on 19-10-2021 15:38
I am having issues with my wifi in my new house.
I have several devices throughout my house all connected to wifi. Each has worked fine at some point and does often.
But, what I am finding is randomly the odd device will lose connection and when trying to connect back again its saying password if wrong or there is no internet connect despite the other devices working.
I have a TV, Apple TV, iPad a few phones and laptop.
The most notable issue is every time I open my laptop it wont connect and I have to turn the wifi on and off again on my laptop before it will connect. Not sure its connected but then it might disconnect a TV which is why im asking if there is a limit on how many devices can be set on a network?
Alex
on 19-10-2021 15:55
on 19-10-2021 17:20
There is not a simple answer to your prime question. Basically VM hubs are notorious in having problems with WiFi as they are a cheap consumer product built down to a price. They should be able to run the number of devices you listed, but a lot depends on the distance from the hub and the amount of data they are sending. As WiFi devices keep a constant “keep alive” with the hub and as the hub can only process one device at a time you get retries and then some dropped packets and the device loses contact. A lot of people, myself included, have invested in their own network equipment and run the VM hub in modem mode, a task they do very well. I’ve had over 40 WiFi devices on my network without any problems. If you are only getting problems with WiFi devices that’s the area to look, VM do supply pods for WiFi free if you are on the top package or £5 per month if not. The total cost of the pods really means you should invest in your own network equipment.
If you are having problems on Ethernet connected devices we can help you to check out your circuit.
