tried Hub in modem mode, both on WiFi same name, both on WiFi different name, nesh with cable etc etc and tried with mesh off just Hub. Playbase just keeps failing.
on 19-11-2022 10:58
