14-09-2020 11:15 - edited 14-09-2020 11:19
I'm working from home full time and I am thinking of switching to another broadband provider, since I've called an engineer and apart from changing the cable, all the issues still remain.
My internet connection keeps dropping for 5-10 secs and then is coming back. For me working from home means that this behaviour is very disruptive and enough for kicking me out of a meeting or ruin a presentation.
Posting a message here, hoping that someone will actually investigate the problem is the last move before I switch to another provider.
Answered! Go to Answer
on 14-09-2020 17:43
If you notice the chart, there have already been 2 disruption, meaning that I was kicked out from my Zoom calls and had to wait about a min to reconnect again.
on 14-09-2020 17:52
It looks like a problem on the WAN side of the Hub.
Keep your >> BQM << running.
You can contact VM to report the problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
on 16-09-2020 23:23
Hi. It’s been 3 days. I haven’t had an answer from the text service (they claim they forward my texts to the appropriate team) but it never goes through.
I also haven’t been able to go through in the 0345 telephone line.
could you please advise what are the steps to cancel my subscription? And imagine I was planning to upgrade. 🙂
on 17-09-2020 14:28
Hi agis_k,
Thanks for posting.
I'm sorry you're experiencing drops in your connection whilst working from home. I completely understand that you need a stable connection to be able to do your job properly.
I've had a look at your services and I can see that you've got a prolonged stability issue which is going to need a technician visit to fix.
I know you've mentioned in your last post that you're looking to cancel, so I wanted to check if that's still the case?
I'm happy to get you a technician visit booked, but if you're looking to cancel then you would need to contact the team on the number listed above, as we're not able to help with that from here.
Let me know either way.
Melissa
on 17-09-2020 15:14
Hi Melissa
Provided that my issue is fixed, I will be looking at upgrading soon but I need to have a stable service first.
So I would appreciate if you could send a technician to see what's going on.
Agis
on 17-09-2020 15:28
Thanks for letting me know.
I've booked you in for our next available technician appointment and you can see the details of this via your online account. You can also reschedule it if you need to.
I hope that's okay?
Let me know how it goes.
Melissa
on 17-09-2020 15:32
Thank you Melissa.
I'll let you know in a few days (will be keeping an eye on my BQM).
Agis
on 17-09-2020 15:52
Great thanks Agis.
I look forward to hearing from you 🙂
Melissa
on 18-09-2020 16:19
OK. A quick update.
A technician came earlier today and said that it is probably a Hub issue, so he replaced the hub.
Have created a new BQM to track the performance.
>>>>>>>>>>> BQM for the new router >>>>>>>>>>>>>>>>>>
Fingers crossed it'll go well.
on 20-09-2021 12:01
Hi Virgin Media team and
It seems like my previous problems are back.
Please see my BQM chart and here are my logs from my router:
1 | 699000000 | 1.7 | 38 | 256 qam | 33 |
2 | 491000000 | 2.5 | 38 | 256 qam | 11 |
3 | 499000000 | 2 | 38 | 256 qam | 12 |
4 | 507000000 | 2 | 38 | 256 qam | 13 |
5 | 515000000 | 1.7 | 38 | 256 qam | 14 |
6 | 523000000 | 2.2 | 38 | 256 qam | 15 |
7 | 531000000 | 2.2 | 38 | 256 qam | 16 |
8 | 539000000 | 2.2 | 38 | 256 qam | 17 |
9 | 547000000 | 2.5 | 38 | 256 qam | 18 |
10 | 555000000 | 2 | 38 | 256 qam | 19 |
11 | 563000000 | 1.9 | 38 | 256 qam | 20 |
12 | 571000000 | 1 | 38 | 256 qam | 21 |
13 | 579000000 | 1.4 | 38 | 256 qam | 22 |
14 | 587000000 | 1.2 | 38 | 256 qam | 23 |
15 | 595000000 | 1.5 | 38 | 256 qam | 24 |
16 | 603000000 | 1.7 | 38 | 256 qam | 25 |
17 | 611000000 | 1.5 | 38 | 256 qam | 26 |
18 | 619000000 | 1.9 | 38 | 256 qam | 27 |
19 | 627000000 | 1.5 | 38 | 256 qam | 28 |
20 | 635000000 | 1.5 | 38 | 256 qam | 29 |
21 | 643000000 | 1 | 38 | 256 qam | 30 |
22 | 651000000 | 1 | 38 | 256 qam | 31 |
23 | 659000000 | 0.7 | 38 | 256 qam | 32 |
24 | 707000000 | 1 | 38 | 256 qam | 34 |
1 | Locked | 38.6 | 299 | 1586 |
2 | Locked | 38.9 | 355 | 1783 |
3 | Locked | 38.6 | 354 | 1995 |
4 | Locked | 38.9 | 396 | 2041 |
5 | Locked | 38.6 | 399 | 2200 |
6 | Locked | 38.9 | 329 | 1890 |
7 | Locked | 38.9 | 370 | 1880 |
8 | Locked | 38.9 | 349 | 2192 |
9 | Locked | 38.9 | 347 | 1887 |
10 | Locked | 38.9 | 358 | 1741 |
11 | Locked | 38.9 | 353 | 1649 |
12 | Locked | 38.6 | 373 | 1904 |
13 | Locked | 38.6 | 436 | 2158 |
14 | Locked | 38.9 | 374 | 1721 |
15 | Locked | 38.9 | 355 | 1554 |
16 | Locked | 38.6 | 383 | 1732 |
17 | Locked | 38.6 | 402 | 1499 |
18 | Locked | 38.6 | 348 | 1558 |
19 | Locked | 38.9 | 394 | 1524 |
20 | Locked | 38.9 | 352 | 1554 |
21 | Locked | 38.6 | 488 | 1577 |
22 | Locked | 38.9 | 439 | 1403 |
23 | Locked | 38.9 | 472 | 1644 |
24 | Locked | 38.9 | 394 | 1399 |
1 | 25800000 | 47 | 5120 | 64 qam | 6 |
2 | 32600000 | 46.5 | 5120 | 64 qam | 5 |
3 | 39400000 | 47 | 5120 | 64 qam | 4 |
4 | 46200000 | 47.5 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 45 | 0 |
2 | ATDMA | 0 | 0 | 22 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
20/09/2021 10:54:31 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 10:40:54 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 10:40:54 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 10:18:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 10:18:16 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 10:14:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 10:14:36 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 10:13:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 10:13:16 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 08:36:17 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:10:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:10:39 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:09:20 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:09:19 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:08:0 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:08:0 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:06:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:06:40 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:05:20 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/09/2021 06:05:20 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
I hope someone picks up to help me resolve the issue. Thanks
