on 28-10-2021 20:58
Hi all. For several weeks, I've been experiencing internet dropouts, it happens a few times a day and lasts a few minutes. I'd appreciate some help or guidance.
During the outage, I've tried to check service status and there's nothing, no known outages in the area, and by the time I run a test the service comes back.
Of course this is very difficult as I'm working from home and keep getting dropped during calls.
The Superhub 3 is in modem mode (with an RT-AX86U router).
The hub has two attenuators connected, a 6 db and a 3 db.
I am not 100% sure but I think the hub 'flat' light starts flashing, and then after a few minutes it reboots. I'm able to access the Hub admin console for a while during the outage and then it becomes inaccessible for a brief period during the reboot, then it comes back.
I have performed a factory reset on the Superhub 3 using the pinhole on the back for 60 seconds, but I still get dropouts a few times a day.
Here's some of the information from advanced settings. I've included network logs from both during an outage as well as afterwards.
Status
Item Status Comments
Acquired Downstream Channel (Hz) | 419000000 | Locked |
Ranged Upstream Channel (Hz) | 39400000 | Locked |
Provisioning State | Online |
Downstream
1 | 163000000 | -3.5 | 38 | 256 qam | 4 |
2 | 139000000 | -3.5 | 38 | 256 qam | 1 |
3 | 147000000 | -3.7 | 38 | 256 qam | 2 |
4 | 155000000 | -3.5 | 38 | 256 qam | 3 |
5 | 171000000 | -3 | 38 | 256 qam | 5 |
6 | 179000000 | -3 | 38 | 256 qam | 6 |
7 | 187000000 | -2.9 | 38 | 256 qam | 7 |
8 | 195000000 | -3.5 | 38 | 256 qam | 8 |
9 | 203000000 | -3.4 | 40 | 256 qam | 9 |
10 | 211000000 | -3.4 | 38 | 256 qam | 10 |
11 | 219000000 | -3.5 | 40 | 256 qam | 11 |
12 | 227000000 | -3.7 | 40 | 256 qam | 12 |
13 | 235000000 | -3.7 | 40 | 256 qam | 13 |
14 | 243000000 | -3.5 | 40 | 256 qam | 14 |
15 | 251000000 | -3.2 | 40 | 256 qam | 15 |
16 | 259000000 | -3 | 40 | 256 qam | 16 |
17 | 267000000 | -2.9 | 40 | 256 qam | 17 |
18 | 275000000 | -3 | 40 | 256 qam | 18 |
19 | 283000000 | -2.5 | 40 | 256 qam | 19 |
20 | 291000000 | -2.5 | 40 | 256 qam | 20 |
21 | 299000000 | -1.9 | 40 | 256 qam | 21 |
22 | 307000000 | -1.7 | 40 | 256 qam | 22 |
23 | 315000000 | -1.5 | 40 | 256 qam | 23 |
24 | 323000000 | -1.7 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 1943 | 0 |
2 | Locked | 40.3 | 116196 | 0 |
3 | Locked | 40.9 | 271825 | 0 |
4 | Locked | 40.3 | 257940 | 0 |
5 | Locked | 40.9 | 247098 | 0 |
6 | Locked | 40.9 | 236665 | 0 |
7 | Locked | 40.3 | 238977 | 0 |
8 | Locked | 40.3 | 226905 | 0 |
9 | Locked | 40.3 | 215954 | 0 |
10 | Locked | 40.3 | 206014 | 0 |
11 | Locked | 40.3 | 189354 | 0 |
12 | Locked | 40.3 | 186487 | 0 |
13 | Locked | 40.9 | 175046 | 0 |
14 | Locked | 40.3 | 166003 | 0 |
15 | Locked | 40.9 | 152247 | 0 |
16 | Locked | 40.3 | 146875 | 0 |
17 | Locked | 40.3 | 139234 | 0 |
18 | Locked | 40.3 | 128701 | 0 |
19 | Locked | 40.3 | 130521 | 0 |
20 | Locked | 40.3 | 118686 | 0 |
21 | Locked | 40.9 | 119103 | 0 |
22 | Locked | 40.3 | 103440 | 0 |
23 | Locked | 40.3 | 95940 | 0 |
24 | Locked | 40.3 | 97404 | 0 |
(more to follow)
Answered! Go to Answer
on 29-10-2021 09:55
A few hours later:
1 | 419000000 | 5.8 | 40 | 256 qam | 36 |
2 | 267000000 | 5.5 | 40 | 256 qam | 17 |
3 | 275000000 | 5.6 | 40 | 256 qam | 18 |
4 | 283000000 | 6 | 40 | 256 qam | 19 |
5 | 291000000 | 6.1 | 40 | 256 qam | 20 |
6 | 299000000 | 6.8 | 40 | 256 qam | 21 |
7 | 307000000 | 7 | 40 | 256 qam | 22 |
8 | 315000000 | 7 | 40 | 256 qam | 23 |
9 | 323000000 | 7 | 40 | 256 qam | 24 |
10 | 331000000 | 6.9 | 40 | 256 qam | 25 |
11 | 339000000 | 6.9 | 40 | 256 qam | 26 |
12 | 347000000 | 6.8 | 40 | 256 qam | 27 |
13 | 355000000 | 6.5 | 40 | 256 qam | 28 |
14 | 363000000 | 6 | 40 | 256 qam | 29 |
15 | 371000000 | 6 | 40 | 256 qam | 30 |
16 | 379000000 | 6 | 40 | 256 qam | 31 |
17 | 387000000 | 5.8 | 40 | 256 qam | 32 |
18 | 395000000 | 5.5 | 40 | 256 qam | 33 |
19 | 403000000 | 5.5 | 40 | 256 qam | 34 |
20 | 411000000 | 5.6 | 40 | 256 qam | 35 |
21 | 427000000 | 5.6 | 40 | 256 qam | 37 |
22 | 435000000 | 5.6 | 40 | 256 qam | 38 |
23 | 443000000 | 5.8 | 40 | 256 qam | 39 |
24 | 451000000 | 6 | 40 | 256 qam | 40 |
on 29-10-2021 09:55
1 | Locked | 40.3 | 15668 | 0 |
2 | Locked | 40.9 | 23222 | 0 |
3 | Locked | 40.3 | 21931 | 0 |
4 | Locked | 40.9 | 21197 | 0 |
5 | Locked | 40.9 | 20146 | 0 |
6 | Locked | 40.9 | 20559 | 0 |
7 | Locked | 40.9 | 19517 | 0 |
8 | Locked | 40.9 | 18314 | 0 |
9 | Locked | 40.9 | 17552 | 0 |
10 | Locked | 40.9 | 16262 | 0 |
11 | Locked | 40.9 | 16025 | 0 |
12 | Locked | 40.3 | 15023 | 0 |
13 | Locked | 40.3 | 14104 | 0 |
14 | Locked | 40.9 | 12915 | 0 |
15 | Locked | 40.3 | 12653 | 0 |
16 | Locked | 40.3 | 12053 | 0 |
17 | Locked | 40.9 | 10932 | 0 |
18 | Locked | 40.3 | 11261 | 0 |
19 | Locked | 40.9 | 10253 | 0 |
20 | Locked | 40.9 | 10284 | 0 |
21 | Locked | 40.9 | 8847 | 0 |
22 | Locked | 40.3 | 8317 | 0 |
23 | Locked | 40.3 | 8341 | 0 |
24 | Locked | 40.9 | 7606 | 0 |
on 31-10-2021 09:24
So should I put the attenuators back?
I've also set up a ThinkBroadband quality monitor as I've seen advised in other threads.
Here's the graph
Can someone tell me if this looks 'normal'?
At this moment I can see clumps of packet loss and it's seemingly getting worse.
Here's a graph from October 29th which was a particularly bad day.
on 01-11-2021 17:16
Hi varimathras,
Thanks for posting and sorry to hear you've had some issues with your connection.
I've been able to locate your account using your forum information and can see that you're currently affected by an area SNR issue, the current fix time for this is 8th November.
Whilst this is ongoing your services may be intermittent/ slow.
If you're still experiencing an issue after this date please let us know.
Alex_Rm
on 03-11-2021 17:53
Hi varimathras,
Thanks for posting and sorry to see you're still experiencing some issues with the connection.
I've had a look and can see you're currently affected by an area SNR outage. Whilst this is ongoing you may find your services are intermittent.
The fix date for this is 8th November, if you're still having an issue with the connection after this date, please let us know.
Alex_Rm
on 03-11-2021 19:50
Alright thanks for that Alex_RM, I will wait and then message again. Yes the problem is still happening few times a day and it's quite hard to work like this.
I did manage to get an engineer visit on Nov 2nd. He said something along the lines of what you said, legacy1, about the 'tap' levels changing (not a familiar set of jargon for me so I've probably got some words mixed up). He said it was good that the attenuators were removed, the levels looked better compared to before.
He also changed the isolator (I think that's the word he used? it was a rectangular metal thing which the coaxial cable connects to) and did something similar on the outside of the house and also said that he did some rewiring at the cabinet.
So I suppose at least this eliminates any problems that could have been as far as my own home is concerned, isn't it. The problem shouldn't be my Hub3, it shouldn't be my cables.
The problem must actually be the "SNR" as you said. I don't know enough about SNR to understand why it happens in bursts between islands of calm!
on 05-11-2021 20:34
Thanks for getting back to us @varimathras.
I'm glad to hear you've had an engineer out to come take a look at things for you.
I've just checked your account and I can see the SNR outage is still ongoing, and the estimated fix time still stands at 08/11/21 at 10:05am.
Please let us know how the service performs once this has been resolved 🙂
on 10-11-2021 22:19
At the risk of jinxing myself and suddenly having the problem return on me with a renewed exponential vengeance.
It's now November 10th. The past few days the connection has been stable. No problems, no dropouts at all. So it's just as you said there was an SNR issue in the area. Work calls have been good too, no degraded quality.
Thanks all of you for commenting/replying, it was useful for me (and reassuring too). I'm glad that I posted here.
Hey VM team, as a wishlist item, it would be nice if these 'hidden' problems could be reported as well.
on 13-11-2021 10:10
Thank you for the update @varimathras.
I am glad to hear the service has improved since. We truly do appreciate your feedback and will pass this on to the relevant team for improvement. Please do not hesitate to contact us if you need any further help.
