Intermittent drop outs and high packet loss
tigger2014
Ive had on going issues for months, A number of things have been done by networks to resolve the issue but it appears to be ongoing.
I  think levels look ok to me?
11630000002.238256 qam4
21390000003.238256 qam1
31470000003.238256 qam2
41550000002.538256 qam3
5171000000238256 qam5
61790000001.738256 qam6
71870000001.738256 qam7
81950000001.440256 qam8
9203000000138256 qam9
102110000000.938256 qam10
112190000000.740256 qam11
122270000000.538256 qam12
132350000000.238256 qam13
14243000000-0.538256 qam14
15251000000-138256 qam15
16259000000-0.738256 qam16
17267000000038256 qam17
182750000000.540256 qam18
192830000000.740256 qam19
202910000000.540256 qam20
212990000000.540256 qam21
223070000000.540256 qam22
233150000000.240256 qam23
243230000000.240256 qam24
1Locked38.93600
2Locked38.94660
3Locked38.94160
4Locked38.63820
5Locked38.93250
6Locked38.92460
7Locked38.92200
8Locked40.92160
9Locked38.61930
10Locked38.61620
11Locked40.31620
12Locked38.91340
13Locked38.61180
14Locked38.61100
15Locked38.91080
16Locked38.9960
17Locked38.6890
18Locked40.3650
19Locked40.9630
20Locked40.3480
21Locked40.3700
22Locked40.3600
23Locked40.9790
24Locked40.3620
14620000039.5512064 qam3
23940000038.5512064 qam4
35370000041512064 qam2
46030000041.5512064 qam1
1ATDMA0010
2ATDMA0020
3ATDMA0080
4ATDMA00100
16 REPLIES 16
Hello,
Still an issue today
Fault is still present, Can i get an update with the new reference number and estimated fix please?
I also have an open complaint regarding this as its been on going for months, Ive had no phone calls or anything regarding the complaint but was sent a rather insulting letter that suggests my property is the issue, clearly the handler of the complaint did not read over the vast notes on the account and just sent me a generic template.
This is rapidly approaching going to the ISPA and the ombudsman
Good Afternoon @tigger2014, I've been able to look into the local area and can see that the known outage is estimated to be resolved on 30/06/22 at 15:10.
We apologise for the ongoing frustration this has caused you.
Kindest regards,
David_Bn
Hello,
I think all the area issues are now resolved, connection is a lot better generally but still has bad days like today, I was contacted by the resolve team and was assured a follow up call, I think they have tried to get in touch but timing was awful and i was in meetings unable to answer, Is it possible to get a note over to them somehow to get them to give me another call back. They were also assisting with a rather awful handling of a complaint.
Cheers
Hi tigger2014,
Thanks for your post and update on how things have been with your connection.
Taking a look at things this end, I can see that the area fault has indeed closed so this is no longer affecting you. The hub is showing online and all the levels look good too.
In terms of the resolutions team, we're unable to arrange call backs via the Forums I'm afraid. You can give the team a call on 150 / 0345 454 1111 and they'll be able to help though.
Let us know how you get on by coming back and updating the thread.
Kath_F
tigger2014
A couple of months later and i appear to be back in the same position, although this time it does look to be RS error issue, at least not on my segment.
Seems like with the rather heavy rain we had on the night of the 7th it appears to have all gone belly up again. Not saying the rain is the cause but is certainly suspicious.
Called up today and got told to jump through the usual hoops, Pin hole reset etc and like clockwork it of course didn't help.
This time however it got me thinking my Hub is not appearing to drop off however packet loss jumps up to a level when you notice it browsing the web and especially on work calls. I wonder if the upstream gateway is having issues, Ive added a BQM of my GW (WAN IP ending in .1)
BQM of the upstream Gateway https://www.thinkbroadband.com/broadband/monitoring/quality/share/7945deafec5fea8b724a3349f991cbcc49...
It certainly looks like the upstream gateway is having similar packet loss to me, Might need passing over the networking team beyond usual field support.
Also below is an example of when im getting packet loss to the internet (1.1.1.1 or 8.8.8.8 for example) but no packet loss at all to the upstream gateway
Internet ping being the green line
Upstream gateway ping being the orange line (right at bottom of graph)
Ive ended up with another engineer visit booked for this Thursday, Will see what the outcome of that is but this is certainly looking like an issue external to my property/line, But as always must jump through the usual hoops to get anywhere.
BQM of my line
BQM live https://www.thinkbroadband.com/broadband/monitoring/quality/share/849a14578c9f9c272403d7e43b026c6930...
10th https://www.thinkbroadband.com/broadband/monitoring/quality/share/dd6a83ecbc7afa6e6aa376ab6cf9e02b58...
9th https://www.thinkbroadband.com/broadband/monitoring/quality/share/9dca375561f9b7e0b87468c26f1fc71a4e...
8th https://www.thinkbroadband.com/broadband/monitoring/quality/share/7a26bb8cf67f8b598172df41f937ecad10...
7th https://www.thinkbroadband.com/broadband/monitoring/quality/share/ab3ebe87de4c0e17d8dda736d34832834e...
Hi tigger2014,
Thanks for your post and apologies to hear your issues are back.
As you've mentioned you have an engineer booked, we'll need to wait until this visit completes. If there is anything needing to be referred up to the Networks team, the engineer will do this  whilst there.
Please keep us posted on how the visit goes.
Many thanks,
Kath_F
