Issues for months. So solution from Virgin.
Jb1874
I've had Internet issues for several months. The Internet drops for seconds or a minute or so dozens if not hundreds of times a day. Games freeze. Videos freeze. Woget disconnected from work, etc
Things I've done:
-Used www.thinkbroadband.com to monitor (showing drops most of the day)
-removed netgear router (virgin insisted it was this), took out of modem mode.
-Reset router to default.
-tested wifi and wired. Both same. Align with thinkbroadband and router logs.
-tested ping from router to virgin dns ip (or any other ip) and I get 60% packet loss.
Things virgin have done:
-Reset router
-reset router
-reset router
-send engineer (found no issues)
-reset router (remotely without telling me)
-request I reset router again (I refused)
My questions are. Are there any other things I can to. How can I get virgin to help and stop telling me the will fix it when I phone and do nothing.
Currently looking for other providers. Such a drag to switch so hoping virgin can fix.
3 REPLIES 3
Lets see the connection data
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
Thanks. I may have found a solution  already. Please see my reddit post
https://www.reddit.com/r/VirginMedia/comments/15ozehy/virgin_issues_with_no_fix/?utm_source=share&ut...
I couldn't face speaking to virgin again. I brought the product of amazon which seem to help. I did set up the quality broadband monitor. It showed hundreds of outages per day. I'll update this thread if all well soon.  Thanks for your reply!
Legend
Which faulty item of network kit was replaced from Amazon ?
