on 08-12-2022 12:59
Since I've joined in ~June, I have unstable connection. It seems works kind of ok, but during the day I have few seconds connection drops. It sounds as not a big deal, but affects me significantly especially when I am on a video call or similar.
I've had 5 or so engineer visits already, they have replaced all possible connectors and wires in the house. but it seems does not help. For couple few months I have permanent "issues in your postcode affecting your services", I've called technical support several times, they usually promise fix by tomorrow or so but there is no any progress in the fixing the issue. I have BQM installed:
on 08-12-2022 13:00
Some stats from my router
1 | 331000000 | 6.3 | 40 | 256 qam | 25 |
2 | 203000000 | 6.6 | 40 | 256 qam | 9 |
3 | 211000000 | 6.5 | 40 | 256 qam | 10 |
4 | 219000000 | 6 | 40 | 256 qam | 11 |
5 | 227000000 | 5.8 | 38 | 256 qam | 12 |
6 | 235000000 | 5.8 | 38 | 256 qam | 13 |
7 | 243000000 | 5.5 | 38 | 256 qam | 14 |
8 | 251000000 | 5.4 | 40 | 256 qam | 15 |
9 | 259000000 | 5.5 | 38 | 256 qam | 16 |
10 | 267000000 | 5.8 | 38 | 256 qam | 17 |
11 | 275000000 | 5.8 | 40 | 256 qam | 18 |
12 | 283000000 | 6 | 40 | 256 qam | 19 |
13 | 291000000 | 6.1 | 38 | 256 qam | 20 |
14 | 299000000 | 6.8 | 38 | 256 qam | 21 |
15 | 307000000 | 6.5 | 40 | 256 qam | 22 |
16 | 315000000 | 6.4 | 40 | 256 qam | 23 |
17 | 323000000 | 6.3 | 38 | 256 qam | 24 |
18 | 339000000 | 6.1 | 40 | 256 qam | 26 |
19 | 347000000 | 5.9 | 40 | 256 qam | 27 |
20 | 355000000 | 5.9 | 40 | 256 qam | 28 |
21 | 363000000 | 5.6 | 40 | 256 qam | 29 |
22 | 371000000 | 5.5 | 40 | 256 qam | 30 |
23 | 379000000 | 5.4 | 40 | 256 qam | 31 |
24 | 387000000 | 5.6 | 40 | 256 qam | 32 |
1 | Locked | 40.3 | 13263 | 994 |
2 | Locked | 40.3 | 20664 | 3149 |
3 | Locked | 40.3 | 20796 | 4583 |
4 | Locked | 40.3 | 20911 | 5306 |
5 | Locked | 38.9 | 21341 | 5077 |
6 | Locked | 38.9 | 20720 | 3722 |
7 | Locked | 38.9 | 20237 | 3299 |
8 | Locked | 40.3 | 20742 | 3544 |
9 | Locked | 38.9 | 21433 | 3956 |
10 | Locked | 38.9 | 21749 | 4127 |
11 | Locked | 40.3 | 22000 | 3452 |
12 | Locked | 40.3 | 21599 | 2432 |
13 | Locked | 38.9 | 19704 | 1482 |
14 | Locked | 38.9 | 16744 | 1080 |
15 | Locked | 40.9 | 12986 | 1052 |
16 | Locked | 40.3 | 12037 | 979 |
17 | Locked | 38.9 | 12269 | 1014 |
18 | Locked | 40.3 | 13170 | 888 |
19 | Locked | 40.3 | 10302 | 919 |
20 | Locked | 40.3 | 7145 | 865 |
21 | Locked | 40.3 | 4276 | 809 |
22 | Locked | 40.3 | 3577 | 832 |
23 | Locked | 40.3 | 3375 | 810 |
24 | Locked | 40.9 | 2449 | 824 |
1 | 49600000 | 35.5 | 5120 | 64 qam | 1 |
2 | 36600000 | 34.5 | 5120 | 64 qam | 3 |
3 | 43100000 | 35.3 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 3 | 0 |
on 08-12-2022 13:01
08/12/2022 12:55:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:55:6 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:54:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:54:46 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:53:58 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:53:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:53:26 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:53:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:53:6 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:51:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:51:46 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:51:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:51:26 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:50:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:50:6 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:49:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:49:46 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:48:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:48:26 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/12/2022 12:48:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 12-12-2022 09:00
Hi kan-izh,
Thank you for reaching out to us in our community and welcome, really sorry to see you have been facing intermittent drops in your connection, although the drops only lasted seconds it is effecting you when making Video calls ETC.
I was able to locate you on our system with the details we have for you, after running further checks I can see there is an SNR (Signal to Noise Ratio) fault in your area, this is generally caused by an exposed or faulty connection causing noise on the Network, these can be quite tricky to locate and once found doees usually required works doing which we have to wait for permits from the local Council.
You might find that your Virgin Fibre, Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then. We are sorry and our engineers are working hard to resolve this ASAP.
This was raised on 23/10/22 which coincides from when you started facing issues, the estimated fix time is Today 12/12/22 @15:00 however this can change.
Paul.
on 06-01-2023 11:01
The issue seems was not fixed yet. Yesterday and today is especially bad.
on 09-01-2023 10:34
Thanks for your reply @kan-izh, sorry to see that this has still not been resolved.
I have checked for an update on the SNR issue and it seems like the estimated fix time is now today at 3pm. As the times are estimates only, they can change depending on the complexity of the issue.
If you need any further updates, please let us know. We will be happy to assist.
Nathan
on 10-01-2023 22:03
Was anything actually fixed? I still see "Looks like there are issues in your postcode affecting your services", timeouts and errors in logs.
on 10-01-2023 23:29
Hi .I am having issue with broadband .I am not getting internet on my house .I am having a trouble to get the signal intermittently in my hub 4 .Engineer visit three times and changed the hub .Now I have a problem again today same no internet connectivity in my hub 4.I rang Virgin media and they book the engineer.It’s quite frustrating.I don’t no what to do .Please give me advice.
on 11-01-2023 12:24
on 13-01-2023 12:28
Hi @kan-izh thanks for your reply, sorry you're still having issues.
It does look like this is still ongoing unfortunately, the latest info is that it's due to be fixed Jan 16th @ 15:00.
If this is happening after this time, please let us know.
Many thanks
