on 04-08-2021 21:41
Hi there!
Cardiff based Virgin Customer
Similar to a few people I have read on here I am having massive trouble with the intermittent Internet issue, thought it was my network so tried resetting and rebooting all that then when interrogating the hub I saw the error logs on the Super Hub 3. I have tried reboots etc
Critical and warnings every few mins. I have posted the text below but was advised to blank out the MAC addresses.
critical SYNC Timing Synchronisation failure and Warning RCS Partial Service.
It was working great but has now been unusable for well over a week, I work from home and need to get to the bottom of this ASAP please.
Cheers!
text of hub log below:
04/08/2021 21:07:38 | notice | LAN login Success;CM-MAC=xxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:03:53 | Warning! | RCS Partial Service;CM-MAC=xxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:03:34 | Warning! | Lost MDD Timeout;CM-MAC=xxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:03:33 | Warning! | RCS Partial Service;CM-MAC=xxxxxxxxx;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:03:33 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xxxxxxxxxx;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:02:37 | Warning! | RCS Partial Service;CM-MAC=xxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:01:58 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:01:43 | Warning! | RCS Partial Service;CM-MAC=xxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:01:43 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xxxxxxxxxxxxx;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:00:10 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 21:00:9 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0 |
on 04-08-2021 21:54
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
if its an earlier hub button is top right
on 05-08-2021 13:20
Hi Tony
see below downstream and upstream figures covering the same period
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 203000000 | 6.9 | 40 | 256 qam | 9 |
2 | 211000000 | 6.5 | 40 | 256 qam | 10 |
3 | 219000000 | 6.4 | 40 | 256 qam | 11 |
4 | 227000000 | 6.1 | 40 | 256 qam | 12 |
5 | 235000000 | 5.9 | 40 | 256 qam | 13 |
6 | 243000000 | 5.8 | 40 | 256 qam | 14 |
7 | 251000000 | 6 | 40 | 256 qam | 15 |
8 | 259000000 | 6 | 40 | 256 qam | 16 |
9 | 267000000 | 6 | 40 | 256 qam | 17 |
10 | 275000000 | 6 | 40 | 256 qam | 18 |
11 | 283000000 | 6 | 40 | 256 qam | 19 |
12 | 291000000 | 6 | 40 | 256 qam | 20 |
13 | 299000000 | 6 | 40 | 256 qam | 21 |
14 | 307000000 | 6 | 40 | 256 qam | 22 |
15 | 315000000 | 6.1 | 40 | 256 qam | 23 |
16 | 323000000 | 6.1 | 40 | 256 qam | 24 |
17 | 331000000 | 6.3 | 40 | 256 qam | 25 |
18 | 371000000 | 5 | 40 | 256 qam | 26 |
19 | 379000000 | 5 | 40 | 256 qam | 27 |
20 | 387000000 | 4.8 | 40 | 256 qam | 28 |
21 | 395000000 | 4.8 | 40 | 256 qam | 29 |
22 | 403000000 | 4.8 | 40 | 256 qam | 30 |
23 | 411000000 | 5 | 40 | 256 qam | 31 |
24 | 419000000 | 4.9 | 40 | 256 qam | 32 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 40.9 | 492 | 6571 |
2 | Locked | 40.3 | 521 | 5784 |
3 | Locked | 40.3 | 512 | 6428 |
4 | Locked | 40.3 | 466 | 7813 |
5 | Locked | 40.3 | 508 | 7072 |
6 | Locked | 40.3 | 487 | 7011 |
7 | Locked | 40.9 | 534 | 6495 |
8 | Locked | 40.3 | 537 | 7271 |
9 | Locked | 40.3 | 485 | 6952 |
10 | Locked | 40.3 | 496 | 6937 |
11 | Locked | 40.3 | 503 | 6696 |
12 | Locked | 40.3 | 488 | 6721 |
13 | Locked | 40.3 | 564 | 6874 |
14 | Locked | 40.3 | 588 | 7144 |
15 | Locked | 40.3 | 521 | 6793 |
16 | Locked | 40.3 | 471 | 6596 |
17 | Locked | 40.9 | 486 | 6862 |
18 | Locked | 40.3 | 510 | 6772 |
19 | Locked | 40.3 | 508 | 7164 |
20 | Locked | 40.3 | 451 | 6615 |
21 | Locked | 40.3 | 542 | 7623 |
22 | Locked | 40.3 | 431 | 7490 |
23 | Locked | 40.3 | 466 | 6291 |
24 | Locked | 40.3 | 486 | 7509 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 32600000 | 43.5 | 5120 | 64 qam | 5 |
2 | 46200000 | 45 | 5120 | 64 qam | 3 |
3 | 39400000 | 44 | 5120 | 64 qam | 4 |
4 | 53700000 | 45 | 5120 | 64 qam | 2 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 06-08-2021 18:05
Hi, any updates please
thanks
on 06-08-2021 18:20
levels are generally good - some noise on the line [maybe] do a restart to zero the pre and post rs errors and see if they rise again
how is it unusable at times - wired or wifi
on 06-08-2021 20:55
It’s wifi and wired, the connection drops out constantly, every few mins, then it comes back for a min or two then off again, speed tests performed while it’s on show a good strength but 2 mins later there is nothing again, actually dropped out while typing this reply so this is the 2nd time I have typed this 😞
what’s the best advise to fix this, the customer service line just say reboot/reset and wait 24 h which I have now done a hat full of time. How do I get to talk to someone who will actually do something??
thanks
on 09-08-2021 08:53
Hi Batos2000.
Thanks for posting and welcome to the community. My apologies for the broadband issues.
I've ran a check here and it says the following;
There is a very short term connectivity issue which may cause intermittent or performance related issues with the customer's connection.
We believe that the issue is only impacting their connection but it'll only be a very short term issue and their connection will return to normal very soon. It further asks me to get you to check all the white cables are connected securely to the Hub, any TV boxes, splitters and the wall socket.
Best,
