on 03-08-2021 23:11
Hi there!
Seen a few people with the intermittent Internet issue, thought it was my network until I saw the error logs on the Super Hub 3
This kind of stuff again
03/08/2021 22:07:50 critical SYNC Timing Synchronization failure - Loss of Sync;
Any idea if it can be fixed remotely? It was working great until about 2 weeks ago.
Cheers!
on 04-08-2021 06:32
Network logs are always full of sinister looking warnings, and even the odd "critical" error is normal. Repeated critical errors are not normal, and Partial Service is something you wouldn't want to see with any frequency.
The likely causes of a poor performance are noise or power level problems, and those can't be fixed remotely. You can phone up and take your chances with the grim offshore support, personally I'd rely on this forum. The only measures within your grasp are checking the coax lead into the hub is properly fixed and the securing nuts are finger tight, a simple reboot that you've probably already tried, and a pinhole reset that clears the hubs settings and reloads the firmware.
If those haven't worked then (after the hub has been running continuously for a good few hours since last restart, ideally 24 hours), connect to the hub by clicking on this link http://192.168.0.1/ (I'm assuming the hub is in normal router mode). That should pull up the log in page for the hub. But don't log in, just click on the link "Check router status" That'll bring up a window with five tabs. Open the Downstream tab. Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots. Post that, do the same for the Upstream and Network log. You'll get an error message when you post the Network log, just click on "post" a second time.
Then we can check for any obvious problems with power, noise or error counts. If those are visible the staff here can book you a technician visit.
on 04-08-2021 11:55
Hi Andrew,
Cheers for the reply, been having Critical's for a while now, SuperHub3 is in Modem mode as... ehh... would rather have a Router with a bit more BEEF than the stock one so it's in Modem mode.
1 | 202750000 | -0.5 | 38 | 256 qam | 9 |
2 | 138750000 | 1 | 38 | 256 qam | 1 |
3 | 146750000 | 0.7 | 38 | 256 qam | 2 |
4 | 154750000 | 0.4 | 37 | 256 qam | 3 |
5 | 162750000 | 0.2 | 38 | 256 qam | 4 |
6 | 170750000 | 0.2 | 37 | 256 qam | 5 |
7 | 178750000 | 0 | 37 | 256 qam | 6 |
8 | 186750000 | 0 | 37 | 256 qam | 7 |
9 | 194750000 | -0.2 | 38 | 256 qam | 8 |
10 | 210750000 | -0.5 | 38 | 256 qam | 10 |
11 | 218750000 | -0.4 | 38 | 256 qam | 11 |
12 | 226750000 | -0.5 | 38 | 256 qam | 12 |
13 | 234750000 | -0.5 | 38 | 256 qam | 13 |
14 | 242750000 | -0.5 | 38 | 256 qam | 14 |
15 | 250750000 | -0.7 | 38 | 256 qam | 15 |
16 | 258750000 | -0.7 | 38 | 256 qam | 16 |
17 | 266750000 | -0.4 | 38 | 256 qam | 17 |
18 | 274750000 | 0 | 38 | 256 qam | 18 |
19 | 282750000 | 0.4 | 38 | 256 qam | 19 |
20 | 290750000 | 0.4 | 38 | 256 qam | 20 |
21 | 298750000 | 0.5 | 38 | 256 qam | 21 |
22 | 306750000 | 0.4 | 38 | 256 qam | 22 |
23 | 314750000 | 0.4 | 38 | 256 qam | 23 |
24 | 322750000 | 0.5 | 38 | 256 qam | 24 |
1 | Locked | 38.6 | 1171923 | 685319 |
2 | Locked | 38.6 | 6180835 | 2831054 |
3 | Locked | 38.6 | 2057137 | 1322727 |
4 | Locked | 37.3 | 4605018 | 1696057 |
5 | Locked | 38.6 | 7099672 | 3245066 |
6 | Locked | 37.6 | 1501804 | 1088627 |
7 | Locked | 37.6 | 6925151 | 2980284 |
8 | Locked | 37.6 | 4656309 | 1586541 |
9 | Locked | 38.9 | 1242065 | 752257 |
10 | Locked | 38.6 | 1118347 | 654521 |
11 | Locked | 38.6 | 1085075 | 631606 |
12 | Locked | 38.6 | 1095507 | 606803 |
13 | Locked | 38.9 | 1105161 | 600496 |
14 | Locked | 38.6 | 1012441 | 530949 |
15 | Locked | 38.6 | 932333 | 459274 |
16 | Locked | 38.6 | 933323 | 455517 |
17 | Locked | 38.6 | 980246 | 477599 |
18 | Locked | 38.9 | 911852 | 448762 |
19 | Locked | 38.9 | 774274 | 365796 |
20 | Locked | 38.6 | 733103 | 329457 |
21 | Locked | 38.6 | 769829 | 339227 |
22 | Locked | 38.9 | 711073 | 313264 |
23 | Locked | 38.9 | 654934 | 298110 |
24 | Locked | 38.6 | 620688 | 292896 |
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1 | 53700137 | 43.8 | 5120 | 64 qam | 2 |
2 | 39400044 | 43.8 | 5120 | 64 qam | 4 |
3 | 46200010 | 43.3 | 5120 | 64 qam | 3 |
4 | 60300000 | 44.8 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 43 | 0 |
2 | ATDMA | 0 | 0 | 143 | 0 |
3 | ATDMA | 0 | 0 | 141 | 0 |
4 | ATDMA | 0 | 0 | 144 | 0 |
Aye heard that phone support can be abit iffy, so the forum is the happenin' place to be for all the cool cats. Done all the Coax stuff, reboots (was even convinced by Router was on the way out until I heard about the Network logs on the SuperHub3).
Will post the Network logs in another post
on 04-08-2021 11:56
04/08/2021 10:48:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:48:41 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:45:7 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:44:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:44:22 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:44:19 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:43:30 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:43:30 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:43:29 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:43:11 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:43:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:42:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:35:48 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:35:34 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:35:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:35:31 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:32:0 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:31:42 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:31:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 10:31:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 04-08-2021 17:12
That's the telecoms equivalent of the London Dungeon. How long since the hub last had a reboot? There's an "uptime" counter in the hub's admin pages if you can't recall.
on 04-08-2021 20:53
16 days, so this issue has been with me longer than 2 weeks, as I've rebooted everything since it started happening.
Guessing another reboot is in my future, hopefully this latest one will work as there has been work in the area in the last 2 days.
on 04-08-2021 22:10
Still popping up it seems sadly.
04/08/2021 21:07:33 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2021 21:07:33 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2021 20:30:37 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2021 20:30:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2021 20:30:2 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 05-08-2021 05:26
I was asking about the reboot not in the expectation that it would cure anything here, but to understand the error counts - the counters are zeroed when you do a reboot, and doing that gives a clue to how fast the errors are cropping up, and whether they are continuing to do so. DOCSIS is an error prone technology, and so the rate of increase is particularly important. I'll flag your post for staff to advise, but they will need the hub in router mode to troubleshoot. When you're running in modem mode (as I am too) the staff can't remotely interrogate the hub's data.
As a short term thing only, I suggest you put your own router in access point mode (only until this line fault is fixed) and the hub in router mode, that at least gives you good wifi, even if you have to put up with the hub's shonky router. The staff will probably need the hub in router mode for at least 24 hours. You're welcome to re-post the data here as well if you want community comment.
on 05-08-2021 08:40
Hi @MrMattHere.
Welcome to the community and thanks for your first post, we're happy to have you with us 🙂
I'm very sorry to hear you're experiencing intermittent connection, I appreciate how frustrating this must be and we apologise for any inconvenience caused.
I've managed to locate your account and I can see there is a short term connectivity issue causing intermittent service. Could you please ensure all white cables are connected securely to the Hub?
If so, I'd advise setting up a Broadband Quality Monitor here. This will continually monitor the state of your connection and record any network drop outs. It does this 24/7/365 and will keep a visual record of your connection. I'd advise keeping this running for up to a week to get a good indication on how the connection is performing. Once you've done this, please post the live link on this thread and we'll take a look at this for you.
on 05-08-2021 09:22
Hi Sofia,
Sure here you go -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/36a780ae4c17bb5af4f1fdc6b105cc4b21defc95
It's really annoying as my work meetings keep cutting out and my online games keep dropping, hate taking a hit to my productivity and rank needlessly 😂
