on 23-08-2022 19:58
Hello,
I am suffering intermittent dropouts at (I believe) random times of the day. I noticed this in router mode and assumed the Virgin Hub was the issue so now use the router in modem mode with an Asus ZenWifi AX (AT8) router.
It has made no difference so I don't believe the issue is inside my property. It is affecting wired connections as well as the Wi-Fi, and there do not appear to be any wider issues in my area when I do a check. All wires are new and I have checked connections.
Does anyone know what I can check in the Hub 3.0 settings to see if it is a problem on the outside of my network?
on 23-08-2022 20:42
Hi!
type in http://192.168.0.1 or http://192.168.100.1 (If in modem mode) in your browser,
Don't log in, click the text that says ">Check router status"
Copy and paste everything from the Upstream, Downstream and Network log.
The forum will filter out MAC-address.
Also set up one of these: https://www.thinkbroadband.com/broadband/monitoring/quality
You'll need to allow ICMP in the hub settings, however.
on 23-08-2022 20:51
23/08/2022 20:47:16 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 19:41:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 19:40:21 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 19:38:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 19:38:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 19:38:5 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 19:36:45 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 19:36:45 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 19:18:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 18:32:44 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 18:31:50 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 18:29:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 18:29:26 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 05:08:32 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 05:08:32 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 02:43:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 02:20:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 02:17:9 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 02:16:55 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2022 02:16:55 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 23-08-2022 20:51
1 | 330750000 | 5.3 | 40 | 256 qam | 25 |
2 | 202750000 | 5.5 | 40 | 256 qam | 9 |
3 | 210750000 | 5.4 | 40 | 256 qam | 10 |
4 | 218750000 | 5.4 | 40 | 256 qam | 11 |
5 | 226750000 | 5.5 | 40 | 256 qam | 12 |
6 | 234750000 | 5.6 | 40 | 256 qam | 13 |
7 | 242750000 | 5.6 | 40 | 256 qam | 14 |
8 | 250750000 | 5.8 | 43 | 256 qam | 15 |
9 | 258750000 | 5.8 | 40 | 256 qam | 16 |
10 | 266750000 | 5.8 | 40 | 256 qam | 17 |
11 | 274750000 | 5.8 | 40 | 256 qam | 18 |
12 | 282750000 | 5.9 | 40 | 256 qam | 19 |
13 | 290750000 | 5.6 | 40 | 256 qam | 20 |
14 | 298750000 | 5.6 | 40 | 256 qam | 21 |
15 | 306750000 | 5.5 | 40 | 256 qam | 22 |
16 | 314750000 | 5.5 | 40 | 256 qam | 23 |
17 | 322750000 | 5.5 | 40 | 256 qam | 24 |
18 | 338750000 | 5 | 40 | 256 qam | 26 |
19 | 346750000 | 5.3 | 40 | 256 qam | 27 |
20 | 354750000 | 5.3 | 40 | 256 qam | 28 |
21 | 362750000 | 5.1 | 40 | 256 qam | 29 |
22 | 370750000 | 5 | 40 | 256 qam | 30 |
23 | 378750000 | 4.8 | 40 | 256 qam | 31 |
24 | 386750000 | 4.4 | 40 | 256 qam | 32 |
1 | Locked | 40.3 | 20 | 80 |
2 | Locked | 40.3 | 17 | 0 |
3 | Locked | 40.3 | 19 | 0 |
4 | Locked | 40.9 | 17 | 0 |
5 | Locked | 40.9 | 13 | 0 |
6 | Locked | 40.9 | 15 | 0 |
7 | Locked | 40.9 | 17 | 0 |
8 | Locked | 43.3 | 18 | 0 |
9 | Locked | 40.9 | 17 | 0 |
10 | Locked | 40.9 | 18 | 0 |
11 | Locked | 40.9 | 16 | 0 |
12 | Locked | 40.9 | 12 | 0 |
13 | Locked | 40.9 | 14 | 0 |
14 | Locked | 40.9 | 12 | 0 |
15 | Locked | 40.9 | 15 | 0 |
16 | Locked | 40.9 | 14 | 0 |
17 | Locked | 40.3 | 12 | 0 |
18 | Locked | 40.3 | 8 | 0 |
19 | Locked | 40.9 | 13 | 0 |
20 | Locked | 40.3 | 14 | 0 |
21 | Locked | 40.9 | 12 | 0 |
22 | Locked | 40.9 | 10 | 0 |
23 | Locked | 40.9 | 18 | 0 |
24 | Locked | 40.9 | 6 | 0 |
on 23-08-2022 20:51
1 | 32600024 | 43 | 5120 | 64 qam | 5 |
2 | 39400048 | 43.5 | 5120 | 64 qam | 4 |
3 | 46200004 | 43.5 | 5120 | 64 qam | 3 |
4 | 53700017 | 45 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
23-08-2022 21:26 - edited 23-08-2022 21:34
This error right here, quite a few of them in the logs.
and of course a few T4 timeouts to go along with it
I'm guessing the Post and Pre-RS errors are clearing after the T4 timeouts, or i'd be expecting to see a lot more of them from the partial service, etc.
Can you keep an eye on them and see how fast they climb?
You'll definitely need staff to take a look,
At least the issues are sticking out right away, so fingers crossed for a fast fix!
until then I'd suggest checking the service faults page: https://www.virginmedia.com/help/service-status
See if there's anything showing there for your post code.
If you're interested in what those error messages are, there's a lovely little write-up here: https://community.virginmedia.com/t5/Speed/Hub-status-data-understanding-network-log-messages/td-p/4...
on 23-08-2022 21:44
Thanks so much for your help with this. That link explaining the errors is magic as well.
What's the best way to get someone on staff to read this post? Do they do it as a matter of course or do I need to somehow instigate this process?
23-08-2022 21:48 - edited 23-08-2022 21:48
Hey, no worries!
Just paying forward the same help i've received!
The link is definitely a good one 🙂
In regards to staff:
You'll have to wait a few days, usually. - you wont have to do anything 🙂
Much easier than dealing with and being fobbed off by the offshore CS.
on 26-08-2022 08:41
Hey jasonprf, thank you for reaching out and I am sorry to hear you are having some connection issues.
Would it be possible to take it out of modem mode and just use the router to see if this makes any difference at all?
How did you get on checking the settings, has anything improved over the last few days?
Please do let me know. Thanks
Matt - Forum Team
New around here?
on 26-08-2022 09:27
Hi Matthew,
I was using the hub in router mode and initially thought the issue was because of this. I then invested quite o lot of cash on the ASUS router system to boost my wifi coverage and also to take some of the 'load' off the virgin hub but the dropouts are still occurring. Nothing has changed over the past few days although I've not changed any settings. The help I received above was purely to obtain and share logs which I was advised point to an issue on the WAN rather than my LAN.
