27-09-2022 11:52 - edited 27-09-2022 11:55
Hello!
For the past week or two we've been experience regular dropouts on our 1gb service, dozens of times a day. Whilst we've had a few dropouts lasting up to 5mins, they are usually only brief, 10-30seconds, but it's enough to cause havoc with 3 of us working at home, getting constantly kicked off work meetings etc.
Internal set up is solid. Virgin Hub 4 is in modem mode to an Asus RT-AX86U with Merlin firmware. Mix of wired and wireless devices (all drop at the same time).
We had an engineer out about a month ago after our virgin hub failed from a power cut. He replaced that but took the 'booster' we had installed with him. When we first had virgin installed, I remember that engineer saying we were quite a long way from the cabinet, and the booster would help with any issues. Not sure if that could be part of the problem? Thought it worth mentioning...
I was hoping someone more knowledgeable might please be able to have a look at the info below and see if anything stands out, thanks!
I started the BQM running late last night, so it doesn't have full data yet but link here:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a002c21b0841a46568f7f256354e7de4fe8ab6c0
Fri 16/09/2022 13:52:07 | 6 | CM-STATUS message sent. Event Type Code: 21; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 16/09/2022 13:52:07 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 16/09/2022 13:53:08 | 3 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 16/09/2022 13:58:50 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 16/09/2022 13:59:02 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 16/09/2022 13:59:02 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 16/09/2022 20:37:38 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 16/09/2022 21:51:18 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 17/09/2022 19:36:21 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 17/09/2022 21:13:02 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 18/09/2022 22:38:45 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 19/09/2022 14:10:20 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 20/09/2022 01:34:28 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 20/09/2022 01:34:28 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 20/09/2022 14:51:34 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 21/09/2022 15:33:25 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 21/09/2022 15:33:39 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 21/09/2022 15:33:40 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 22/09/2022 03:17:07 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 22/09/2022 11:53:49 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: ; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 23/09/2022 04:47:15 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 23/09/2022 11:45:32 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 23/09/2022 11:45:32 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 23/09/2022 12:41:26 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 23/09/2022 13:16:17 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 24/09/2022 08:33:48 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 24/09/2022 08:33:48 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 24/09/2022 09:07:07 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 24/09/2022 16:49:48 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 24/09/2022 17:11:06 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 25/09/2022 03:15:48 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 25/09/2022 03:15:48 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 25/09/2022 04:05:10 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 25/09/2022 04:46:32 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 25/09/2022 13:38:09 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 25/09/2022 13:46:50 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 25/09/2022 18:29:21 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 25/09/2022 19:46:53 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 27/09/2022 00:12:13 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 27/09/2022 00:47:31 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 27/09/2022 00:47:56 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 27/09/2022 00:47:56 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 27-09-2022 11:53
48 | 514750000 | 4.4 | 40.4 | QAM256 | 48 |
18 | 274750000 | 6.4 | 39 | QAM256 | 18 |
19 | 282750000 | 6.2 | 40.4 | QAM256 | 19 |
20 | 290750000 | 6.3 | 39 | QAM256 | 20 |
21 | 298750000 | 6.7 | 38.6 | QAM256 | 21 |
22 | 306750000 | 6.3 | 40.4 | QAM256 | 22 |
23 | 314750000 | 5.7 | 39 | QAM256 | 23 |
24 | 322750000 | 4.7 | 38.6 | QAM256 | 24 |
25 | 330750000 | 4.6 | 39 | QAM256 | 25 |
26 | 338750000 | 4.5 | 39 | QAM256 | 26 |
27 | 346750000 | 4.9 | 39 | QAM256 | 27 |
28 | 354750000 | 5 | 39 | QAM256 | 28 |
29 | 362750000 | 4.7 | 38.6 | QAM256 | 29 |
30 | 370750000 | 4.3 | 38.6 | QAM256 | 30 |
31 | 378750000 | 4.1 | 39 | QAM256 | 31 |
32 | 386750000 | 4.2 | 38.6 | QAM256 | 32 |
33 | 394750000 | 4.3 | 39 | QAM256 | 33 |
34 | 402750000 | 4.7 | 40.4 | QAM256 | 34 |
35 | 410750000 | 4.5 | 40.4 | QAM256 | 35 |
36 | 418750000 | 4 | 39 | QAM256 | 36 |
37 | 426750000 | 3.7 | 38.6 | QAM256 | 37 |
38 | 434750000 | 3.6 | 39 | QAM256 | 38 |
39 | 442750000 | 4.1 | 40.4 | QAM256 | 39 |
40 | 450750000 | 4.6 | 40.4 | QAM256 | 40 |
41 | 458750000 | 4.6 | 40.9 | QAM256 | 41 |
42 | 466750000 | 4.5 | 40.4 | QAM256 | 42 |
43 | 474750000 | 3.9 | 40.4 | QAM256 | 43 |
44 | 482750000 | 3.8 | 40.4 | QAM256 | 44 |
45 | 490750000 | 3.8 | 39 | QAM256 | 45 |
46 | 498750000 | 4.1 | 39 | QAM256 | 46 |
47 | 506750000 | 4.3 | 40.4 | QAM256 | 47 |
48 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.605377 | 0 | 0 |
25 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.605377 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
32 | Locked | 38.605377 | 0 | 0 |
33 | Locked | 38.983261 | 0 | 0 |
34 | Locked | 40.366287 | 0 | 0 |
35 | Locked | 40.366287 | 0 | 0 |
36 | Locked | 38.983261 | 0 | 0 |
37 | Locked | 38.605377 | 0 | 0 |
38 | Locked | 38.983261 | 0 | 0 |
39 | Locked | 40.366287 | 0 | 0 |
40 | Locked | 40.366287 | 0 | 0 |
41 | Locked | 40.946209 | 0 | 0 |
42 | Locked | 40.366287 | 0 | 0 |
43 | Locked | 40.366287 | 0 | 0 |
44 | Locked | 40.366287 | 0 | 0 |
45 | Locked | 38.983261 | 0 | 0 |
46 | Locked | 38.983261 | 0 | 0 |
47 | Locked | 40.366287 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 42 | 2.9 | 17276990 | 0 |
on 27-09-2022 11:54
1 | 43100000 | 36.5 | 5120 KSym/sec | 64QAM | 10 |
2 | 23600000 | 35 | 5120 KSym/sec | 64QAM | 13 |
3 | 30100000 | 35.5 | 5120 KSym/sec | 64QAM | 12 |
4 | 36600000 | 36 | 5120 KSym/sec | 64QAM | 11 |
5 | 49600000 | 36.5 | 5120 KSym/sec | 64QAM | 9 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
14 | 10.0 | 32.0 | 2K | QAM8 |
14 | OFDMA | 200 | 53.9 | 0 | 0 |
on 28-09-2022 22:13
New BQM, IP changed
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5a0d89d349b5c5ff69b4d0a135c50e28bbb61cce-28-09-2022
on 01-10-2022 10:41
Hi Ceodod,
Thank you for your post and welcome to the community.
I'm very sorry to hear about issue with your broadband service.
I have taken a look on our side and I am unable to see anything that could be causing the issue.
Can you please confirm if you are still having this issue?
^Martin
on 05-10-2022 06:16
Hi Martin,
We're not getting as many drop-outs now but still occasionally.
I'm no expert with the Broadband Quality Monitor but it doesn't look so healthy to me!
These are from the last couple of days and live link below:
on 05-10-2022 08:03
on 07-10-2022 12:03
Thanks for coming back to us Ceodod,
We can certainly understand the frustration caused by these intermittent dropouts, Upon checking this morning, I have done a full health check and cannot see any issues what could be causing this issue.
All your power levels are within specification and nice and green, there are no SNR issue or area faults that are causing any issues either which is good.
You advised in your original post that you are using your hub in modem mode currently as you are connected to a mesh system. Have you tested your connection in router mode and removed the 3rd party equipment.
Can you give this a go first and come back to us.
Kind regards Jodi.
