on 05-07-2021 19:34
I saw many people have the same problem but still. Connection dropping off every 10 15 mins. This sh.t stated 3 weeks ago. I thought is something temporarily but obviously is not. Specially after 5-6 pm is OMG. If many people are reporting the same maybe there is a major problem with Virgin network. And yes I restarted the router 200 times and reset it 100 times.
Channel Frequency (Hz) Power (d B m V) Symbol Rate ( k s p s) Modulation Channel ID
1 | 39399983 | 47.5 | 5120 | 64 q am | 2 |
2 | 25800000 | 47.3 | 5120 | 64 q am | 4 |
3 | 32600046 | 46.5 | 5120 | 64 q am | 3 |
4 | 46200068 | 47.3 | 5120 | 64 q am | 1 |
1 | ATDMA | 0 | 0 | 6 | 0 |
2 | ATDMA | 0 | 0 | 6 | 0 |
3 | ATDMA | 0 | 0 | 11 | 0 |
4 | ATDMA | 0 | 0 | 17 | 0 |
05/07/2021 18:01:28 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:59 | critical | No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:59 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:58 | critical | No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:47 | critical | SYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:47 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:19 | critical | No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:19 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:19 | critical | SYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:0 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 18:00:0 | critical | SYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 17:59:51 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 17:59:19 | critical | No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 17:59:6 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 17:59:6 | critical | SYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 17:58:38 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 17:58:38 | critical | SYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2021 17:58:18 | critical | SYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 12-07-2021 19:37
Just to let you know. The guy from VM was here on Saturday morning and he changed the router. Apparently that was the problem. Last 3 days everything is ok.There is not droppings.
Thanks for the help.
on 12-07-2021 19:49
Hello @IVAYLO81.
Thank you for updating us with this information.
I am glad to see that this has improved your services, please do let us know if you have anymore issues (if any)
Take care 🙂
on 09-09-2021 18:04
HI,
What did you do guys? After the last time when the problem was solved today start again. Virgin were doing essential works on the network in my area today and yesterday. There was not problem yesterday but today when the finish the problem start. 🙂 Connection dropping off every 10 - 15 mins. Restart or reset does not help. Last time the guy from virgin change the router and till today everything was ok. So I think maybe you have to change it again. Idk. Lets see how will be in the next few days but I sure will be the same. Hope not.
on 09-09-2021 20:28
on 12-09-2021 13:47
Hi IVAYLO81,
Thanks for your post and I'm sorry to hear about the issues you have been having with your broadband. I'm happy to take a look in to things but I've been unable to locate your account via your forum credentials. I will need to confirm some information with you in order for me to proceed with checks.
I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right hand side of the page to access your inbox.
on 12-09-2021 21:14
Well the same as before. I think.
Channel Frequency (Hz) Power (dB mV) Symbol Rate (k s p s) Modulation Channel ID
1 | 39399971 | 47.3 | 5120 | 64 q am | 2 |
2 | 25800000 | 45.8 | 5120 | 64 q am | 4 |
3 | 32600009 | 47.3 | 5120 | 64 q am | 3 |
4 | 46200129 | 47.3 | 5120 | 64 q am | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
12/09/2021 20:02:8 | notice | LAN login Success; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/09/2021 20:00:24 | Warning! | LAN login FAILED : Incorrect Username / Password / Connection Type ; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/09/2021 18:26:35 | critical | No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/09/2021 19:49:25 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/09/2021 23:29:41 | critical | No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 19:59:41 | Warning! | RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 17:29:53 | notice | DHCP Renew - lease parameters t ftp file-cmreg-vmdg505-bbt057-b.cm modified; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 17:29:53 | Error | DHCP RENEW WARNING - Field invalid in response v4 option; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 16:36:45 | notice | DHCP Renew - lease parameters t ftp file-cmreg-vmdg505-bbt057-b.cm modified; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 16:36:45 | Error | DHCP RENEW WARNING - Field invalid in response v4 option; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:40 | critical | No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 15:53:2 | notice | DHCP Renew - lease parameters t f t p file-cmreg-vmdg505-bbt057-b.cm modified; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 15:53:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 15:23:1 | notice | DHCP Renew - lease parameters t f t p file-cmreg-vmdg505-bbt057-b.cm modified; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 15:23:1 | Error | DHCP RENEW WARNING - Field invalid in response v4 option; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 14:53:1 | notice | DHCP Renew - lease parameters t f t p file-cmreg-vmdg505-bbt057-b.cm modified; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 14:53:1 | Error | DHCP RENEW WARNING - Field invalid in response v4 option; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:37 | critical | No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 13:49:5 | notice | DHCP Renew - lease parameters ttp file-cmreg-vmdg505-bbt057-b.cm modified; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 13:49:5 | Error | DHCP RENEW WARNING - Field invalid in response v4 option; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 13-09-2021 09:52
Hi IVAYLO81,
Thanks for coming back to me on via private message with your information.
Checking the account today it looks as though the work is still ongoing. The details of this are below:
I have made a note of this on your account so the relevant teams are aware you are affected. Once the fault is been resolved we can look further in to things for you.
If there is anything else we can do, let us know.
on 15-09-2021 10:55
Hi @UZUNOV thanks for posting and welcome back to our community.
Sorry to hear of your intermittent internet connection. I have located your account from here and found that there is planned works in your area that we hope will resolve the issue you've reported. The estimated completion time is 3:30pm today. If things have not improved after this time, please do get back to us.
Lee_R
16-09-2021 20:08 - edited 16-09-2021 20:09
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/7e888e364ffb11e94fd53c538d1c35d47d686205"><img alt="My Broadband Ping - Network" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/7e888e364ffb11e94fd53c538d1c35d47d686205.png" /></a>
How it looks like? Still there is droppings not like before (10 - 15 mins) but still have them.
on 16-09-2021 20:20
Channel Frequency (Hz) Power (dB mV) SNR (dB) Modulation Channel ID
1 | 171000000 | 5.4 | 40 | 256 q am | 5 |
2 | 139000000 | 5.3 | 40 | 256 q am | 1 |
3 | 147000000 | 5.5 | 40 | 256 q am | 2 |
4 | 155000000 | 5.5 | 40 | 256 q am | 3 |
5 | 163000000 | 5.5 | 40 | 256 q am | 4 |
6 | 179000000 | 5.4 | 40 | 256 q am | 6 |
7 | 187000000 | 5.1 | 40 | 256 q am | 7 |
8 | 195000000 | 5 | 40 | 256 q am | 8 |
9 | 203000000 | 4.6 | 40 | 256 q am | 9 |
10 | 211000000 | 4.5 | 40 | 256 q am | 10 |
11 | 219000000 | 4.4 | 40 | 256 q am | 11 |
12 | 227000000 | 4 | 38 | 256 q am | 12 |
13 | 235000000 | 3.9 | 40 | 256 q am | 13 |
14 | 243000000 | 3.7 | 40 | 256 q am | 14 |
15 | 251000000 | 3.7 | 40 | 256 q am | 15 |
16 | 259000000 | 3.7 | 40 | 256 q am | 16 |
17 | 267000000 | 3.7 | 40 | 256 q am | 17 |
18 | 275000000 | 4.5 | 40 | 256 q am | 18 |
19 | 283000000 | 5 | 40 | 256 q am | 19 |
20 | 291000000 | 5.1 | 40 | 256 q am | 20 |
21 | 299000000 | 5.3 | 40 | 256 q am | 21 |
22 | 307000000 | 4.6 | 40 | 256 q am | 22 |
23 | 315000000 | 4.5 | 40 | 256 q am | 23 |
24 | 323000000 | 4.4 | 40 | 256 q am | 24 |
Channel Locked Status Rx MER (dB) Pre RS Errors Post RS Errors
1 | Locked | 40.3 | 3189 | 3727 |
2 | Locked | 40.9 | 343759 | 87744 |
3 | Locked | 40.3 | 45315 | 15545 |
4 | Locked | 40.3 | 3599 | 5456 |
5 | Locked | 40.3 | 4862 | 4860 |
6 | Locked | 40.3 | 3856 | 4684 |
7 | Locked | 40.3 | 3795 | 3578 |
8 | Locked | 40.3 | 5930 | 4079 |
9 | Locked | 40.9 | 5382 | 6897 |
10 | Locked | 40.3 | 3717 | 3429 |
11 | Locked | 40.9 | 4185 | 3322 |
12 | Locked | 38.9 | 8159 | 5077 |
13 | Locked | 40.3 | 7084 | 4240 |
14 | Locked | 40.3 | 3902 | 5807 |
15 | Locked | 40.3 | 3223 | 3943 |
16 | Locked | 40.3 | 4092 | 4563 |
17 | Locked | 40.9 | 3798 | 3838 |
18 | Locked | 40.3 | 2691 | 6885 |
19 | Locked | 40.3 | 2814 | 5044 |
20 | Locked | 40.9 | 2472 | 1929 |
21 | Locked | 40.3 | 2571 | 3683 |
22 | Locked | 40.3 | 2034 | 3294 |
23 | Locked | 40.9 | 2981 | 4591 |
24 | Locked | 40.3 | 3335 | 3628 |
