  • 8
John_P1
Message 1 of 14
Intermittent broadband connection; Connected no internet
Hi all,
As titled my WiFi/broadband connection (I also test with Ethernet cables) intermittently stops working, often stating "connected, no internet" or the like.
I've read through the forum posts of people who have had similar issues, and tried all of the various techniques I could find: hold reset for 1 minute, checked cables, run service checks (which state there are no issues) etc.
Just today the connection has cut out 5 times in one hour, and this is not the first day this has occurred.
Thanks in advance.
  • 6.23K
  • 481
  • 1.03K
Hero
Message 2 of 14
Re: Intermittent broadband connection; Connected no internet
Please go into your hub on 192.168.0.1 and post your up/downstream stats and network log.
  • 8
John_P1
Message 3 of 14
Thanks for the response.
I've gotten this far and checked the available links, but can't figure out where the required data is.Screenshot_20190724-130315.png
  • 9.43K
  • 978
  • 1.48K
Message 4 of 14
. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before] click on the “router status” icon at top right (SH2’s) or the text at bottom-middle of first page up (Hub3) and then copy/paste 3 FULL sets of data onto here – from the downstream, upstream, & network logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you.
  • 8
John_P1
Message 5 of 14
There doesn't seem to be either a "router status" icon in the top right or text at the bottom middle available to click on.
  • 9.43K
  • 978
  • 1.48K
Message 6 of 14
What Hub is it ?  That probably means that you have never logged on to the Hub before. So log on - change a password if you like, then save changes, log off and then try again.
  • 8
John_P1
Message 7 of 14
I've just logged out and back in again (twice), and I'm still getting the same page I had before.
I believe I've just found the info you're after. I clicked on "Tools" on the left hand side of the page and then "Network Status". I'm currently working off of a mobile and copy and pasting the data may prove troublesome. So I'm going to wait for a clear patch in my WiFi so I can use my laptop.
  • 8
John_P1
Message 8 of 14
... and it's a hub 3. Sorry forgot to put that in my initial response.
And I've just figured out I could've edited that response instead of sending a new message.
  • 8
John_P1
Message 9 of 14
1 323000000 -1.7 38 256 qam 24
2 139000000 -1 38 256 qam 1
3 147000000 0.2 38 256 qam 2
4 155000000 -0.4 38 256 qam 3
5 163000000 -1.5 38 256 qam 4
6 171000000 0 38 256 qam 5
7 179000000 -0.5 38 256 qam 6
8 187000000 -1.4 38 256 qam 7
9 195000000 -0.4 38 256 qam 8
10 203000000 -0.7 38 256 qam 9
11 211000000 -1.5 38 256 qam 10
12 219000000 -0.5 40 256 qam 11
13 227000000 -1 38 256 qam 12
14 235000000 -1.5 38 256 qam 13
15 243000000 -1.2 40 256 qam 14
16 251000000 -1.9 38 256 qam 15
17 259000000 -1.7 38 256 qam 16
18 267000000 -1.2 40 256 qam 17
19 275000000 -2 38 256 qam 18
20 283000000 -2.2 38 256 qam 19
21 291000000 -1.2 40 256 qam 20
22 299000000 -1.4 38 256 qam 21
23 307000000 -1 38 256 qam 22
24 315000000 -0.9 40 256 qam 23
1 Locked 38.6 212 800
2 Locked 38.9 13326 3158
3 Locked 38.6 2658 746
4 Locked 38.6 6301 1158
5 Locked 38.6 15038 1189
6 Locked 38.9 1842 852
7 Locked 38.9 13583 4408
8 Locked 38.6 11260 913
9 Locked 38.9 2058 456
10 Locked 38.9 1517 464
11 Locked 38.9 582 64
12 Locked 40.3 358 433
13 Locked 38.9 894 602
14 Locked 38.6 2673 106
15 Locked 38.9 2903 712
16 Locked 38.6 1090 539
17 Locked 38.9 334 43
18 Locked 40.3 642 106
19 Locked 38.6 1074 422
20 Locked 38.6 604 65
21 Locked 40.3 512 335
22 Locked 38.6 1343 173
23 Locked 38.6 1189 159
24 Locked 40.9 707 452
1 60300000 4.975 5120 64 qam 1
2 53700000 5.05 5120 64 qam 2
3 46200000 4.925 5120 64 qam 3
4 39400000 4.875 5120 64 qam 4
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
24/07/2019 11:44:33 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 11:52:24 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 11:53:13 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 11:56:9 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:07:29 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:07:29 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:34:21 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:34:41 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:34:41 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:44:35 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:45:19 critical Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:45:19 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:45:19 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:45:39 critical Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:45:39 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:49:19 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:50:15 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:51:2 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 12:51:2 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2019 13:05:6 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 9.43K
  • 978
  • 1.48K
Message 10 of 14
Needs a superuser to comment - but the logs dont look good with a lot of T3's in a short space of time. Updstream power levels are high too - but may be ok.
Looks as if you will need a technician's visit.
