on 13-01-2023 11:25
Hi all,
I have been experiencing intermittent dropouts of my works software VPN for a few months now (up to 10 times a day - really annoying). At first I thought it was related to my home network, but have ruled that out by connecting straight into my router (TP-Link). My Virgin Hub4 is in modem mode. Anyway, following advice on this forum I have setup the Think Broadband Quality Monitor - here is a pic of my graph:
The VPN dropouts seem to sometimes coincide with the dropped packets seen in the graph.
The stats from my Hub4 are as follows - would appreciate it if anybody's who knows how to interpret this data could give me a steer please! Many thanks
4 | 387000000 | -1.8 | 39 | QAM256 | 4 |
1 | 363000000 | -0.8 | 39 | QAM256 | 1 |
2 | 371000000 | -2 | 38.6 | QAM256 | 2 |
3 | 379000000 | -2 | 39 | QAM256 | 3 |
5 | 395000000 | -2.3 | 39 | QAM256 | 5 |
6 | 403000000 | -2.6 | 39 | QAM256 | 6 |
7 | 411000000 | -2.5 | 38.6 | QAM256 | 7 |
8 | 419000000 | -2.2 | 39 | QAM256 | 8 |
9 | 427000000 | -2.2 | 39 | QAM256 | 9 |
10 | 435000000 | -2.3 | 38.6 | QAM256 | 10 |
11 | 443000000 | -2.4 | 40.4 | QAM256 | 11 |
12 | 451000000 | -2.2 | 40.4 | QAM256 | 12 |
13 | 459000000 | -2.2 | 39 | QAM256 | 13 |
14 | 467000000 | -2.3 | 40.4 | QAM256 | 14 |
15 | 475000000 | -2 | 39 | QAM256 | 15 |
16 | 483000000 | -1.6 | 39 | QAM256 | 16 |
17 | 491000000 | -1.6 | 40.4 | QAM256 | 17 |
18 | 499000000 | -1.7 | 40.4 | QAM256 | 18 |
19 | 507000000 | -2 | 40.4 | QAM256 | 19 |
20 | 515000000 | -1.9 | 40.4 | QAM256 | 20 |
21 | 523000000 | -1.8 | 40.4 | QAM256 | 21 |
22 | 531000000 | -1.8 | 40.4 | QAM256 | 22 |
23 | 539000000 | -1.7 | 40.4 | QAM256 | 23 |
24 | 547000000 | -1.5 | 40.4 | QAM256 | 24 |
25 | 555000000 | -1.3 | 40.4 | QAM256 | 25 |
26 | 563000000 | -1.3 | 40.4 | QAM256 | 26 |
27 | 571000000 | -1.8 | 40.4 | QAM256 | 27 |
28 | 579000000 | -3 | 39 | QAM256 | 28 |
29 | 587000000 | -3.3 | 39 | QAM256 | 29 |
30 | 595000000 | -2.8 | 39 | QAM256 | 30 |
31 | 603000000 | -2.3 | 40.4 | QAM256 | 31 |
4 | Locked | 38.983261 | 1 | 0 |
1 | Locked | 38.983261 | 0 | 0 |
2 | Locked | 38.605377 | 1 | 0 |
3 | Locked | 38.983261 | 0 | 0 |
5 | Locked | 38.983261 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 38.605377 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.605377 | 1 | 0 |
11 | Locked | 40.366287 | 1 | 0 |
12 | Locked | 40.366287 | 1 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 40.366287 | 1 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 1 | 0 |
17 | Locked | 40.366287 | 2 | 0 |
18 | Locked | 40.366287 | 1 | 0 |
19 | Locked | 40.366287 | 3 | 0 |
20 | Locked | 40.366287 | 1 | 0 |
21 | Locked | 40.366287 | 2 | 0 |
22 | Locked | 40.366287 | 1 | 0 |
23 | Locked | 40.366287 | 4 | 0 |
24 | Locked | 40.366287 | 3 | 0 |
25 | Locked | 40.366287 | 3 | 0 |
26 | Locked | 40.366287 | 3 | 0 |
27 | Locked | 40.366287 | 1 | 0 |
28 | Locked | 38.983261 | 6 | 0 |
29 | Locked | 38.983261 | 8 | 0 |
30 | Locked | 38.983261 | 5 | 0 |
31 | Locked | 40.366287 | 9 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 41 | -5.7 | 27032875 | 27 |
1 | 36600000 | 44 | 5120 KSym/sec | 64QAM | 11 |
2 | 23600000 | 43 | 5120 KSym/sec | 64QAM | 13 |
3 | 30100000 | 43 | 5120 KSym/sec | 64QAM | 12 |
4 | 43100000 | 45 | 5120 KSym/sec | 64QAM | 10 |
5 | 49600000 | 45.5 | 5120 KSym/sec | 64QAM | 9 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 2 | 0 |
14 | 10.0 | 40.8 | 2K | QAM8 |
14 | OFDMA | 200 | 53.9 | 1 | 0 |
Answered! Go to Answer
on 01-02-2023 10:55
Hi All,
I thought I would just update this post to say I got the issue resolved in the end. A Virgin Engineer visited my home and agreed that the packet loss spikes did not seem right. He also noticed my downstream signal strength was too low. After visiting the cab at the end of my street he noticed that the connector on that end looked degraded and old. He replaced it and my connection had been stable since. All in all he was very helpful and I'm pleased with the service I received.
Thanks for everyone's help and input into getting this resolved!
on 13-01-2023 15:06
on 13-01-2023 15:31
Hi John,
Thanks for the reply. The Hub's light is a solid dim white and is definitely in modem mode:
The router is a TP-Link Archer AX23. I actually got it to see if it would sort this issue out, but it has not helped.
Many thanks
on 14-01-2023 01:14
on 16-01-2023 09:12
Hi there @aweaire
Thank you so much for your post and welcome to the community forums, its great to have you here.
I am so sorry to hear that you have faced these issues with your connection, I'd be happy to take a look into things from our side however as @legacy1 has stated I would need the Hub to be in router mode in order for me to make checks.
Are you able to change this over so we can run diagnostics, you can then pop it back to modem mode?
on 16-01-2023 09:38
Hi Ashleigh,
Thanks for the response. I will do this (hopefully later today) and will let you know when it's done.
on 16-01-2023 13:47
Hi Ashleigh,
My Hub4 back in router mode now.
Thanks.
on 16-01-2023 20:28
curious what you find out, I have exact same packet drops after upgraded to TG3492LG-VMIE hub, exactly every 60 minutes, 3 seconds drop out.
on 17-01-2023 12:21
Yesterday at 10pm I went through all menus again, but the only option I changed was to disable DMZ. And after that, no more issue. However, I have no idea if it was in fact DMZ setting causing this, I dare not to touch anything now.
on 17-01-2023 16:20
Hi Schriss,
My connection has been better today also. I have not made any changes since switching back to router mode. I did experience some dropped packets after switching back however (at approx. 2pm) - so not sure the switching back is related:
Maybe Virgin have made a change?
Thanks.
