on 03-11-2022 21:00
Hi all,
I recently changed from a Hub 3 on 350Mb to a hub 5 on 1Gb. On the hub 3 I forwarded 5 ports and I think everyone know DMZ / port forwarding does not work on the hub 5.
I purchased a TP-Link AC2300 and connected it to the hub 5 in modem mode, when first connecting I got a message saying to stop any conflict the router would be set to 192.168.1.1. For some reason (I don't know much about these things) but I now have four devices on 192.168.0.xx and the rest on 192.168.1.xx I set the forwarding rules for one of my devices address range 192.168.1.xx and that now works but the other device is in the range 192.168.0.xx and errors when I try to add the rule, I get ' The IP address and LAN IP address should be in the same subnet'. What do I need to do to get all devices on 192,168.0.xx as some of my devices are hard coded for this range?
on 03-11-2022 21:48
Ignore the message and set your own routers address to 192.168.0.1 make sure the Hub5 is in modem mode and the LED is green.
on 03-11-2022 22:52
Thanks for your reply, yes, the hub is in modem mode (green light) how do I set the router to be set to 192.168.0.1?
on 03-11-2022 23:31
I have no knowledge of that particular router, but usually you go to 192.168.0.1 and get a web page to change its settings.
