If you can just connect any laptop or computer port by ethernet cable (Cat5e/6) - via an adapter if necessary and see how that performs.
Meanwhile...
Type in
http://192.168.0.1 into your web browser’s url box and login with settings password on the Hub's base sticker (or your own if you changed it). Then in Advanced>wireless>smart wifi - tick the disable “channel optimisation” box and save settings. Then, go to advanced>wireless>security, rename the 2.4 & 5 GHz network SSID's. Just change 'em to whatever you like and something that will differentiate them (e.g - adrbud_2 & adrbud_5) -- use the same password for both. Then, click apply settings and restart the Hub. Your 2 wifi networks will now be clearly separated - and you can then select the network you want to connect to individually from the "available networks" list on each device.
Note all your wifi devices will need re-connecting to the new SSID's and passwords.
5 GHz is usually better and subject to less interference (and is better for iDevices ) than the 2.4 one - although this one has the better "range" and some older/cheaper/dumber devices can only use this one.
You should also use a wifi analyser App to check which 2.4 channels are being heavily used around you and move yours to one of numbers 1,6,11 that is least so, but it wont help if there is other interference.
See if these changes help - you will lose any “seamless roaming” benefits but it may not matter and you can always change the settings back by doing a " pinhole factory reset " if you prefer the way it was - or it doesn’t help.
