on 08-02-2022 16:48
For a while now my internet connection has been periodically dropping out throughout the day. It is usually only for a matter of seconds but while working at home has inevitably caused disruption to Zoom meetings.
I have tried all the tips and checks and can see no service issue in my area.
Can you please help
on 08-02-2022 16:57
on 08-02-2022 17:09
Both. Most devices (v6 boxes and games consoles) are wired direct to hub3 but also some WiFi via laptops/phones. Had the issue a few months ago but was eventually resolved when engineer replaced all the wall connections (said the 3rd party connectors were allowing leakage or causing interference into the system - don't recall exactly what he said). Been working fine since until recently when problem started reoccurring - nothing in the setup has been changed between the issue being fixed and it reoccurring.
on 11-02-2022 09:49
Hi dereks2003,
Thank you for your post. I'm very sorry to hear about the issue with your broadband service.
Can you confirm if you're continuing to have issues?
^Martin
on 11-02-2022 19:31
Hi Martin
Doesn't seem too bad at the moment but it does come and go - any advice?
on 13-02-2022 21:06
After a couple of days where it has not been too bad, it has now gone back to going off regularly. Nothing has changed and no extra usage so at a complete loss as to what is causing the issue.
on 14-02-2022 11:11
Hello @dereks2003,
Thank you for the update with this.
How is your wired connection for you at the moment?
Many thanks,
on 14-02-2022 12:27
Hi Hayley
I'm still getting intermittent problems where I lose Internet connection (both wired and wifi). It is difficult to know how often this is happening as it only usually goes down for a few seconds. It is most noticeable when the kids are playing online on their games consoles - when it goes down they have to reconnect to their game.
Is there a log that would record how often this is happening?
on 14-02-2022 12:38
on 14-02-2022 12:46
Excuse my lack of knowledge but I have no idea what a BQM is - presumably just Google it to find out how to set one up?
