on 13-08-2021 18:30
Been struggling with this for 5 months now. Had an engineer come out and install a new cable as we thought it was damaged. Our broadband is intermittent and the internet will cut out 2/3 times a day. Power and colour will be the same but the wifi wont work until a reset. Annoying as its happening daily and VM tech team cant seem to figure out the problem and think its working fine. Any help is appreciated, thankyou.
1 | 46200000 | 47 | 5120 | 64 qam | 1 |
2 | 32600000 | 46.8 | 5120 | 64 qam | 3 |
3 | 39400000 | 47 | 5120 | 64 qam | 2 |
4 | 25800000 | 46.5 | 5120 | 64 qam | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
1 | 203000000 | 4.1 | 40 | 256 qam | 9 |
2 | 139000000 | 3.2 | 38 | 256 qam | 1 |
3 | 147000000 | 3.5 | 40 | 256 qam | 2 |
4 | 155000000 | 3.7 | 40 | 256 qam | 3 |
5 | 163000000 | 3.7 | 40 | 256 qam | 4 |
6 | 171000000 | 3.7 | 40 | 256 qam | 5 |
7 | 179000000 | 4 | 40 | 256 qam | 6 |
8 | 187000000 | 4.4 | 40 | 256 qam | 7 |
9 | 195000000 | 4.3 | 40 | 256 qam | 8 |
10 | 211000000 | 4 | 40 | 256 qam | 10 |
11 | 219000000 | 4.1 | 40 | 256 qam | 11 |
12 | 227000000 | 4.1 | 40 | 256 qam | 12 |
13 | 235000000 | 3.7 | 40 | 256 qam | 13 |
14 | 243000000 | 3.9 | 40 | 256 qam | 14 |
15 | 251000000 | 4.1 | 40 | 256 qam | 15 |
16 | 259000000 | 4.1 | 40 | 256 qam | 16 |
17 | 267000000 | 4.3 | 40 | 256 qam | 17 |
18 | 275000000 | 4.1 | 40 | 256 qam | 18 |
19 | 283000000 | 4.9 | 40 | 256 qam | 19 |
20 | 291000000 | 5.3 | 40 | 256 qam | 20 |
21 | 299000000 | 5.9 | 40 | 256 qam | 21 |
22 | 307000000 | 6.1 | 40 | 256 qam | 22 |
23 | 315000000 | 6.1 | 40 | 256 qam | 23 |
24 | 323000000 | 6.5 | 40 | 256 qam | 24 |
on 13-08-2021 18:30
1 | Locked | 40.9 | 16 | 0 |
2 | Locked | 38.6 | 5 | 0 |
3 | Locked | 40.3 | 6 | 0 |
4 | Locked | 40.3 | 6 | 0 |
5 | Locked | 40.3 | 4 | 0 |
6 | Locked | 40.3 | 0 | 0 |
7 | Locked | 40.3 | 18 | 0 |
8 | Locked | 40.3 | 18 | 0 |
9 | Locked | 40.9 | 17 | 0 |
10 | Locked | 40.3 | 6 | 0 |
11 | Locked | 40.9 | 5 | 0 |
12 | Locked | 40.3 | 5 | 0 |
13 | Locked | 40.3 | 0 | 0 |
14 | Locked | 40.3 | 6 | 0 |
15 | Locked | 40.9 | 12 | 0 |
16 | Locked | 40.9 | 5 | 0 |
17 | Locked | 40.3 | 5 | 0 |
18 | Locked | 40.3 | 0 | 0 |
19 | Locked | 40.3 | 4 | 0 |
20 | Locked | 40.9 | 6 | 0 |
21 | Locked | 40.9 | 4 | 0 |
22 | Locked | 40.9 | 19 | 0 |
23 | Locked | 40.9 | 18 | 0 |
24 | Locked | 40.3 | 6 | 0 |
13/08/2021 17:13:55 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/08/2021 17:00:51 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/08/2021 05:08:29 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/08/2021 03:50:14 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/08/2021 03:50:14 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/08/2021 03:50:13 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/08/2021 16:42:49 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/08/2021 13:50:6 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/08/2021 19:14:44 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2021 02:26:41 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/08/2021 02:22:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/08/2021 23:56:29 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/08/2021 12:12:23 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/08/2021 10:01:22 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/08/2021 10:00:44 | critical | TFTP Request Retries exceeded, CM unable to register |
06/08/2021 10:00:44 | critical | TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/08/2021 09:56:38 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 13-08-2021 18:35
on 13-08-2021 19:14
on 15-08-2021 18:26
So our connection cut off again at about 18:12pm tonight and its back up now after a reset. I tested an ethernet cable when it went down and the laptop said there was no internet at all and the colour was still orange on the router.
Here's the link to my broadband quality monitor:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7393d0989f107778d2a88852391991203ed7cce4
Is there anything else I can post to help us figure it out?
on 16-08-2021 20:53
Hey, just replying to this so you get a notification. Internet has dropped again tonight at 20:45pm!
on 19-08-2021 08:37
Hey @nparojcic,
Welcome to the forums and many thanks for your recent posts. I'm really sorry to hear that you're having continuous connection issues.
Thanks for providing the BQM, as well as confirming that the issue is still present via ethernet connection.
I'd like to have a further look into things from our end for you. However, I've been unable to locate your account with you forums details. I'll send you a private message just to get these from you so please keep an eye on the purple envelope at the top of the page.
Kind regards,
