on 24-08-2022 13:49
Hi Folks
I've recently started experiencing drop in connection issues. It's very random times and seems to only be for a few seconds - although it's enough to disrupt apps like MS Teams. When I've been quick enough to check WiFi, it seems my PC is connected to the router, but the router has lost internet. I did check the logs and I can see some strange errors, but none seem to relate to the issue as it's happened three times today. I've attached a screen grab below. Any help appreciated.
Answered! Go to Answer
on 08-09-2022 10:48
Hey gezsugg, thank you for reaching back out and sending this information over.
I have run some more tests and everything is looking good, however I would like to run some more in-depth tests with you.
I am going to send you a PM, please can you look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
on 24-08-2022 15:24
on 25-08-2022 16:13
Thanks for replying. Sorry about the image, I've attached again with MAC's blocked out. Unfortunately the issue happens when I'm in my home office, away from the router (which is a Hub 3 model). The connection drops and reconnects within a few seconds, so I cannot get to the router to check. The light is solid white when ever I look at the hub and I've not noticed any issue with Sky Q/Xbox/etc that are hardwired. When the connection drops, I have noticed it also affects my phone (also on wifi) but again it's a few seconds. I am using a Virgin Pod to extend WiFi.
on 25-08-2022 16:22
on 29-08-2022 08:17
Hi gezzugg, thank you for posting on our help forum and welcome to our community.
Sorry to hear of the issues you had with dropping connection on the WiFi, since you've stated we have added a WiFi Pod to enhance the wireless signal could you please advise if the issue occurs on all devices at the same time or if there are devices struggling to connect from a certain spot in the house?
Also, you can visit this page here and find more info as well as some fixes depending on the issue we detect.
Let us know how things go since you last posted and if you still need our help with the above, happy to assist you.
on 30-08-2022 14:32
Hi.
I'm unable to tell if all devices are affected as it happens while I'm working. It's literally a few seconds issue - but is enough to drop MS Teams calls, causing me a problem. I've not noticed any dropouts on other devices, but as I'm only browsing the internet or watching Netflix, it would be less noticeable. I am running a monitor, as suggested by another forum member. Once this has collated some data I will share here.
on 01-09-2022 19:27
Hi gezsugg, thanks for getting back to us.
Please do post your results when collated? I have checked our systems from here and cannot find anything that explains the issue you're reporting.
Lee
05-09-2022 09:56 - edited 05-09-2022 10:36
Hi Folks
Sorry for the delay. For some reason all the notification emails get sent to spam, despite me flagging as not-spam. I'm still having this issue randomly. Today (Mon 5th Sep) it happened at 9:39am. I was on a Teams call when my connection 'blipped'. I could still hear everyone, but they could not hear me. My connection showed NOT connected to internet, but I was connected to the router (?!?!).
Here's the latest snapshot from the monitor. Thanks in advance.
on 06-09-2022 10:07
Today I experienced another loss of connection (09:23). This time I happened to be listening to the radio on a WiFi speaker. This also dropped, as did my mobile phone connection to WiFi. Updated monitor below. Can anyone at VM check to see if there was any minor 'blip' at this time for my connection?
on 08-09-2022 10:48
Matt - Forum Team
New around here?
