  • 7
DW94
Internet connection and speed inconsistent
I've noticed recently that the quality and speed of my internet connection is inconsistent.
I'm currently connected to the 2GHz network, sitting beside the router and am getting about 26Mbps (contracted to 100)
The connection quality upstairs is poor (not a large property) with my Xbox and TV constantly dropping from the WiFi. The signal strength upstairs of the 5GHz network is poor (my iPhone won't even discover it upstairs) whilst the speed of the 2GHz network is again, poor.
5GHz network is fine downstairs.
Can someone please review my Downstream and Upstream as well as the network log. Maintenance was carried out in the area recently and since this, my Internet has been worse.
Kind Regards,
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
323000000
-1
38
256 qam
24
2
139000000
0.7
40
256 qam
1
3
147000000
0.5
40
256 qam
2
4
155000000
0.5
38
256 qam
3
5
163000000
0.2
38
256 qam
4
6
171000000
0
40
256 qam
5
7
179000000
-0.2
40
256 qam
6
8
187000000
-0.5
38
256 qam
7
9
195000000
-0.5
40
256 qam
8
10
203000000
-1
40
256 qam
9
11
211000000
-1.2
38
256 qam
10
12
219000000
-1.5
40
256 qam
11
13
227000000
-1.7
38
256 qam
12
14
235000000
-2
38
256 qam
13
15
243000000
-2.5
38
256 qam
14
16
251000000
-2.9
38
256 qam
15
17
259000000
-2.4
38
256 qam
16
18
267000000
-2
38
256 qam
17
19
275000000
-1.9
40
256 qam
18
20
283000000
-1.7
38
256 qam
19
21
291000000
-1.7
38
256 qam
20
22
299000000
-1.2
38
256 qam
21
23
307000000
-1
38
256 qam
22
24
315000000
-1
40
256 qam
23
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
109
0
2
Locked
40.3
224
9
3
Locked
40.3
239
0
4
Locked
38.9
172
0
5
Locked
38.6
131
0
6
Locked
40.3
133
0
7
Locked
40.3
475
0
8
Locked
38.9
127
0
9
Locked
40.3
60
0
10
Locked
40.3
149
0
11
Locked
38.9
122
0
12
Locked
40.9
88
0
13
Locked
38.9
228
0
14
Locked
38.9
335
13
15
Locked
38.6
219
0
16
Locked
38.9
572
0
17
Locked
38.9
334
0
18
Locked
38.9
94
0
19
Locked
40.3
130
0
20
Locked
38.9
150
1
21
Locked
38.9
116
13
22
Locked
38.9
242
0
23
Locked
38.9
134
0
24
Locked
40.9
112
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
31000046
4.325
5120
16 qam
5
2
37599971
4.375
5120
16 qam
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
  • 7
DW94
Re: Internet connection and speed inconsistent
  • 6.14K
  • 470
  • 1.02K
Hero
Phone customer services and report the problem. You only have 2 upstream channels at 16 QAM when you should have 4 at 64 QAM
  • 11.8K
  • 1.08K
  • 2.56K
griffin
The stats look fine, apart from a single dropout on the 11th.
There are still areas where VM have not upgraded to 4 upstreams yet and having two upstream channels will not affect your connection. My 200Mbps runs fine with 2 upstreams.
Ideally the upstream should be using 64QAM modulation but as your upstream channels are at the lower end of the spectrum so it is not that unusual to see them running at 16QAM. This should not affect your connection seeing the logs are showing no evidence that your upstream is in any distress.
The stats reflect the state of the connection between your Hub and VM's servers and does not reflect how your wireless connections are performing which can be affected by many external factors.
Before phoning in, I would test the speed with a PC connected directly to the Hub by CAT 5E or better Ethernet cable.
This would test if the fault is on VM's side (no evidence of that yet) or the wireless side which would be down to yourself as wireless is affected by many factors outside VM's (or any ISP's) control.
If you get close to headline speeds on the wired connection, then the problem would be on the wireless side. If so, it would be absolutely pointless phoning in as VM CS would only be able to give generic advise at best, and I doubt  many of the Offshore Support staff will be able to do that.
