on 28-05-2022 11:42
I've had intermittent problems with wired/wireless connection to the router for a couple of weeks now. Occasionally the connection drops out for half an hour or so (on 23/05/2022 it was for over 3 hours).
I know there are rules about quality of service and when you can get refunds but working on what should be a reliable wired system providing 500Mb/s should be straightforward and consistent. I sometimes have to work from home and that is via wired too, so it should also be reliable.
I currently pay over £100 a month for what should be a decent quality of service, but at the moment I am just not getting that. I have rebooted the hub several times but nothing seems to work for a continued period of time. Intermittent broadband failures, occasional TV outages.
And the VirginMedia help is absolutely USELESS. There is NO way to get an engineer to come and look at the setup if the system is currently working. And (because I live in a mobile blackspot) there's no easy way of requesting one when it's not, as I DON'T HAVE ACCESS! And phoning is also a waste of time, as they never actually seem to be able to help.
Seriously considering moving on from VirginMedia despite the broadband/O2 boost etc via Volt, as 500Mb/s is only good if it actually works.
on 28-05-2022 11:45
Typo in the message - should have read 22/05, not 23/05
on 28-05-2022 16:52
on 03-06-2022 16:21
Downstream:
1 | 658250000 | -2.5 | 38 | 256 qam | 36 |
2 | 458250000 | -0.7 | 40 | 256 qam | 13 |
3 | 466250000 | -0.7 | 40 | 256 qam | 14 |
4 | 474250000 | -0.7 | 40 | 256 qam | 15 |
5 | 482250000 | -0.9 | 40 | 256 qam | 16 |
6 | 490250000 | -1 | 38 | 256 qam | 17 |
7 | 498250000 | -1.2 | 40 | 256 qam | 18 |
8 | 506250000 | -1.2 | 40 | 256 qam | 19 |
9 | 514250000 | -1.5 | 40 | 256 qam | 20 |
10 | 522250000 | -2 | 40 | 256 qam | 21 |
11 | 530250000 | -2 | 40 | 256 qam | 22 |
12 | 538250000 | -3 | 38 | 256 qam | 23 |
13 | 546250000 | -2.7 | 38 | 256 qam | 24 |
14 | 554250000 | -3 | 38 | 256 qam | 25 |
15 | 562250000 | -3 | 38 | 256 qam | 26 |
16 | 570250000 | -3.5 | 40 | 256 qam | 27 |
17 | 578250000 | -3.5 | 38 | 256 qam | 28 |
18 | 586250000 | -3.2 | 38 | 256 qam | 29 |
19 | 594250000 | -3.2 | 40 | 256 qam | 30 |
20 | 602250000 | -3.5 | 38 | 256 qam | 31 |
21 | 610250000 | -4 | 38 | 256 qam | 32 |
22 | 618250000 | -3.2 | 38 | 256 qam | 33 |
23 | 626250000 | -4 | 38 | 256 qam | 34 |
24 | 634250000 | -2.9 | 38 | 256 qam | 35 |
1 | Locked | 38.9 | 429 | 411 |
2 | Locked | 40.3 | 721 | 7027 |
3 | Locked | 40.3 | 106 | 496 |
4 | Locked | 40.3 | 218 | 586 |
5 | Locked | 40.9 | 260 | 573 |
6 | Locked | 38.9 | 99 | 686 |
7 | Locked | 40.9 | 74 | 4416 |
8 | Locked | 40.3 | 84 | 997 |
9 | Locked | 40.3 | 86 | 4371 |
10 | Locked | 40.3 | 86 | 4425 |
11 | Locked | 40.3 | 99 | 4474 |
12 | Locked | 38.9 | 186 | 4542 |
13 | Locked | 38.9 | 165 | 4468 |
14 | Locked | 38.9 | 2040 | 4911 |
15 | Locked | 38.9 | 2211 | 5110 |
16 | Locked | 40.3 | 2234 | 5213 |
17 | Locked | 38.6 | 2070 | 5171 |
18 | Locked | 38.9 | 1904 | 5150 |
19 | Locked | 40.3 | 1866 | 5108 |
20 | Locked | 38.9 | 1959 | 5029 |
21 | Locked | 38.9 | 2172 | 5149 |
22 | Locked | 38.9 | 1926 | 4859 |
23 | Locked | 38.9 | 2331 | 4664 |
24 | Locked | 38.6 | 4756 | 4846 |
Upstream:
1 | 60300000 | 46.8 | 5120 | 64 qam | 1 |
2 | 53700000 | 46.3 | 5120 | 64 qam | 2 |
3 | 39400000 | 46 | 5120 | 64 qam | 4 |
4 | 46200000 | 45.8 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 108 | 0 |
2 | ATDMA | 0 | 0 | 184 | 0 |
3 | ATDMA | 0 | 0 | 335 | 0 |
4 | ATDMA | 0 | 0 | 189 | 0 |
on 03-06-2022 16:24
Time | Priority | Description |
03/06/2022 15:11:54 | notice | LAN login Success;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 11:03:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 11:02:55 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 11:02:55 | critical | Ranging Request Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:56:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:56:6 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:56:6 | critical | Ranging Request Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:50:54 | critical | No Ranging Response received - T3 time-out;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:50:40 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:50:40 | critical | Ranging Request Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:49:23 | critical | No Ranging Response received - T3 time-out;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:49:18 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:49:18 | critical | Ranging Request Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:49:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:48:59 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:48:59 | critical | Ranging Request Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:43:52 | critical | No Ranging Response received - T3 time-out;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:43:28 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 10:43:28 | critical | Ranging Request Retries exhausted;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
03/06/2022 07:49:51 | critical | No Ranging Response received - T3 time-out;CM-MAC=YY:YY:YY:YY:YY:YY;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
on 03-06-2022 16:29
on 03-06-2022 22:50
on 03-06-2022 22:54
These figures cover the last 2-3 days since I last rebooted/reset the hub. I've fought long and hard about getting an engineer out to look at this but it's like trying to get blood out of a stone.
Actually raised a complaint today as this has gone on for FAR too long.
Thanks for your help so far...
on 03-06-2022 23:26
on 04-06-2022 00:20
Yes, connected via ethernet cable to hub.
