on 21-06-2021 19:51
Our internet connection seems to cut out every 15-20 minutes for around 20 seconds before restoring. I use the Hub 3.0 as a modem, with a separate router, so the Wi-Fi stays connected.
Any advice or support would be greatly appreciated as I can't get through a meeting without this cutting out in a very embarrassing way.
I have seen similar issues where people have requested the details of the upstream, downstream and network logs so I've included them here:
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 53700005 | 49 | 5120 | 64 qam | 6 |
2 | 39400034 | 48.5 | 5120 | 64 qam | 8 |
3 | 60300273 | 51 | 5120 | 64 qam | 5 |
4 | 46200009 | 48 | 5120 | 64 qam | 7 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 243000000 | 1.5 | 40 | 256 qam | 14 |
2 | 139000000 | 7 | 40 | 256 qam | 1 |
3 | 147000000 | 6.5 | 40 | 256 qam | 2 |
4 | 155000000 | 5.3 | 40 | 256 qam | 3 |
5 | 163000000 | 4.8 | 40 | 256 qam | 4 |
6 | 171000000 | 5.1 | 40 | 256 qam | 5 |
7 | 179000000 | 5.5 | 40 | 256 qam | 6 |
8 | 187000000 | 4.1 | 40 | 256 qam | 7 |
9 | 195000000 | 3.9 | 40 | 256 qam | 8 |
10 | 203000000 | 3.7 | 40 | 256 qam | 9 |
11 | 211000000 | 2.9 | 40 | 256 qam | 10 |
12 | 219000000 | 3 | 32 | 256 qam | 11 |
13 | 227000000 | 2.7 | 32 | 256 qam | 12 |
14 | 235000000 | 2.7 | 40 | 256 qam | 13 |
15 | 251000000 | 1.9 | 40 | 256 qam | 15 |
16 | 259000000 | 1.5 | 40 | 256 qam | 16 |
17 | 267000000 | 2 | 40 | 256 qam | 17 |
18 | 275000000 | 1.2 | 40 | 256 qam | 18 |
19 | 283000000 | 0.9 | 40 | 256 qam | 19 |
20 | 291000000 | 1.9 | 40 | 256 qam | 20 |
21 | 299000000 | 2.4 | 40 | 256 qam | 21 |
22 | 307000000 | 2.2 | 40 | 256 qam | 22 |
23 | 315000000 | 1.7 | 40 | 256 qam | 23 |
24 | 323000000 | 1.5 | 40 | 256 qam | 24 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 40.3 | 692 | 346 |
2 | Locked | 40.9 | 29 | 3414 |
3 | Locked | 40.3 | 37 | 3429 |
4 | Locked | 40.3 | 168 | 3356 |
5 | Locked | 40.3 | 243 | 2577 |
6 | Locked | 40.9 | 51 | 3434 |
7 | Locked | 40.9 | 59 | 3381 |
8 | Locked | 40.9 | 47 | 3498 |
9 | Locked | 40.9 | 460 | 2986 |
10 | Locked | 40.3 | 437 | 1700 |
11 | Locked | 40.9 | 1518 | 1314 |
12 | Locked | 32.5 | 2541756 | 4658 |
13 | Locked | 32.6 | 120933 | 4582 |
14 | Locked | 40.9 | 1996 | 1726 |
15 | Locked | 40.9 | 2785 | 1808 |
16 | Locked | 40.3 | 1275 | 8653 |
17 | Locked | 40.3 | 1637 | 547 |
18 | Locked | 40.9 | 1405 | 1530 |
19 | Locked | 40.9 | 1420 | 360 |
20 | Locked | 40.3 | 1564 | 415 |
21 | Locked | 40.3 | 51 | 4015 |
22 | Locked | 40.9 | 96 | 4331 |
23 | Locked | 40.3 | 75 | 3970 |
24 | Locked | 40.9 | 289 | 4095 |
Time | Priority | Description |
21/06/2021 19:38:30 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2021 15:05:53 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2021 15:05:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2021 15:05:50 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2021 02:10:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 11:51:38 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 11:51:35 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:36:29 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:31:10 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:21:59 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:20:58 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:20:22 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:20:18 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:20:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:20:4 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:19:57 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 08:19:40 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 16-08-2021 14:36
Hello @jdbann,
Yes, we need to send someone out to investigate this further.
I am sorry for the issues recently.
We are limited to what we can see from here, the engineer can test the things we can not see.
Please let us know how it goes.
on 16-08-2021 17:38
Thank you Hayley, I understand.
There was an outage in the area over the weekend and our appointment was postponed. It was fixed within a couple of hours but we've not heard anything about arranging the appointment again. Could you check on that please?
on 18-08-2021 17:46
Hi @jdbann
Thanks for posting on our community forum.
How is the connection today? Is the issue still ongoing?
on 18-08-2021 18:01
@jdbann just a thought but do you have any neighbours in the flats who are with VM, that you could ask if they are also experiencing issues?
It has occurred to me that if there is a intermittent bad connection somewhere upstream of your flat then it’s quite possible that you can have any number of engineer visits and they won’t necessarily see any problems. You only need a cracked cable or iffy joint somewhere which moves slightly every time someone walks past and it will give you exactly the problems you are seeing.
on 19-08-2021 17:53
Hey Travis,
It's probably too soon to say for sure but it looks a lot more reliable. Could I ask what has changed? Have any repairs been made? Would be good to understand so we can be clear if anything comes up again in future.
on 22-08-2021 09:29
Hi @jdbann,
Thank you for coming back to us about your connection issue.
How is your connection at the moment?
The issues you could have been experiencing could have been experienced by some people in your area. Once an outage is recognised, our technicians will come out to the area and resolve the area wide issue.
Your problems could have stemmed from the area issue, so once that was resolved, so were your connection issues.
Please let us know if you're having any issues with your connection. We're more than happy to help.
Thanks! 🙂
on 27-08-2021 09:19
Thank you Paulina, and everyone else who supported on the thread. It was an incredibly frustrating few months but it really does look like the issue has been resolved and we have decent functioning internet again. I really appreciate everyones' assistance 🥳
