on 27-09-2022 11:48
Hi there,
I'm struggling to resolve an issue with my broadband connection where on a frequent basis it drops out. A few key points:
Thanks for any help provided!
on 27-09-2022 14:13
on 28-09-2022 10:52
Many thanks for your reply and support. In response to your questions:
Therefore I'm not arriving at an easy resolution to my problem. I guess I was hoping a VM employee would do some checks in the background upon seeing this post and they'd say they've seen an issue in my area or something, like they've done on many other posts. Other than that, I'm a bit at a loss as to what I can do other than put up with it until I can switch back to my old provider where I never had service issues like this.
on 28-09-2022 21:08
on 01-10-2022 09:40
Hi Seand1, welcome to the community! Thank you for posting!
Sorry to hear you have been experiencing connection issues.
Having had a look on our systems there have been no drop outs on your hub in the last week or so, however there were quite a few earlier on in the month.
There aren't any issues with the signals at the exchange or those reaching your hub currently.
As you mentioned the issue primarily happening when in video conferencing it would be good to check:
-Are you using a VPN?
-Have you experienced the issue across multiple devices?
-Does this also happen if you connect the device via Ethernet cable? (Just let us know if this is not possible to test).
-Are you using any devices via a wired connection where the drop-outs occur?
-Is there any noticeable pattern to the drop-outs? (Eg are they happening at the same time each day)?
I understand you have your own Wi-Fi booster set up, however if you would like to scan your home for Wi-Fi coverage issues you can do so using our Connect app. If you need help to use this here's a handy support article: https://virg.in/conhelp.
If you can also try some of the troubleshooting steps advised by Jbrennard, this may help identify or resolve the issue for you in the meantime!
Let us know how you get on and we will offer further support!
All the best.
