on 08-02-2022 09:19
I've been having intermittent signal issues for the past couple of days. Is this a known problem in my area and if not can it be escalated
1 267000000 -1.2 40 256 qam 17
2 275000000 -1.4 40 256 qam 18
3 283000000 -1.2 40 256 qam 19
4 291000000 -1.2 40 256 qam 20
5 299000000 -0.5 40 256 qam 21
6 307000000 -0.7 40 256 qam 22
7 315000000 -1 40 256 qam 23
8 323000000 -1.2 40 256 qam 24
9 331000000 -1.4 40 256 qam 25
10 339000000 -1.5 40 256 qam 26
11 347000000 -1.7 40 256 qam 27
12 355000000 -2.2 40 256 qam 28
13 363000000 -2.5 40 256 qam 29
14 371000000 -2.9 40 256 qam 30
15 379000000 -2.9 40 256 qam 31
16 387000000 -2.7 40 256 qam 32
17 395000000 -2.2 40 256 qam 34
18 403000000 -2.2 40 256 qam 35
19 411000000 -2.2 40 256 qam 36
20 419000000 -2.7 40 256 qam 37
21 427000000 -2.7 40 256 qam 38
22 435000000 -2.7 40 256 qam 39
23 443000000 -2.5 40 256 qam 40
24 451000000 -2.7 40 256 qam 41
1 Locked 40.9 1809125 1671614
2 Locked 40.3 1814762 1472182
3 Locked 40.3 1707993 1196032
4 Locked 40.9 1784909 1324437
5 Locked 40.3 1915554 1733686
6 Locked 40.3 1852151 1900633
7 Locked 40.9 1752200 1727777
8 Locked 40.3 1797274 1544211
9 Locked 40.3 1727330 1225378
10 Locked 40.9 1675085 1145013
11 Locked 40.9 1668820 1384598
12 Locked 40.9 1701977 1714515
13 Locked 40.3 1731539 1756920
14 Locked 40.3 1740044 1684074
15 Locked 40.9 1757052 1438130
16 Locked 40.3 1736819 1191184
17 Locked 40.3 1711187 1190574
18 Locked 40.9 1690977 1443063
19 Locked 40.3 1739903 1574471
20 Locked 40.3 1778830 1614231
21 Locked 40.3 1763584 1490525
22 Locked 40.3 1766489 1316490
23 Locked 40.3 1763685 1120087
24 Locked 40.3 1756369 1097100
Refresh data
1 60300000 50.5 5120 64 qam 1
2 46200034 49.5 5120 64 qam 3
3 39400117 49 5120 64 qam 4
4 53699912 50.3 5120 64 qam 2
1 ATDMA 0 0 15 0
2 ATDMA 0 0 9 0
3 ATDMA 0 0 6 0
4 ATDMA 0 0 17 0
08/02/2022 09:15:22 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:15:19 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:13:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:13:59 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:04:29 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:04:0 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:03:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:03:41 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:03:29 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:03:29 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:02:57 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:02:57 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:02:35 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:02:11 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:02:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:01:45 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:01:32 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 09:01:18 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 08:59:50 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 08:59:50 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 08-02-2022 09:29
intermittent signals means what - poor wifi or poor internet generally
you look to have a noise issue on the downstream - can you reboot the hub and post the levels again in a few hours
your upstream is on the high side - in limits but only just plus a fair number of T3 errors
if the pre and post rs errors rise after a reboot i would think you need a tech to look at things
ring or wait for VM to get to the thread
on 10-02-2022 13:45
Hi there @asad78611,
welcome to our forums and thanks for your post.
As per the advice given by @-tony- have you now been able to reboot the hub? If so are you able to post the levels again so we can review this further?
Nathan
on 10-02-2022 21:07
I did a reboot last night. Haven't noticed any issues so far.
1 | 267000000 | -0.2 | 40 | 256 qam | 17 |
2 | 139000000 | 3.7 | 40 | 256 qam | 1 |
3 | 147000000 | 3.5 | 40 | 256 qam | 2 |
4 | 155000000 | 3.2 | 40 | 256 qam | 3 |
5 | 163000000 | 2.5 | 40 | 256 qam | 4 |
6 | 171000000 | 2.2 | 40 | 256 qam | 5 |
7 | 179000000 | 1.7 | 40 | 256 qam | 6 |
8 | 187000000 | 2 | 40 | 256 qam | 7 |
9 | 195000000 | 1.5 | 40 | 256 qam | 8 |
10 | 203000000 | 1.2 | 40 | 256 qam | 9 |
11 | 211000000 | 0.9 | 40 | 256 qam | 10 |
12 | 219000000 | 0.5 | 40 | 256 qam | 11 |
13 | 227000000 | 0.4 | 40 | 256 qam | 12 |
14 | 235000000 | 0.2 | 40 | 256 qam | 13 |
15 | 243000000 | 0.2 | 40 | 256 qam | 14 |
16 | 251000000 | 0 | 40 | 256 qam | 15 |
17 | 259000000 | 0 | 40 | 256 qam | 16 |
18 | 275000000 | -0.2 | 40 | 256 qam | 18 |
19 | 283000000 | -0.2 | 40 | 256 qam | 19 |
20 | 291000000 | -0.2 | 40 | 256 qam | 20 |
21 | 299000000 | 0.4 | 40 | 256 qam | 21 |
22 | 307000000 | 0.4 | 40 | 256 qam | 22 |
23 | 315000000 | 0.2 | 40 | 256 qam | 23 |
24 | 323000000 | 0 | 40 | 256 qam | 24 |
1 | Locked | 40.9 | 70 | 13 |
2 | Locked | 40.3 | 1673939 | 80539 |
3 | Locked | 40.3 | 1323 | 0 |
4 | Locked | 40.3 | 998 | 0 |
5 | Locked | 40.3 | 1314 | 0 |
6 | Locked | 40.3 | 1758 | 0 |
7 | Locked | 40.9 | 1122 | 0 |
8 | Locked | 40.3 | 321 | 0 |
9 | Locked | 40.9 | 97 | 0 |
10 | Locked | 40.3 | 98 | 0 |
11 | Locked | 40.9 | 155 | 0 |
12 | Locked | 40.3 | 110 | 10 |
13 | Locked | 40.3 | 101 | 0 |
14 | Locked | 40.3 | 75 | 0 |
15 | Locked | 40.9 | 80 | 0 |
16 | Locked | 40.3 | 97 | 0 |
17 | Locked | 40.3 | 104 | 14 |
18 | Locked | 40.3 | 56 | 12 |
19 | Locked | 40.9 | 49 | 0 |
20 | Locked | 40.3 | 60 | 0 |
21 | Locked | 40.3 | 50 | 12 |
22 | Locked | 40.3 | 48 | 16 |
23 | Locked | 40.9 | 42 | 16 |
24 | Locked | 40.3 | 62 | 13 |
1 | 46200213 | 49 | 5120 | 64 qam | 3 |
2 | 39400229 | 48.5 | 5120 | 64 qam | 4 |
3 | 32600185 | 47.8 | 5120 | 64 qam | 5 |
4 | 25800054 | 46.8 | 5120 | 64 qam | 11 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
10/02/2022 04:42:47 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 19:32:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 19:32:28 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 11-02-2022 10:11
Hi asad78611,
Thank you for carrying out a reboot and for posting all the stats after, everything looks OK, I have also located your services on our system with the details we have for you and everything also looks good there, no signs of any issues, if you do have any further issues, please do not hesitate to reach back out, you can if needed also run further diagnostics via your Online Account.
Paul.
