on 22-09-2021 13:34
Good afternoon all
Unfortunately I have an intermittent connection and have done for the last 3-4 weeks. Originally Virgin admitted a network fault, I received a text to say it was sorted, but it’s actually worse. Called again spoke to second line support who confirmed there was still an issue and they’d escalated it - this was 2 days ago. Called again today and was advised there was no external fault and that it was my own TP router - despite the modem continuously losing sync. Power signals seems ok, SNR does seem high - can I get your opinions. Power levels also fluctuate quite often. Thanks
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1 | 419000000 | 6.3 | 40 | 256 qam | 36 |
2 | 235000000 | 7.5 | 40 | 256 qam | 13 |
3 | 243000000 | 7.5 | 40 | 256 qam | 14 |
4 | 251000000 | 7.1 | 40 | 256 qam | 15 |
5 | 259000000 | 7.1 | 40 | 256 qam | 16 |
6 | 267000000 | 7.1 | 40 | 256 qam | 17 |
7 | 275000000 | 7.3 | 40 | 256 qam | 18 |
8 | 283000000 | 7 | 40 | 256 qam | 19 |
9 | 291000000 | 7.3 | 40 | 256 qam | 20 |
10 | 299000000 | 7.6 | 40 | 256 qam | 21 |
11 | 307000000 | 7.9 | 40 | 256 qam | 22 |
12 | 315000000 | 7.6 | 40 | 256 qam | 23 |
13 | 323000000 | 7.4 | 40 | 256 qam | 24 |
14 | 331000000 | 7.5 | 40 | 256 qam | 25 |
15 | 339000000 | 7.6 | 40 | 256 qam | 26 |
16 | 347000000 | 7.5 | 40 | 256 qam | 27 |
17 | 355000000 | 7.1 | 40 | 256 qam | 28 |
18 | 363000000 | 7.5 | 40 | 256 qam | 29 |
19 | 371000000 | 7.5 | 40 | 256 qam | 30 |
20 | 379000000 | 7.5 | 40 | 256 qam | 31 |
21 | 387000000 | 7 | 40 | 256 qam | 32 |
22 | 395000000 | 7.1 | 40 | 256 qam | 33 |
23 | 403000000 | 6.8 | 40 | 256 qam | 34 |
24 | 411000000 | 6.8 | 40 | 256 qam | 35
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID13940000036.8512064 qam1223260000036.3512064 qam1334620000037.3512064 qam1145370000038.3512064 qam10
on 22-09-2021 13:35
1 | 39400000 | 42.3 | 5120 | 64 qam | 12 |
2 | 32600000 | 41.8 | 5120 | 64 qam | 13 |
3 | 46200000 | 42.3 | 5120 | 64 qam | 11 |
4 | 53700000 | 38.3 | 5120 | 64 qam | 10 |
on 22-09-2021 15:03
on 22-09-2021 15:57
Thanks - it confirms there are no outages. Did receive a call from the executive team though as I raised a complaint. The case handler ran some diagnostics and confirmed there was an issue. Booked an engineer in for tomorrow.
on 24-09-2021 16:11
Hi @SheziKalebra thanks for coming back to us.
How did your appointment go? Has things improved?
Lee_R
on 24-09-2021 19:34
@Lee_R
Issue is still not resolved - engineer could not see any fault on my end. There is an issue on the network but they don’t know where it is.
on 27-09-2021 11:40
Thanks very much for the details @SheziKalebra
Did the engineer advise on what actions they will be taking regarding the network issue?
Kind regards,
Serena
on 28-09-2021 09:57
@Serena_C
They were going to monitor it and take it from there. So just a waiting game, but I’d like an option to be able to track the fault for updates etc without having to call in. The complaint has also been closed although the issue is still ongoing, and all complaint points haven’t been addressed.
BTW when I @ a user it doesn’t actually tag them, what’s the correct way to do it?
on 30-09-2021 10:09
Hello SheziKalebra
Thanks for getting back to us, from looking at your account I can see you have spoken to the team since posting and that they have updated you on this and arranged a call back for today.
Let us know the outcome of the call.
Rob
on 08-10-2021 11:14
Good morning. The issue was resolved following network repairs. But this was a temporary fix and the issues are back, which started again yesterday. Multiple drop outs - network log:
08/10/2021 09:43:51 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 05:36:0 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 05:34:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 04:47:35 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 04:47:35 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 01:23:59 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 01:10:12 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 00:04:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 00:02:12 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2021 00:00:53 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 18:53:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 18:03:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 18:02:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 18:02:31 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 18:02:23 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 18:02:21 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 16:46:55 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 16:37:2 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 16:34:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/10/2021 16:34:56 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
