on 05-12-2021 18:52
Hi i have 350mbps and i am only get 8mbps wired an actually getting more though wifi at 30 mbps i have done the usual switch it off rest start but its still the same any ideas how to fix this issue
on 05-12-2021 19:18
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
if its an earlier hub button is top right
on 05-12-2021 19:29
on 05-12-2021 19:29
on 05-12-2021 20:09
Can you please copy and paste your answer not photos, they are nearly unreadable and do not contain all the information required.
How to get stats from a VM hub
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
on 05-12-2021 20:13
1 | 419000000 | 1 | 40 | 256 qam | 36 |
2 | 267000000 | 1.5 | 40 | 256 qam | 17 |
3 | 275000000 | 1.7 | 40 | 256 qam | 18 |
4 | 283000000 | 2.2 | 43 | 256 qam | 19 |
5 | 291000000 | 2.2 | 40 | 256 qam | 20 |
6 | 299000000 | 2.2 | 40 | 256 qam | 21 |
7 | 307000000 | 2.5 | 40 | 256 qam | 22 |
8 | 315000000 | 2.7 | 40 | 256 qam | 23 |
9 | 323000000 | 1.9 | 40 | 256 qam | 24 |
on 05-12-2021 20:14
1 | 39399981 | 49.5 | 5120 | 64 qam | 4 |
2 | 46199944 | 49.5 | 5120 | 64 qam | 3 |
3 | 53700002 | 49.5 | 5120 | 64 qam | 2 |
4 | 60299998 | 49.5 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
on 05-12-2021 20:15
44 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/12/2021 16:47:39 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/12/2021 16:47:38 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/12/2021 12:11:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/12/2021 10:47:21 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=40 |
on 05-12-2021 20:42
the downstream has 24 channels and there is a second page - the upstream also has a second set of figures - post all those and it will help
as an initial comment the upstream figures you have posted are on the high side but within limes - the downstream figures are ok
on 05-12-2021 20:49
I was being to think its the hub thats faulty since am not gett decents speeds
