on 18-11-2021 12:28
Hello, have been with Virgin since the start and also before, when it was NTL, almost 30yrs I would think. All that time I have had itermittent connection loss on ethernet and wifi. On older modems before the hub 3.0, all modems would reboot on signal loss, this doesn't happen with the Hub 3.0, white light stays on continiously. Normally I have a seperate router - Synology RT2600 and Hub in modem mode, but have since removed to illiminate this as a problem. Over the last few months this connection loss has gotten worse, can happen as little as once a night to multiple times a night. I have tried over the years to call them and everytime I do the results are the same, everything is fine according to our checks, so I gave up calling them, until today, and the answer is still the same apart from we can#t send out a technician as no fault found, but if you pay £25 we can. I have replaced ethernet cables, checked all internal connections are tight and not damaged, taken out my router and connected my main PC directly to the hub and anything else that can be hard wired directley to the hub, the only place the fault can be is from the box on the outside of my house to the cabinet in the street, possibly cable and/or connection degradation due to age??
Connection loss is more noticeable when gaming (Call of Duty) or when browsing YouTube.
Answered! Go to Answer
on 18-11-2021 18:20
Thanks for your help, currently unable to access link
It's something at our end, and we?re working as fast as we can to fix it.
If you try again later everything will be sorted. Sorry for the inconvenience.
Need to do anything else?
Take me to:
on 18-11-2021 19:12
Thanks for your help, can't see anything on there yet, will check later
on 18-11-2021 20:10
Thank you for coming back to me @george64,
Have you manged to find it? If not I can pop back to our PM and confirm that for you.
Kind regards,
Zak_M
on 19-11-2021 05:34
on 20-11-2021 19:19
Thank you Zak_M for arranging tech visit, very helpful tech turned up this morning and sorted power levels out, he has also arranged for repull of cables on 3rd December due to noise on the cable.
Thank you
on 22-11-2021 19:47
Hi George64,
Thank you for updating us on your visit. I am glad all went well:)
Please do keep us posted on your repull.
Zoie
