on 25-04-2024 22:45
on 25-04-2024 23:13
AFAIK VM UK do not use CGNAT but VM IE do.
on 25-04-2024 23:31
Your Hub is assigned a public IP Address, i.e. traffic can be routed to it over the internet; this is not possible with CGNAT where private IP Addresses are used.
on 19-09-2024 01:45
I know it's a bit late. But I thought I reply with an straight forward answer to this.
No. Virgin Media does not use CGNAT for fiber optic. I know this as I had no issues port forwarding my plex streaming and pc for Web hosting.
If you are having issues, consult a pc network advisor or YouTube videos.
19-09-2024 06:55 - edited 19-09-2024 06:56
Carrier-Grade NAT (CGNAT), also known as large-scale NAT (LSN), is a type of network address translation used by Internet Service Providers (ISPs) to manage the shortage of IPv4 addresses. Here’s a simple breakdown:
Purpose: CGNAT allows multiple customers to share a single public IP address. This is crucial because the pool of available IPv4 addresses is limited and nearly exhausted12.
How It Works: In a typical home network, your router assigns private IP addresses to your devices and translates them to a single public IP address when accessing the internet. CGNAT does something similar but at the ISP level. It translates private IP addresses from multiple customers to a shared public IP address13.
Benefits:
Drawbacks:
Transition to IPv6: CGNAT is considered a temporary solution until IPv6, which has a much larger add...2.
