05-07-2022 16:10 - edited 05-07-2022 16:23
I've been a Virgin broadband (Hub 3) customer for 18 months now (200mb) and up to now it's been faultless. SO LUCKY! In the past couple of months however we've noticed an increasing problem with interruption, usually during the day when the connection drops for a minute or so then it's back to normal (average between 180-210mbps) or will it remain 'slow' for a short period (around 60mpbs). This is interrupting work calls and is well...annoying! Other things like websites wont load even though there's a 'connection' etc. I've posted some stats below, hopefully they're of some use. I must point out that these problems coincide with our neighbour having Virgin broadband installed...possible link? many thanks!
1 | 259000000 | 3.2 | 40 | 256 qam | 16 |
2 | 139000000 | 2.9 | 40 | 256 qam | 1 |
3 | 147000000 | 3 | 40 | 256 qam | 2 |
4 | 155000000 | 3.2 | 40 | 256 qam | 3 |
5 | 163000000 | 3 | 40 | 256 qam | 4 |
6 | 171000000 | 3.2 | 40 | 256 qam | 5 |
7 | 179000000 | 3.5 | 40 | 256 qam | 6 |
8 | 187000000 | 3.5 | 40 | 256 qam | 7 |
9 | 195000000 | 3.4 | 40 | 256 qam | 8 |
10 | 203000000 | 3.5 | 40 | 256 qam | 9 |
11 | 211000000 | 3.2 | 40 | 256 qam | 10 |
12 | 219000000 | 3 | 40 | 256 qam | 11 |
13 | 227000000 | 3.4 | 40 | 256 qam | 12 |
14 | 235000000 | 3.2 | 38 | 256 qam | 13 |
15 | 243000000 | 2.7 | 40 | 256 qam | 14 |
16 | 251000000 | 3 | 40 | 256 qam | 15 |
17 | 267000000 | 2.5 | 40 | 256 qam | 17 |
18 | 275000000 | 2.4 | 40 | 256 qam | 18 |
19 | 283000000 | 3 | 40 | 256 qam | 19 |
20 | 291000000 | 2.7 | 40 | 256 qam | 20 |
21 | 299000000 | 2.5 | 40 | 256 qam | 21 |
22 | 307000000 | 3 | 40 | 256 qam | 22 |
23 | 315000000 | 3 | 40 | 256 qam | 23 |
24 | 323000000 | 2.5 | 38 | 256 qam | 24 |
1 | 39400002 | 51 | 5120 | 64 qam | 4 |
2 | 46200029 | 51 | 5120 | 64 qam | 3 |
3 | 53699993 | 51 | 5120 | 64 qam | 2 |
4 | 60299944 | 51 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 4 | 0 |
3 | ATDMA | 0 | 0 | 4 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | 9873254k;fg87dsfd;kfoA,.i |
SFID | 19961 |
Max Traffic Rate | 230000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 19962 |
Max Traffic Rate | 22000061 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
05/07/2022 13:58:50 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/07/2022 13:30:54 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/07/2022 12:11:24 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/07/2022 12:11:24 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/07/2022 23:29:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/07/2022 00:11:24 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/07/2022 00:11:24 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 05-07-2022 16:28
Cable Modem Status Item Status Comments
Acquired Downstream Channel (Hz) | 259000000 | Locked |
Ranged Upstream Channel (Hz) | 39400002 | Locked |
Provisioning State | Online |
on 05-07-2022 16:34
Upstream power levels are too high and you have some T3 timeouts.
Before having a go at the neighbours check for local issues on 0800 561 0061 and ensure that all cables and connections are tight and secure and not kinked or damaged.
Also try a 30 second pinhole reset of the hub with no ethernet connection.
Lastly set up a BQM by visiting https://www.thinkbroadband.com/broadband/monitoring/quality and share the link which hides your IP address on here (all is explained in the link).
on 05-07-2022 17:29
I have removed the now unnecessary tv/broadband splitter cables and have got the figures down. I’ve got the 24hr tracker on too, will see how we go. Thanks!
1 | 39400007 | 47.5 | 5120 | 64 qam | 4 |
2 | 46199947 | 47.5 | 5120 | 64 qam | 3 |
3 | 53700019 | 47.5 | 5120 | 64 qam | 2 |
4 | 60300004 | 47.5 | 5120 | 64 qam | 1 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 05-07-2022 17:43
Good to hear. You are the second person I have come across who has found a redundant splitter to be the issue. Must be something to do with customers downsizing their VM package given the cost of living issues.
on 05-07-2022 18:48
While I'm here, are you able to order me one of the intelligent wifi pods? We're Volt customers but can't find anyway to order them online. Thanks
on 05-07-2022 19:05
You can order an Intelligent WiFi Pod by calling 0800 064 3850.
on 06-07-2022 15:07
This is the results of the monitoring from yesterday (5pm packet loss due to disconnecting the router). We’re still experiencing some speed issues that we didn’t before though. It seems to be to do with traffic but I’d expect a 200mb connection to be able to survive 4/5 devices being in use during the day.
Do these Pre RS errors mean anything? Thanks!
1 | Locked | 40.3 | 9 | 0 |
2 | Locked | 40.3 | 7 | 0 |
3 | Locked | 40.3 | 12 | 0 |
4 | Locked | 40.3 | 3 | 0 |
5 | Locked | 40.9 | 10 | 0 |
6 | Locked | 40.3 | 4 | 0 |
7 | Locked | 40.3 | 19 | 0 |
8 | Locked | 40.3 | 18 | 0 |
9 | Locked | 40.3 | 21 | 0 |
10 | Locked | 40.3 | 10 | 0 |
11 | Locked | 40.3 | 7 | 0 |
12 | Locked | 40.3 | 4 | 0 |
13 | Locked | 40.9 | 6 | 0 |
14 | Locked | 38.9 | 6 | 0 |
15 | Locked | 40.3 | 9 | 0 |
16 | Locked | 40.9 | 6 | 0 |
17 | Locked | 40.9 | 10 | 0 |
18 | Locked | 40.9 | 7 | 0 |
19 | Locked | 40.9 | 7 | 0 |
20 | Locked | 40.3 | 7 | 0 |
21 | Locked | 40.3 | 6 | 0 |
22 | Locked | 40.9 | 5 | 0 |
23 | Locked | 40.3 | 6 | 0 |
24 | Locked | 38.9 | 7 | 0 |
on 06-07-2022 15:11
on 08-07-2022 16:20
Hello Sarahb90,
Thanks for your post.
Sorry to hear about the issue with your broadband connection and the request for pods
I can look into both of these for you.
I did check the signal levels for your Hub and the downstream levels are just out, It will need us to book a technician to attend.
If you don't mind, I will need to send you a private message to pass security to arrange.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
