on 18-07-2022 14:00
Since the firmware update (solid green light for bridge mode)
I am getting constant modem resets, due to the new light system I can’t self de bug what is happening.
internet goes down, light flashes white, then goes to solid green then connection comes back
this is happened around 10-15 times today (previously this had happened but maybe 1-2 a week)
what the hell is going on since the firmware update?
on 18-07-2022 14:30
on 18-07-2022 15:36
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level.
on 18-07-2022 16:04
No area faults when calling that number, but just received a text message saying there are planned works in the area for tomorrow so maybe it’s that
on 18-07-2022 21:48
This has happened through the day maybe 30 times (sometimes it’s a yellow flashing light other times it’s a white flashing light) internet only drops for maybe a couple of mins then reconnects
on 19-07-2022 12:59
25 | 331000000 | -12.900002 | 33.834164 | QAM256 | 25 |
1 | 139000000 | -15.400002 | 32.676208 | QAM256 | 1 |
2 | 147000000 | -15.099998 | 33.062504 | QAM256 | 2 |
3 | 155000000 | -14.400002 | 33.376591 | QAM256 | 3 |
4 | 163000000 | -14.200001 | 33.834164 | QAM256 | 4 |
5 | 171000000 | -14.400002 | 33.834164 | QAM256 | 5 |
6 | 179000000 | -14.299999 | 33.834164 | QAM256 | 6 |
7 | 187000000 | -14.299999 | 33.834164 | QAM256 | 7 |
8 | 195000000 | -14.299999 | 33.834164 | QAM256 | 8 |
9 | 203000000 | -14.099998 | 33.834164 | QAM256 | 9 |
10 | 211000000 | -13.700001 | 33.956509 | QAM256 | 10 |
11 | 219000000 | -13.599998 | 34.345688 | QAM256 | 11 |
12 | 227000000 | -13.500000 | 34.345688 | QAM256 | 12 |
13 | 235000000 | -13.500000 | 34.345688 | QAM256 | 13 |
14 | 243000000 | -13.500000 | 33.956509 | QAM256 | 14 |
15 | 251000000 | -13.299999 | 33.956509 | QAM256 | 15 |
16 | 259000000 | -12.900002 | 34.345688 | QAM256 | 16 |
17 | 267000000 | -13.000000 | 34.345688 | QAM256 | 17 |
18 | 275000000 | -13.299999 | 34.483570 | QAM256 | 18 |
19 | 283000000 | -12.599998 | 34.345688 | QAM256 | 19 |
20 | 291000000 | -12.400002 | 33.956509 | QAM256 | 20 |
21 | 299000000 | -12.099998 | 33.956509 | QAM256 | 21 |
22 | 307000000 | -12.099998 | 33.834164 | QAM256 | 22 |
23 | 315000000 | -12.400002 | 33.956509 | QAM256 | 23 |
24 | 323000000 | -13.000000 | 33.834164 | QAM256 | 24 |
26 | 339000000 | -12.400002 | 33.956509 | QAM256 | 26 |
27 | 347000000 | -12.500000 | 33.956509 | QAM256 | 27 |
28 | 355000000 | -12.700001 | 33.956509 | QAM256 | 28 |
29 | 363000000 | -12.299999 | 34.483570 | QAM256 | 29 |
30 | 371000000 | -12.299999 | 34.345688 | QAM256 | 30 |
31 | 379000000 | -12.400002 | 34.345688 | QAM256 | 31 |
25 | Locked | 33.834164 | 6418 | 1836 |
1 | Locked | 32.676208 | 86766 | 14110 |
2 | Locked | 33.062504 | 4935 | 4020 |
3 | Locked | 33.376591 | 15595 | 3958 |
4 | Locked | 33.834164 | 58967 | 6968 |
5 | Locked | 33.834164 | 517 | 4572 |
6 | Locked | 33.834164 | 36830 | 5358 |
7 | Locked | 33.834164 | 5416 | 3997 |
8 | Locked | 33.834164 | 645 | 3720 |
9 | Locked | 33.834164 | 646 | 3233 |
10 | Locked | 33.956509 | 964 | 2932 |
11 | Locked | 34.345688 | 430 | 3593 |
12 | Locked | 34.345688 | 402 | 3453 |
13 | Locked | 34.345688 | 275 | 3953 |
14 | Locked | 33.956509 | 685 | 2748 |
15 | Locked | 33.956509 | 275 | 2374 |
16 | Locked | 34.345688 | 421 | 2440 |
17 | Locked | 34.345688 | 220 | 2254 |
18 | Locked | 34.483570 | 432 | 2335 |
19 | Locked | 34.345688 | 639 | 2279 |
20 | Locked | 33.956509 | 1280 | 2321 |
21 | Locked | 33.956509 | 1914 | 2225 |
22 | Locked | 33.834164 | 3225 | 2171 |
23 | Locked | 33.956509 | 9047 | 2251 |
24 | Locked | 33.834164 | 9433 | 1966 |
26 | Locked | 33.956509 | 6944 | 1905 |
27 | Locked | 33.956509 | 8317 | 2029 |
28 | Locked | 33.956509 | 3475 | 2018 |
29 | Locked | 34.483570 | 1240 | 1858 |
30 | Locked | 34.345688 | 1014 | 1956 |
31 | Locked | 34.345688 | 439 | 1732 |
33 | 96 | 4K | 1880 | QAM4096 | 424 |
33 | Locked | 36 | -12.8 | 3270340 | 1413 |
on 19-07-2022 12:59
1 | 53700000 | 59.020599 | 5120 KSym/sec | 64QAM | 6 |
2 | 60300000 | 59.020599 | 5120 KSym/sec | 64QAM | 5 |
3 | 39400000 | 59.020599 | 5120 KSym/sec | 64QAM | 8 |
4 | 46200000 | 59.020599 | 5120 KSym/sec | 64QAM | 7 |
1 | US_TYPE_STDMA | 0 | 0 | 16 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 38 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 19 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 29 |
on 19-07-2022 13:01
Thu Jan 1 00:01:26 1970 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:10:24 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:14:16 2022 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:14:59 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:15:10 2022 | 6 | CM-STATUS message sent. Event Type Code: 23; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:15:11 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:15:15 2022 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:15:15 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:15:26 2022 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:15:27 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:15:52 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:15:52 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:16:00 2022 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:16:08 2022 | 3 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:16:58 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:18:02 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:51:51 2022 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:51:59 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:52:13 2022 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:52:13 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:52:17 2022 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:52:18 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:52:22 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Jul 19 11:52:22 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 19-07-2022 13:31
Modem seems to be resetting itself constantly sometimes every couple of mins other times it may stay connected for 10mins before it resets again.
I wonder if it’s the heat as this started getting really bad from yesterday (modem is in a shaded part of the house and no where near sun light) was told on engineer can only come by the end of the week, but work from home so I’m pretty….. (insert expletive)
19-07-2022 15:52 - edited 19-07-2022 15:53
It's unlikely a firmware update has caused your Docsis levels to be poor, your line needs fixing.
