  • 38
Message 1 of 7
Internet up and down, massive packet loss and latency.
It's been terrible for weeks now, to the point where I have had to use a VPN just to avoid being booted from games.  But now the connection is so bad, even the VPN can't help.
This is my virgin media monitor.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/198284e87ed8aca3ee42f90f2fde6ff311db1ac0
  • 11.36K
  • 888
  • 1.45K
Message 2 of 7
Re: Internet up and down, massive packet loss and latency.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 38
Message 3 of 7
Check service says no known issues.
My BQM
https://www.thinkbroadband.com/broadband/monitoring/quality/share/198284e87ed8aca3ee42f90f2fde6ff311...
1258750000040256 qam16
2138750000-1.938256 qam1
3146750000-1.438256 qam2
4154750000-1.238256 qam3
5162750000-1.538256 qam4
6170750000-1.738256 qam5
7178750000-1.938256 qam6
8186750000-1.738256 qam7
9194750000-1.738256 qam8
10202750000-1.540256 qam9
11210750000-1.240256 qam10
12218750000-1.240256 qam11
13226750000-1.240256 qam12
14234750000-140256 qam13
15242750000-0.740256 qam14
16250750000-0.440256 qam15
172667500000.240256 qam17
182747500000.540256 qam18
192827500000.540256 qam19
202907500000.740256 qam20
21298750000140256 qam21
223067500001.240256 qam22
233147500001.240256 qam23
243227500001.440256 qam24
1Locked40.31527990563976
2Locked38.996189621962734
3Locked38.969257132248945
4Locked38.935413371746832
5Locked38.62771899662084
6Locked38.9134804121471510
7Locked38.913210347800215
8Locked38.980320851272076
9Locked38.97341705875960
10Locked40.31528400501529
11Locked40.3845821214158
12Locked40.31153685985910
13Locked40.31334112909687
14Locked40.91623128521331
15Locked40.91468779612107
16Locked40.31617840770302
17Locked40.3476756223124
18Locked40.3249825111544
19Locked40.914103280128
20Locked40.33334058651
21Locked40.33645747307
22Locked40.37043763719
23Locked40.9340474176257
24Locked40.3541906321166
15370000049.3512064 qam2
26030016547.8512064 qam1
34620000049.5512064 qam3
43940000049.3512064 qam4
  • 38
Message 4 of 7
2ATDMA00290
3ATDMA00270
4ATDMA0010
  • 38
Message 5 of 7
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID1006138
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID1006137
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
  • 38
Message 6 of 7
05/11/2020 17:53:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:43:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:42:48Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:42:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:42:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:42:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:42:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:27:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:27:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:27:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:27:23criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:40criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 17:25:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 1.66K
  • 85
  • 129
Message 7 of 7
Hi msrsimpkin,
Thank you for your post.
I apologise for the delay in response here. Upon looking into your account and your BQM I can't see anything that stands out that would be causing a problem. Can I ask how everything is at the moment and if you're still experiencing these issues?
Cheers.
Ryan_N - Forum Team - https://community.virginmedia.com/t5/custom/page/page-id/WelcomeGoodFolk
