on 21-07-2022 16:45
Our internet has been dropping out multiple times a day when using ethernet and Wi-Fi.
The drops usually last less than 1 minute but can range up to 2 or 3 mins.
We've tried rebooting the router and checked router cables.
I'd appreciate any assistance.
THINKBROADBAND
Live:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7fc3105b4d13e9644af6479e467b6cbfd8...
21/07/22:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/83b636442bf88222d93113a79e16e2502dbb127d-21-07-2022
20/07/22:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7bbe080f4edcdf7b2df9a761c75d4ce142d9f914-20-07-2022
19/07/22:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/8d1921f0ce1f9ce8dd6e2b23144d4239506950f5-19-07-2022
NETWORK LOG
21/07/2022 15:26:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 15:25:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 15:03:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 15:03:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 15:03:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 15:03:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 15:01:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 15:01:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:58:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:58:20criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:58:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:57:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:57:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:57:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:56:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:56:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:55:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:54:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:53:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2022 14:53:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 21-07-2022 16:47
DOWNSTREAM BONDED CHANNELS
1 | 235000000 | 3.4 | 40 | 256 qam | 13 |
2 | 243000000 | 3 | 40 | 256 qam | 14 |
3 | 251000000 | 3.2 | 40 | 256 qam | 15 |
4 | 259000000 | 3.9 | 40 | 256 qam | 16 |
5 | 267000000 | 4 | 40 | 256 qam | 17 |
6 | 275000000 | 4 | 40 | 256 qam | 18 |
7 | 283000000 | 3.9 | 40 | 256 qam | 19 |
8 | 291000000 | 3.9 | 40 | 256 qam | 20 |
9 | 299000000 | 4.1 | 40 | 256 qam | 21 |
10 | 307000000 | 4.1 | 40 | 256 qam | 22 |
11 | 315000000 | 4.4 | 40 | 256 qam | 23 |
12 | 323000000 | 4.3 | 40 | 256 qam | 24 |
13 | 331000000 | 4.1 | 40 | 256 qam | 25 |
14 | 339000000 | 3.9 | 40 | 256 qam | 26 |
15 | 347000000 | 3.5 | 40 | 256 qam | 27 |
16 | 355000000 | 3.2 | 40 | 256 qam | 28 |
17 | 363000000 | 3.4 | 40 | 256 qam | 29 |
18 | 371000000 | 3.2 | 40 | 256 qam | 30 |
19 | 379000000 | 3.2 | 40 | 256 qam | 31 |
20 | 387000000 | 2.9 | 40 | 256 qam | 32 |
21 | 395000000 | 2.9 | 40 | 256 qam | 34 |
22 | 403000000 | 3 | 40 | 256 qam | 35 |
23 | 411000000 | 2.7 | 40 | 256 qam | 36 |
24 | 419000000 | 2.5 | 40 | 256 qam | 37 |
1 | Locked | 40.9 | 1053284 | 1032805 |
2 | Locked | 40.3 | 1003035 | 1001322 |
3 | Locked | 40.3 | 936450 | 950410 |
4 | Locked | 40.9 | 895278 | 898381 |
5 | Locked | 40.9 | 899268 | 886672 |
6 | Locked | 40.3 | 861039 | 843499 |
7 | Locked | 40.9 | 812993 | 817738 |
8 | Locked | 40.3 | 781731 | 783700 |
9 | Locked | 40.3 | 769420 | 749145 |
10 | Locked | 40.3 | 734254 | 726821 |
11 | Locked | 40.3 | 713320 | 700652 |
12 | Locked | 40.3 | 700944 | 690200 |
13 | Locked | 40.9 | 661040 | 649281 |
14 | Locked | 40.3 | 644047 | 612944 |
15 | Locked | 40.3 | 620845 | 609795 |
16 | Locked | 40.3 | 611179 | 601545 |
17 | Locked | 40.3 | 582118 | 587160 |
18 | Locked | 40.3 | 571274 | 543784 |
19 | Locked | 40.3 | 552082 | 538684 |
20 | Locked | 40.9 | 524153 | 511553 |
21 | Locked | 40.3 | 504019 | 519018 |
22 | Locked | 40.3 | 479990 | 501913 |
23 | Locked | 40.3 | 464988 | 468458 |
24 | Locked | 40.3 | 450957 | 472105 |
on 21-07-2022 16:48
UPSTREAM BONDED CHANNELS
1 | 60300000 | 46.5 | 5120 | 64 qam | 1 |
2 | 53700000 | 46 | 5120 | 64 qam | 2 |
3 | 39400000 | 45.8 | 5120 | 64 qam | 4 |
4 | 46200000 | 45.8 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 15 | 0 |
2 | ATDMA | 0 | 0 | 21 | 0 |
3 | ATDMA | 0 | 0 | 18 | 0 |
4 | ATDMA | 0 | 0 | 41 | 0 |
on 21-07-2022 16:55
on 21-07-2022 17:38
Thanks for sending this over.
I carried these steps out a few days ago after seeing this reply to a similar post. I set up the broadband monitor then and haven’t touched anything else since.
Router is in router mode.
Devices: 2 x TVs, 1 x PC, 1 x Game console, 1 x Network switch
on 22-07-2022 14:03
on 22-07-2022 16:06
Beautiful thanks, I’ll give that a go.
on 26-07-2022 21:17
Thanks for sending the previous info over and apologies for the delay.
All ethernet devices have now been unplugged for the past 24hrs but still getting drops:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/403b434979c6fb57e83038fa869c7ec743...
I'm guessing a ticket will need to be logged for a Virgin engineer to take a look at this.
I'm not the account holder for this connection, does anyone know if I'd still be able to raise one on behalf of them?
Many thanks.
on 27-07-2022 13:15
on 27-07-2022 19:28
I've attached them below:
1 | Locked | 40.3 | 472736 | 297004 |
2 | Locked | 40.3 | 435379 | 282035 |
3 | Locked | 40.3 | 413296 | 270532 |
4 | Locked | 40.3 | 391184 | 255505 |
5 | Locked | 40.3 | 377876 | 249524 |
6 | Locked | 40.9 | 363705 | 235051 |
7 | Locked | 40.3 | 341977 | 229692 |
8 | Locked | 40.3 | 325712 | 225514 |
9 | Locked | 40.3 | 312125 | 211633 |
10 | Locked | 40.9 | 293623 | 211340 |
11 | Locked | 40.3 | 286206 | 197534 |
12 | Locked | 40.3 | 277268 | 197056 |
13 | Locked | 40.3 | 257493 | 186034 |
14 | Locked | 40.3 | 250120 | 178171 |
15 | Locked | 40.3 | 238235 | 178198 |
16 | Locked | 40.3 | 230869 | 178809 |
17 | Locked | 40.3 | 216957 | 171704 |
18 | Locked | 40.3 | 209850 | 161588 |
19 | Locked | 40.3 | 202867 | 158345 |
20 | Locked | 40.3 | 192555 | 153138 |
21 | Locked | 40.3 | 184759 | 157612 |
22 | Locked | 40.9 | 174264 | 155048 |
23 | Locked | 40.3 | 167421 | 141005 |
24 | Locked | 40.9 | 159929 | 141984 |
