on 05-02-2024 19:10
Have an issue with intermittent signal. Engineer has replaced damaged cables outside and now the Virgin hub inside. Still have issues with the signal dropping out. Happens with the Virgin hub in modem mode or not.
1 | 330750000 | -3.7 | 40 | 256 qam | 25 |
2 | 226750000 | -3 | 40 | 256 qam | 12 |
3 | 234750000 | -3 | 40 | 256 qam | 13 |
4 | 242750000 | -3.5 | 40 | 256 qam | 14 |
5 | 250750000 | -3.5 | 43 | 256 qam | 15 |
6 | 258750000 | -3.5 | 43 | 256 qam | 16 |
7 | 266750000 | -3.5 | 40 | 256 qam | 17 |
8 | 274750000 | -3.5 | 43 | 256 qam | 18 |
9 | 282750000 | -4 | 40 | 256 qam | 19 |
10 | 290750000 | -3.7 | 43 | 256 qam | 20 |
11 | 298750000 | -4.2 | 40 | 256 qam | 21 |
12 | 306750000 | -3.7 | 40 | 256 qam | 22 |
13 | 314750000 | -3.5 | 40 | 256 qam | 23 |
14 | 322750000 | -3.7 | 40 | 256 qam | 24 |
15 | 338750000 | -4.7 | 40 | 256 qam | 26 |
16 | 346750000 | -4.2 | 40 | 256 qam | 27 |
17 | 354750000 | -4.4 | 43 | 256 qam | 28 |
18 | 362750000 | -4.5 | 40 | 256 qam | 29 |
19 | 370750000 | -4.2 | 40 | 256 qam | 30 |
20 | 378750000 | -4.9 | 40 | 256 qam | 31 |
21 | 386750000 | -4.5 | 40 | 256 qam | 32 |
22 | 394750000 | -5.5 | 40 | 256 qam | 33 |
23 | 402750000 | -6 | 40 | 256 qam | 34 |
24 | 410750000 | -6 | 40 | 256 qam | 35 |
1 | Locked | 40.3 | 461 | 1325 |
2 | Locked | 40.9 | 632 | 1271 |
3 | Locked | 40.9 | 608 | 1328 |
4 | Locked | 40.9 | 585 | 1412 |
5 | Locked | 43.3 | 592 | 1382 |
6 | Locked | 43.3 | 517 | 1472 |
7 | Locked | 40.9 | 512 | 1587 |
8 | Locked | 43.3 | 508 | 1413 |
9 | Locked | 40.9 | 446 | 1364 |
10 | Locked | 43.3 | 469 | 1574 |
11 | Locked | 40.9 | 482 | 1233 |
12 | Locked | 40.9 | 460 | 1429 |
13 | Locked | 40.9 | 449 | 1352 |
14 | Locked | 40.9 | 481 | 1492 |
15 | Locked | 40.9 | 451 | 944 |
16 | Locked | 40.9 | 514 | 975 |
17 | Locked | 43.3 | 426 | 1179 |
18 | Locked | 40.9 | 457 | 1223 |
19 | Locked | 40.9 | 450 | 1256 |
20 | Locked | 40.9 | 483 | 950 |
21 | Locked | 40.9 | 500 | 811 |
22 | Locked | 40.3 | 495 | 626 |
23 | Locked | 40.9 | 462 | 657 |
24 | Locked | 40.3 | 520 | 762 |
on 05-02-2024 19:31
If there really is only one upstream channel at 32qam... then there's your issue. The down channel power levels are on the low side too anf there are post RS errors. Strt from a clean sheet and do this...
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only another Tech visit will sort.
Also check the Upstream channels have reappeared and all QAM’s are at 64
on 06-02-2024 20:13
Thanks. Done the above. Cables all look fine. Still have issues with intermittent connection/ packet loss.
on 06-02-2024 20:15
Check for local issues here:
https://www.virginmedia.com/support/help/service-status
Run the 'Still having issues' check if nothing is returned.
on 06-02-2024 20:16
You might need a new hub
on 06-02-2024 20:16
Had one installed by an engineer, same issue
on 06-02-2024 20:17
Yeah I have been through all the steps and had 2 engineer visits - none of which have fixed the issue.
on 06-02-2024 20:18
faulty amp then
on 09-02-2024 15:30
Hi arcircus,
We're sorry to hear that despite several engineer visits, you are still having an issue with your connection. Checking thins this end, I can see a more senior engineer appointment has been booked.
Can you please let us know how this visit goes?
on 09-02-2024 18:00
I need a new external cable fitted. The soonest it can be done it’s the 23rd. I don’t think it’s acceptable that I will be without wifi for that long. Can you advise what I can do in this situation please.
