on 11-09-2021 16:01
I experience several drops in connection almost every day. This usually manifests in a total loss in connectivity and the reestablishment of connection on the VM superhub 3 with lights going from white to blinking and solid green then back to solid red. The setup is: VS superhub 3 in modem mode with mesh network doing all the routing and wifi. Outages disrupted meetings during the day and netflix etc in the eve but I setup a broadband quality monitor on our IP that shows it occurs more frequently than just when I notice. Typical day (yesterday) pictured below but can be much more frequent and also we have days of no problem. Called CS who told me that as I had a 3rd party device (ie mesh system) installed and the hub in modem mode they cannot help me in any way. Will post device info in following posts.
on 11-09-2021 16:05
1 | 235000000 | -5.2 | 34 | 256 qam | 13 |
2 | 139000000 | 1.7 | 35 | 256 qam | 1 |
3 | 147000000 | 1 | 35 | 256 qam | 2 |
4 | 155000000 | 0.7 | 35 | 256 qam | 3 |
5 | 163000000 | 0.7 | 35 | 256 qam | 4 |
6 | 171000000 | 0.7 | 35 | 256 qam | 5 |
7 | 179000000 | 0 | 35 | 256 qam | 6 |
8 | 187000000 | -0.2 | 35 | 256 qam | 7 |
9 | 195000000 | -0.7 | 35 | 256 qam | 8 |
10 | 203000000 | -1.4 | 35 | 256 qam | 9 |
11 | 211000000 | -2.2 | 35 | 256 qam | 10 |
12 | 219000000 | -3 | 35 | 256 qam | 11 |
13 | 227000000 | -4 | 35 | 256 qam | 12 |
14 | 243000000 | -4.9 | 34 | 256 qam | 14 |
15 | 251000000 | -4.4 | 35 | 256 qam | 15 |
16 | 259000000 | -3.9 | 35 | 256 qam | 16 |
17 | 267000000 | -3.7 | 35 | 256 qam | 17 |
18 | 275000000 | -3.7 | 35 | 256 qam | 18 |
19 | 283000000 | -3.2 | 35 | 256 qam | 19 |
20 | 291000000 | -2.9 | 36 | 256 qam | 20 |
21 | 299000000 | -2 | 36 | 256 qam | 21 |
22 | 307000000 | -1.2 | 36 | 256 qam | 22 |
23 | 315000000 | -1 | 37 | 256 qam | 23 |
24 | 323000000 | -0.2 | 37 | 256 qam | 24 |
1 | Locked | 34.9 | 1238 | 0 |
2 | Locked | 35.5 | 155 | 0 |
3 | Locked | 35.5 | 253 | 0 |
4 | Locked | 35.5 | 269 | 0 |
5 | Locked | 35 | 1623 | 0 |
6 | Locked | 35.5 | 102 | 0 |
7 | Locked | 35.5 | 52 | 0 |
8 | Locked | 35.7 | 65 | 0 |
9 | Locked | 35.7 | 49 | 0 |
10 | Locked | 35.7 | 128 | 0 |
11 | Locked | 35.7 | 93 | 0 |
12 | Locked | 35.5 | 202 | 0 |
13 | Locked | 35 | 746 | 0 |
14 | Locked | 34.9 | 634 | 0 |
15 | Locked | 35.5 | 218 | 0 |
16 | Locked | 35.5 | 164 | 0 |
17 | Locked | 35.5 | 57 | 0 |
18 | Locked | 35.7 | 76 | 0 |
19 | Locked | 35.7 | 24 | 0 |
20 | Locked | 36.3 | 9 | 0 |
21 | Locked | 36.3 | 11 | 0 |
22 | Locked | 36.6 | 5 | 0 |
23 | Locked | 37.3 | 17 | 0 |
24 | Locked | 37.3 | 19 | 0 |
on 11-09-2021 16:06
1 | 25800069 | 44.8 | 5120 | 32 qam | 6 |
2 | 39400034 | 45.5 | 5120 | 64 qam | 4 |
3 | 46200093 | 46.3 | 5120 | 64 qam | 3 |
4 | 32600000 | 45 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 11-09-2021 16:07
11/09/2021 16:03:56 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 17:21:54 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/09/2021 06:35:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/09/2021 02:46:40 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/09/2021 09:29:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/09/2021 07:01:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 14:09:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 14:08:56 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 14:08:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 14:08:51 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 14:08:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 13:56:54 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 13:53:12 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 13:53:12 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 13:53:12 | critical | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 13:50:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 13:49:30 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 13-09-2021 16:31
Thanks for your post and welcome to the Community Forums, thejinx6,
Sorry to hear that you have been having connection issues. Have you connections improved since your post? Can you confirm if this behaviour occurs when not in modem mode?
Cheers,
Corey C
on 18-09-2021 16:46
Hey Corey C,
Thanks for the response - appreciate you taking time to help. Unfortunately the issue persists, and if anything is worse (see todays graph attached). I received an email from virgin to say they had 'tweaked the settings on my router' to improve my broadband experience but since that its been worse. Not been able to stick it in router mode as I'm away but will try when I return. Just to say, the connection had been pretty stable for many many months until 3-4 weeks ago and nothing has changed in the setup so this is peculiar.
Will try it in router mode when I have a chance but any further suggestions would be useful.
Thanks in advance!
on 20-09-2021 17:08
Thanks for getting back to us @thejinx6
I'm sorry to see that things have't improved for your connection yet. Please do try putting your Hub in Router Mode and let us know how things are working when you can 🙂 Also, if you let us know when you plan to pop it in Router Mode we can run some more tests on your connection and investigate the issue further once it is in Router Mode.
Kind regards,
Serena
on 27-09-2021 08:54
Hi Serena,
Thanks for your reply. I put the hub back into router mode and early indications (12h or so) suggest it has had no impact - so far its dropped connection totally more than 3 times in that duration so I dont have much hope that has fixed things. I did also do a hard reset of the router by pressing the pin button on the back.
I did note that there seems to be a fault reported in my area with the BB service so suspect it may be prident to wait for that to be cleared before concluding no improvement.
I'll give it another few days but it simply isnt stable enough to work from home so any suggestiong welcome.
Best wishes,
J
on 29-09-2021 08:31
Latest 24h - Virgin reported the fault fixed at 3pm and as you can see its been dropping frequently still since.
Hub is in router mode. Looks like I'll have to give them a call again.
on 01-10-2021 10:45
Thanks for posting the BQM thejinx6, I've taken a look and there are some issues with the upstream channels. I'm going to send you a Private Message to get some more details and arrange a technician visit for you.
Look forward to hearing back from you.
Rob
