Ipad Air connection issue
My iPad keeps randomly disconnecting from the Wi-Fi. I have tried resetting the iPad and the router but it still keeps happening. It is an issue between the router and iPad, it works fine when connected to mobile hotspots and other Wi-Fi netwoks.
  • 24.39K
  • 1.4K
  • 3.1K
Re: Ipad Air connection issue
have you spoken to Apple as well?
  • 7.7K
  • 613
  • 1.31K
Have you separated the 2.4 & 5Ghz SIDS with different names? Some devices try to switch between the bands and lose the signal. The iPad should work fine on just the 5Ghz band. My iPad Air 2, iPad Pro 10.5 and iPad Pro 12.9 all work well on the 5Ghz band.
Is there a way of making it only connect to a certain frequency?
  • 11.46K
  • 889
  • 1.46K
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 7.7K
  • 613
  • 1.31K
It’s easy to get an iPad to just use say the 5Ghz band. Just set the SSID names different, say xxx-2 and xxx-5. Then you connect the iPad to just the xxx-5 SSID.
