on 29-04-2021 20:55
Hello everyone
having problems with hub 3 and deco m5
internet has dropped a lot
down stairs sitting next to hub fluctuating from 350mbps drops to 230bmps
adults bedroom normally gets about 130 to 150mbps
but now getting 40 to 50mbps
kids room 30mbps usually 70 to 90mbps
ive rest hub 3 a few times still nothing
then deleted the whole lot and reinstalled but still the same
why has it dropped so much when kids go online for gaming lags really bad
Is there any other fixes I can do as was fine about a week ago
Many thanks
Answered! Go to Answer
on 15-05-2021 14:36
You could maybe look at a mesh with a dedicated backhaul. That does in all honesty sound like normal behaviour for some mesh systems
on 15-05-2021 15:54
Hello Gary
how do I go about that as ain’t got a clue with other routers
this has drove me insane.have to maintain this setup a lot keep optimising it slot of the deco as comes up congested
Just want internet that actually works properly
thanks tony
on 15-05-2021 16:27
15-05-2021 16:33 - edited 15-05-2021 16:51
Hello John
sorry I forgot to mention I’ve got 3 computers plugged straight into the deco and still get low internet
I’ve deleted the deco setup and rest hub gonna reconnect all again as in message 5
this will be the 5th time now I’ve done it works for abit then goes all slow speed again after 4 days or so
will update in abit
if not think new router but not sure on what one just want the kids to be able to play gaming without a issue
cheers
tony
on 15-05-2021 16:53
Update
done the normal with connecting the deco m5 to hub3 in modem mode
now can’t connect to internet hub 3 is red and deco is green but nothing now
Can’t work it out why it’s not letting me connect now when before it did
on 15-05-2021 17:15
on 15-05-2021 22:21
I’ve reset the whole lot hub 3 and reset all decos
ive got 2 computers plugged into one deco Other one has got computer a sky q mini box on
main deco is connected to hub
When you put deco in AP mode and hub in modem mode,done exactly what you said in message 5,turned off hub connected deco and Ethernet cable then turned hub 3 on
get a green light on deco normal light when connected,but can’t connect keeps saying no internet even on the app says no deco connected
had to reset again and only way I could get connection is lhub 3 modem mode.then main deco in router mode seems to work that way just gotta see for how long
on 15-05-2021 23:04
“When you put deco in AP mode and hub in modem mode”, this will not work. Deco must be in router mode if VM hub is in modem mode.
Setup for your own router / mesh:
VM hub in router mode -> router / mesh in AP mode,
VM hub in modem mode -> router / mesh in router mode.
on 16-05-2021 16:41
Thank you Tudor
ive got hub in modem mode and deco in router mode
is that the best way to have it
or shall I do it the other way round
Cheers
Tony
16-05-2021 16:51 - edited 16-05-2021 16:53
You have got the best way.
When in modem mode the CPU in the hub, which is very under powered, does not have the overhead of processing the WiFi and Network Switch components of the hub.
