spudjones
Message 1 of 5
Intermittent connection | known fault
Hey there,
I've been dealing with an intermittent connection for the last 10 days or so. While service status page was all green, calling their 0800 number tells me that there's a complex fault in my area (W11). I figured there's nothing I can do on my end, but hope that by posting here someone from VM but can give me more context around the fault (what it is, estimated fix date etc.), and if by chance there's something I can do on my end.
Some context:
  • On M500, SH3 in modem mode with ASUS RT-AC86U
  • Done the usual tests, resets, cable checks (using coax provided by VM)
  • Affects all devices both wireless and ethernet
  • Speeds constantly fluctuating across down/up eg. up should be 32 but mostly stays around 3. Although i've noticed in the last two days it's started reaching back to normal speeds it still drops very frequently (more noticeable while running speed tests). Having two people on VoIP is no doubt becoming a problem.
  • Relatively consistent packet loss + the odd latency spike
Router Status
Here's some data from the hub. I last rebooted yesterday morning. There's a staggering amount of T3 timeouts.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
202750000
1.2
37
256 qam
9
2
138750000
3.5
38
256 qam
1
3
146750000
1.7
38
256 qam
2
4
154750000
0.7
38
256 qam
3
5
162750000
1.2
38
256 qam
4
6
170750000
1.9
38
256 qam
5
7
178750000
2
38
256 qam
6
8
186750000
2.7
38
256 qam
7
9
194750000
2
38
256 qam
8
10
210750000
0.5
38
256 qam
10
11
218750000
-0.2
38
256 qam
11
12
226750000
-0.2
38
256 qam
12
13
234750000
0
38
256 qam
13
14
242750000
-0.5
38
256 qam
14
15
250750000
-1
38
256 qam
15
16
258750000
-1
38
256 qam
16
17
266750000
-0.7
38
256 qam
17
18
274750000
-1.2
38
256 qam
18
19
282750000
-1.4
38
256 qam
19
20
290750000
-1.2
37
256 qam
20
21
298750000
-1.7
38
256 qam
21
22
306750000
-2
38
256 qam
22
23
314750000
-2
37
256 qam
23
24
322750000
-1.7
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.9
16
0
2
Locked
38.6
14
0
3
Locked
38.6
2
0
4
Locked
38.9
160
0
5
Locked
38.9
57
0
6
Locked
38.6
23
0
7
Locked
38.9
10
0
8
Locked
38.6
1
0
9
Locked
38.6
6
0
10
Locked
38.6
12
0
11
Locked
38.6
9
0
12
Locked
38.6
8
0
13
Locked
38.9
13
0
14
Locked
38.6
5
0
15
Locked
38.9
10
0
16
Locked
38.6
12
0
17
Locked
38.6
11
0
18
Locked
38.6
7
0
19
Locked
38.6
32
0
20
Locked
37.6
14
0
21
Locked
38.6
19
0
22
Locked
38.6
9
0
23
Locked
37.6
13
0
24
Locked
38.6
21
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
47.3
5120
64 qam
3
2
32600000
42.8
5120
64 qam
5
3
39400000
44.8
5120
64 qam
4
4
53700000
45.3
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
220
0
4
ATDMA
0
0
0
0
Will post network logs and BQM in another comment (character limit 😅
spudjones
Message 2 of 5
Re: Intermittent connection | known fault
Time
Priority
Description
16/01/2021 16:52:50
critical
16/01/2021 16:52:49
critical
Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 13:55:48
critical
16/01/2021 13:55:47
critical
16/01/2021 11:49:1
critical
16/01/2021 11:48:44
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 05:45:27
critical
15/01/2021 05:42:29
notice
SW download Successful - Via NMS
15/01/2021 05:40:39
notice
SW Download INIT - Via NMS
14/01/2021 17:04:35
critical
14/01/2021 17:03:43
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 17:03:13
Warning!
TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 17:03:13
critical
14/01/2021 07:41:21
critical
14/01/2021 07:41:20
critical
14/01/2021 07:39:48
critical
14/01/2021 07:39:48
critical
14/01/2021 07:09:11
critical
14/01/2021 07:09:11
critical
14/01/2021 05:19:44
critical
BQM
I've been running a BQM the last 24 hours, which certainly maps back to when I've been getting dropouts.
Live BQM Link
Again, I imagine there's not much I can do on my end but would appreciate any insight around the fault. I understand a lot of folks here recommend calling VM at 8:00am. Would that be worthwhile given my current situation? Been learning a ton just by browsing on here, so thank you for that.
gary_dexter
  • 28.88K
  • 1.76K
  • 3.77K
Message 3 of 5
If you are having issues then you either need to call in or wait 5-10 days for a forum rep to reply here.
Also the link to your BQM isn't working.
spudjones
Message 4 of 5
Oops, sorry, BQM link should be working now.
Is 0345 454 1111 the number I should be calling?
Emily_G
  • 4.45K
  • 189
  • 255
Message 5 of 5
Thanks for the post Spudjones and welcome to our community.
We can see there's currently a known area fault that may be affecting your services, I'll pop the information on this below.
Reference: F008720722
Estimated repair time: 22 JAN 2021 12:00
Thanks, Emily.
