Hammer82
  • 22
Message 1 of 16
Internet running slow hub 3 with deco m5
Hello everyone
having problems with hub 3 and deco m5
internet has dropped a lot
down stairs sitting next to hub fluctuating from 350mbps drops to 230bmps
adults bedroom normally gets about 130 to 150mbps
but now getting 40 to 50mbps
kids room 30mbps usually 70 to 90mbps
ive rest hub 3 a few times still nothing
then deleted the whole lot and reinstalled but still the same
why has it dropped so much when kids go online for gaming lags really bad
Is there any other fixes I can do as was fine about a week ago
Many thanks
  • 22.45K
  • 2.4K
  • 4K
Message 2 of 16
Re: Internet running slow hub 3 with deco m5
Are you in modem mode on the Hub?
Hammer82
  • 22
Message 3 of 16
Yeah hub is in modem mode
Hammer82
  • 22
Message 4 of 16
Also should I keep 2.4ghz and 5ghz on or just have one of them on ?
  • 22.45K
  • 2.4K
  • 4K
Message 5 of 16
Try setting it up again this way.
__________________________
On the first Deco unit, change/ensure its network setting is at DHCP & Nat mode. Then switch it off and disconnect the wan cable to the Hub. Switch off all the other M5 units. Then check that the VM Hub is put into modem mode ( https://www.virginmedia.com/help/virgin-media-hub-modem-mode ) and wait for the base light to turn magenta/purple (on a Hub3 - but not on a Hub4!). Once it’s in modem mode, the VM hub MUST then be powered off.
Now switch on the first M5 and then put in the WAN cable to the VM hub. Only now power up the VM hub and leave a few minutes you should get a connection. Then use se the recommended App to connect other M5 units to the first one. This order only needs to be done the first time you connect the router to the VM hub.
gary_dexter
  • 30.49K
  • 1.89K
  • 4.05K
Message 6 of 16
If you’re not in modem mode it could just be limitations of the mesh system.
Have you turned QOS off?
Hammer82
  • 22
Message 7 of 16
I’ve check hub is in modem mod just to double check it
how do you turn QOS off with deco system
  • 22.45K
  • 2.4K
  • 4K
Message 8 of 16
Check the Deco manual/instructions ?
Hammer82
  • 22
Message 9 of 16
Just tried few different settings in the qos as can’t turn it off fully
still coming back low mbps
gary_dexter
  • 30.49K
  • 1.89K
  • 4.05K
Message 10 of 16
What speed do you get wired into the main deco that’s connected to the hub?
