stevemagee60
  • 9
Message 1 of 22
Internet keeps dropping both wifi and wired
Internet keeps dropping on both wifi and wired we probably notice it a couple of times a day but could be more.  This is the logs from the router but no idea what it means?
03/01/2022 00:21:0noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 21:44:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 21:44:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2022 16:46:38noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2021 16:30:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 14:13:41noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 09:44:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 09:44:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2021 11:17:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2021 21:44:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2021 21:44:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2021 15:53:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2021 00:28:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2021 00:28:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 17:11:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 15:44:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2021 20:23:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2021 06:01:33noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2021 06:01:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/12/2021 17:32:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
Andrew-G
  • 10.42K
  • 1.66K
  • 4.76K
Message 2 of 22
Re: Internet keeps dropping both wifi and wired
There's nothing in the log that really stands out (a few errors are normal, what counts is the type and frequency), but if you post the Downstream and Upstream tables that you'll find alongside the Network log then we can take a look for potential noise or power faults.
stevemagee60
  • 9
Message 3 of 22
Hi Andrew, thanks so much for the reply. My wife wanted me to try something fix it this morning so I reset it to factory settings so I think that wiped the logs.as there was definitely at least T3 errors there so not sure if this will be helpful. Before I had done that the wired had been out for almost 24hrs and that did seem to fix it temporarily . I've been out today but she says so far her wired connection cut out again but wifi was then ok. I just tried to wired and seems to be working again now.
Thanks again
Steve
Router status
1330750000-2.536256 qam25
2202750000-1.937256 qam9
3210750000-1.737256 qam10
4218750000-1.537256 qam11
5226750000-138256 qam12
6234750000-1.538256 qam13
7242750000-1.438256 qam14
8250750000-238256 qam15
9258750000-237256 qam16
10266750000-2.236256 qam17
11274750000-2.236256 qam18
12282750000-1.937256 qam19
13290750000-1.537256 qam20
14298750000-1.537256 qam21
15306750000-1.538256 qam22
16314750000-237256 qam23
17322750000-237256 qam24
18338750000-2.436256 qam26
19346750000-2.737256 qam27
20354750000-2.238256 qam28
21362750000-2.738256 qam29
22370750000-2.537256 qam30
23378750000-336256 qam31
24386750000-336256 qam32
1Locked36.690
2Locked37.6340
3Locked37.31241
4Locked37.660
5Locked38.6140
6Locked38.6220
7Locked38.620
8Locked38.620
9Locked37.690
10Locked36.650
11Locked36.6100
12Locked37.370
13Locked37.630
14Locked37.690
15Locked38.6190
16Locked37.6180
17Locked37.3210
18Locked36.6100
19Locked37.320
20Locked38.940
21Locked38.620
22Locked37.370
23Locked36.690
24Locked36.320
13260000746.8512064 qam5
23940000248.3512064 qam4
34619999648.3512064 qam3
45369998148.3512064 qam2
3ATDMA0000
4ATDMA0000
Tags (1)
  • 33.79K
  • 3.31K
  • 6.42K
Message 4 of 22
Nothing really leaping out there so...
If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
Kath_F
  • 33.87K
  • 1.3K
  • 2.74K
Message 5 of 22
Hi stevemagee60,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear you are having an issue with your broadband connection.
Taking a look at you hub, all is looking good. The power levels, signal levels and uptime is all looking good. The area segment is looking good too so there is no developing area fault affecting you.
Looking at the devices connected to the Hub, the following links will help you to optimise your network
In terms of the wired devices dropping too, please set up the BQM and post the live URL here so we can look in to this further for you. Keep us posted on how things go.
Kath_F
stevemagee60
  • 9
Message 6 of 22
Sorry I have been sick for a couple of days I will do this soon. Thank you 🙂
stevemagee60
  • 9
Message 7 of 22
Hi John, thank you for this and apologies for replying at the time I have been sick for a few days. I haven't done that yet so I will do it now.
Thanks again
Steve
Ayisha_B
  • 3.79K
  • 147
  • 347
Message 8 of 22
Hi @stevemagee60,
Hope you are feeling better?
We look forward to receiving you BQM and we can take it from there 🙂
Ayisha_B
stevemagee60
  • 9
Message 9 of 22
Hi all, I think I have followed the instruction right and this is the link to my live graph. https://www.thinkbroadband.com/broadband/monitoring/quality/share/6891460ed17a808f32cd469508b0770910...
On Saturday it completely stopped I think I restarted the router but it didn't come back immediately. I also bought a boaster which says it's working however hasn't seemed to make any difference. I also bought one of the ones plugs in directly that goes through the powerlines just to try but even pluging driectly into the the back rarely works.
This evening I disconnected every device in the house apart from my wifes laptop that she was working on and on the google internet speed test she was getting 0.99 Mbps download and 0.5 Mbps upload for a good while now with more devices reconnected it's 9.65 Mbps download 3.12 Mbps upload.
I'm on Virgin Media M100 Fibre Broadband if that makes  any difference.
Many thanks for all your help and advise!
Steve
Tags (1)
gary_dexter
  • 32.63K
  • 2.02K
  • 4.47K
Message 10 of 22
Your BQM is fine.
We’re these Speedtest done on a wired device?
Don’t use the Google speed test either - it’s highly inaccurate.
