timjmottram
Intermittent connection - frequent drops
Hi there,
I have been noticing that I have had regular drops of my internet connection between 5-10 seconds occuring every 20-30 minutes, though it can stretch up to 2 hours between drops.
I run a wired ethernet connection directly to the virgin media modem.
Any help would be greatly appreciated as I've tried the usual - resetting the router, trying different ethernet cables, trying different devices.
Cheers
Tim
I have the following error logs
10/07/2019 10:05:9Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2019 15:07:12ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 08:26:7Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 08:26:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 09:44:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 09:48:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 10:01:45Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 10:46:50ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 13:35:27ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 13:35:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 14:16:41ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 14:27:58ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 14:27:58noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 15:34:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 15:53:15ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 15:53:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 21:09:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 21:43:10Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 21:44:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2019 21:57:9Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
298750000
Locked
Ranged Upstream Channel (Hz)
25799939
Locked
Provisioning State
Online
  • 19.07K
  • 1.67K
  • 4.18K
Re: Intermittent connection - frequent drops
if could copy/paste the downstream and upstream stats
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
timjmottram
1257999394.775512064 qam8
2326000564.775512064 qam7
3393999594.775512064 qam6
4462000214.925512064 qam5
3ATDMA0000
4ATDMA0000
1298750000-3.537256 qam21
2194750000-6.435256 qam8
3202750000-6.435256 qam9
4210750000-4.536256 qam10
5218750000-4.436256 qam11
6226750000-4.936256 qam12
7234750000-6.235256 qam13
8242750000-6.735256 qam14
9250750000-5.236256 qam15
10258750000-536256 qam16
11266750000-4.736256 qam17
12274750000-4.436256 qam18
13282750000-3.437256 qam19
14290750000-3.437256 qam20
15306750000-3.737256 qam22
16314750000-3.537256 qam23
17322750000-3.537256 qam24
18402750000-7.537256 qam25
19410750000-6.537256 qam26
20418750000-6.537256 qam27
21426750000-737256 qam28
22434750000-737256 qam29
23442750000-6.237256 qam30
24450750000-5.937256 qam31
1Locked37.321595999
2Locked35.71216174
3Locked35.71304294
4Locked36.61165511
5Locked36.619331116
6Locked36.330143729
7Locked35.734637009
8Locked35.749538522
9Locked36.646957675
10Locked36.651506190
11Locked36.655444679
12Locked36.6100493105
13Locked37.333143609
14Locked37.323797049
15Locked37.619196005
16Locked37.314212865
17Locked37.613072566
18Locked37.3100870410525
19Locked37.61640559120055
20Locked37.61107415554435886
21Locked37.63347001214078647
22Locked37.37072906711373129
23Locked37.318594320817832502
24Locked37.6716776666643979
  • 19.07K
  • 1.67K
  • 4.18K
Power levels bit on low side, within tolerances, snr is fine.. Something a miss on last few downstreams causing all those post-rs, this would require further investigation by calling support or waiting a few days for forum staff to check things over
timjmottram
Ok, thank you for your help. Hopefully a staff member will get in touch
  • 979
  • 46
  • 87
Forum Team (Retired) Tom_S
Hi timjmottram, welcome to our forums.
I can see that you're experiencing issues with the services at the moment.
I'm going to drop you a PM so we can look into it for you.
Tom_S
