on 27-05-2022 12:19
Dear Sir/Madam,
For the last few weeks our network has been degrading, from dropped speeds to infrequent loss of the network. However, over the last two weeks to connection became very unstable to the point it will reset a few times in a single hour. Rebooting the Hub or resetting to the factory setting does not help.
Please have a look at the graphs.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/186d04a189206dfc6cb742b6075838d6c01357b9-27-05-2022
Acquired Downstream Channel (Hz) | 202750000 | Locked |
Ranged Upstream Channel (Hz) | 39400000 | Locked |
Provisioning State | Online |
1 | 202750000 | 3.5 | 38 | 256 qam | 9 |
2 | 210750000 | 3.5 | 38 | 256 qam | 10 |
3 | 218750000 | 3.2 | 38 | 256 qam | 11 |
4 | 226750000 | 2.7 | 38 | 256 qam | 12 |
5 | 234750000 | 3 | 38 | 256 qam | 13 |
6 | 242750000 | 2.9 | 38 | 256 qam | 14 |
7 | 250750000 | 3 | 38 | 256 qam | 15 |
8 | 258750000 | 3.4 | 38 | 256 qam | 16 |
9 | 266750000 | 3.7 | 38 | 256 qam | 17 |
10 | 274750000 | 3.7 | 38 | 256 qam | 18 |
11 | 282750000 | 4 | 38 | 256 qam | 19 |
12 | 290750000 | 4.5 | 38 | 256 qam | 20 |
13 | 298750000 | 5 | 38 | 256 qam | 21 |
14 | 306750000 | 4.3 | 38 | 256 qam | 22 |
15 | 314750000 | 4.1 | 38 | 256 qam | 23 |
16 | 322750000 | 4.3 | 38 | 256 qam | 24 |
17 | 330750000 | 4.3 | 38 | 256 qam | 25 |
18 | 338750000 | 4.3 | 38 | 256 qam | 26 |
19 | 346750000 | 4.6 | 38 | 256 qam | 27 |
20 | 354750000 | 4.4 | 38 | 256 qam | 28 |
21 | 362750000 | 4 | 38 | 256 qam | 29 |
22 | 370750000 | 3.5 | 38 | 256 qam | 30 |
23 | 378750000 | 3 | 38 | 256 qam | 31 |
24 | 386750000 | 2.5 | 38 | 256 qam | 32 |
1 | 39400000 | 45.3 | 5120 | 64 qam | 6 |
2 | 46200000 | 45.3 | 5120 | 64 qam | 5 |
3 | 25800000 | 45.5 | 5120 | 64 qam | 8 |
4 | 32600000 | 45.5 | 5120 | 64 qam | 7 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt060+voc-b.cm |
SFID | 84376 |
Max Traffic Rate | 230000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Regards,
Sebastian Szczupak
Answered! Go to Answer
on 12-06-2022 19:57
Hi David,
The network has improved as pre RS and post RS errors have reduced from 0.5Million per day to low thousand, how over from time to time TV will drop signal. Bellow errors as 1day accumulation, I've reset the modem yesterday mid-day. As you see timing synchronization failure spectrum is dominant in logs and post RS errors point to fluctuating power, so has VM connected more people than can it support in my area?
12/06/2022 19:48:54 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/06/2022 03:40:14 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/06/2022 03:40:14 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/06/2022 03:39:17 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/06/2022 03:39:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 22:49:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 22:49:12 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 22:46:47 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 20:21:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 15:52:35 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 15:52:35 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 15:52:19 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 15:52:19 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 15:46:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 15:46:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 08:39:38 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 08:39:38 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 04:02:1 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 04:02:1 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 03:59:36 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
1 | Locked | 38.9 | 2119 | 2427 |
2 | Locked | 38.6 | 2759 | 2452 |
3 | Locked | 38.6 | 2684 | 2582 |
4 | Locked | 38.9 | 2688 | 2757 |
5 | Locked | 38.6 | 2629 | 2932 |
6 | Locked | 38.6 | 2521 | 2857 |
7 | Locked | 38.6 | 2527 | 2742 |
8 | Locked | 38.9 | 2488 | 2862 |
9 | Locked | 38.9 | 2354 | 2595 |
10 | Locked | 38.9 | 2310 | 2831 |
11 | Locked | 38.9 | 2319 | 3077 |
12 | Locked | 38.6 | 2298 | 2928 |
13 | Locked | 38.9 | 2226 | 2975 |
14 | Locked | 38.6 | 2235 | 2895 |
15 | Locked | 38.9 | 2267 | 2757 |
16 | Locked | 38.9 | 2236 | 2639 |
17 | Locked | 38.6 | 2196 | 2749 |
18 | Locked | 38.9 | 2146 | 2748 |
19 | Locked | 38.6 | 2060 | 2918 |
20 | Locked | 38.9 | 2075 | 2992 |
21 | Locked | 38.9 | 2074 | 2766 |
22 | Locked | 38.6 | 2100 | 2846 |
23 | Locked | 38.6 | 2055 | 2780 |
24 | Locked | 38.6 | 1989 | 2821 |
Kind Regards,
Sebastian
on 15-06-2022 10:45
Hi David,
Update 15 June 2022, I had a VM engineer today (the third one) and as usual, he could not find the fault in our property, he suggested upgrading to VM hub 4, however, what I did today is I went to neighbours few housed down from me who also have VM services and they experience the same issue as me and their timelines also align when the issue started. The VM engineer said he will try to escalate this issue from his side, however, I am not familiar with VM internal policies and how effective this will be.
Therefore this is not an isolated issue to me, but rather the cabined. Can a network engineer and field engineer be assigned to this case? As filing complaints over the phone doesn't get me anywhere as your staff close the complaint as soon as I hang up the phone and they claim not to have the authority to book field engineer only home engineers.
Kind Regards,
Sebastian
on 15-06-2022 12:07
Thank you for your reply and I am glad to hear things have improved.
We have ran another check from our side and the live report has not detected any errors with all power levels running within specification.
Could you please continue to monitor the service from your end and let us know if any issues occur.
on 21-06-2022 19:32
Dear All,
The faults are ongoing and getting much worse again, our telly keeps showing errors cs2004 every few minutes furthermore, we have now setup whatup a group on our street as the fault are not limited to our property, we spoke now with multiple neighbours and are all experiencing similar issues.
There was a large outage on Friday the 17th and reported by all our neighbours.
As you can see last two days the connection issue is getting significantly worse.
Regards, Sebastian
on 21-06-2022 19:33
ime Priority Description
21/06/2022 19:21:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:21:5 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:21:4 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:21:4 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:08:42 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:08:42 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:06:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:06:50 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:06:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:06:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:06:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:06:8 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:05:31 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:05:31 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:03:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 19:03:8 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 18:08:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 18:08:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 18:08:2 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 18:08:2 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
1 | Locked | 37.6 | 1113435 | 197583 |
2 | Locked | 37.6 | 870313 | 217040 |
3 | Locked | 38.6 | 763267 | 237191 |
4 | Locked | 38.6 | 624410 | 272243 |
5 | Locked | 38.6 | 488217 | 279233 |
6 | Locked | 38.6 | 390541 | 308405 |
7 | Locked | 38.6 | 378233 | 319668 |
8 | Locked | 38.9 | 310758 | 330638 |
9 | Locked | 38.9 | 287946 | 341084 |
10 | Locked | 38.6 | 261488 | 325672 |
11 | Locked | 38.6 | 229409 | 321263 |
12 | Locked | 38.9 | 214320 | 311209 |
13 | Locked | 38.9 | 180939 | 325418 |
14 | Locked | 38.6 | 181344 | 327136 |
15 | Locked | 38.9 | 160957 | 316744 |
16 | Locked | 38.6 | 142252 | 315724 |
17 | Locked | 38.6 | 121080 | 317742 |
18 | Locked | 38.9 | 98881 | 311206 |
19 | Locked | 38.9 | 88413 | 312141 |
20 | Locked | 38.9 | 80910 | 306830 |
21 | Locked | 38.9 | 75627 | 316199 |
22 | Locked | 38.6 | 69422 | 319778 |
23 | Locked | 38.9 | 67540 | 319557 |
24 | Locked | 38.6 | 62375 | 309866 |
on 24-06-2022 14:27
Dear All,
Continued on with updates, the broadband and TV continues to dropout, recently VM sent me replacement TV box calming it will help, not at all, zero difference made. The red big blip is caused by VM hub3 going from modem mode to router so VM costumer service could run tests and confirm what we all know for past month. "Thank you for checking, Sebastian. I have run the checks on the tv box and the hub, we have identified the Pre RS issue, so as to fix this issue we can send out a technician", however I had 3 technicians and all of they said they unable to do anything, as they can't find a single fault at my property, the power fluctuation on VM cables is experience by our neighbours on our street and adjoining street.
1 | Locked | 37.6 | 1272571 | 143847 |
2 | Locked | 37.6 | 953751 | 162345 |
3 | Locked | 38.6 | 708181 | 188927 |
4 | Locked | 38.6 | 576207 | 218410 |
5 | Locked | 38.6 | 419621 | 216815 |
6 | Locked | 38.6 | 324759 | 239713 |
7 | Locked | 38.6 | 281902 | 227458 |
8 | Locked | 38.6 | 214246 | 235777 |
9 | Locked | 38.6 | 195435 | 236474 |
10 | Locked | 38.6 | 152399 | 219329 |
11 | Locked | 38.6 | 142141 | 203672 |
12 | Locked | 38.6 | 164460 | 212805 |
13 | Locked | 38.6 | 132735 | 213358 |
14 | Locked | 38.6 | 127124 | 216205 |
15 | Locked | 38.9 | 112120 | 235412 |
16 | Locked | 38.9 | 99120 | 225160 |
17 | Locked | 38.6 | 88684 | 221402 |
18 | Locked | 38.9 | 78088 | 224550 |
19 | Locked | 38.9 | 68141 | 215253 |
20 | Locked | 38.9 | 65809 | 199350 |
21 | Locked | 38.9 | 64802 | 200255 |
22 | Locked | 38.6 | 60735 | 201118 |
23 | Locked | 38.9 | 61371 | 214359 |
24 | Locked | 38.6 | 53200 | 211562 |
24/06/2022 11:37:53 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:37:53 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:37:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:37:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:26:18 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:26:18 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:26:16 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:26:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:26:10 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:26:10 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:26:7 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:26:7 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 10:00:3 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 10:00:3 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 07:30:26 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 07:30:26 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 07:30:25 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 07:30:25 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 07:30:24 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 07:30:23 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 24-06-2022 19:11
Hi boryssts,
I've had a look at things from our side and everything looks to be within the specifications we would expect.
Can you confirm how things have been since your last post?
Alex_Rm
on 24-06-2022 23:40
Hi Alex,
Please have look your self when you asked the question I have restarted the VM Hub3 to look at the RS Errors results for you, while I can understand you tests do not show you issues, it dose not mean there are no issues, I do not have visibility how limiting or comprehensive your tests are, however if there weren't any issues I would not go to the lengths of posting updates for more than a month.
1 | Locked | 37.3 | 134509 | 10378 |
2 | Locked | 37.6 | 98413 | 11304 |
3 | Locked | 38.6 | 70225 | 13066 |
4 | Locked | 38.6 | 54796 | 14547 |
5 | Locked | 37.6 | 41436 | 17579 |
6 | Locked | 38.6 | 30733 | 15924 |
7 | Locked | 38.9 | 26676 | 14847 |
8 | Locked | 38.6 | 21376 | 15794 |
9 | Locked | 38.6 | 17392 | 14959 |
10 | Locked | 38.6 | 16823 | 14762 |
11 | Locked | 38.6 | 15098 | 16042 |
12 | Locked | 38.6 | 15678 | 15633 |
13 | Locked | 38.6 | 12183 | 14365 |
14 | Locked | 38.6 | 11227 | 18369 |
15 | Locked | 38.6 | 9386 | 14117 |
16 | Locked | 38.6 | 7829 | 14740 |
17 | Locked | 38.9 | 6686 | 15940 |
18 | Locked | 38.9 | 6295 | 16010 |
19 | Locked | 38.9 | 5560 | 15217 |
20 | Locked | 38.9 | 5091 | 14997 |
21 | Locked | 38.9 | 4279 | 14085 |
22 | Locked | 38.9 | 3905 | 12985 |
23 | Locked | 38.9 | 3782 | 14388 |
24 | Locked | 38.6 | 3276 | 14080 |
24/06/2022 23:19:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:9 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:9 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:5 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:3 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:3 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:1 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:19:1 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:18:59 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:18:59 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:18:58 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:18:58 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:15:9 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:15:9 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 11:37:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0 |
AT this point I will file written complain to VM under "Virgin Media Speed Policy | Legal" and cancel the contract, as this issue has been on going for a more than a month and VM has not provided us with any updates how and when they aim to repair the issue. Therefore I will go back to BT as having intermittent broadband is not acceptable to me, I rather have half the speed and reliable broadband than this issue and my time invested trying to resolve this issue is more valuable to me then the monthly cost of VM broadband.
Regards,
Sebastian
on 25-06-2022 23:11
Virgin Media service is just pure joke, I tried to watch a netflix movie in 20 minutes time the internet went down 4 times and the last outage at 23:04 lasted for good 6-7 minutes, your service is just pure joke
25/06/2022 23:04:22 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:04:22 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:04:13 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:04:13 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:04:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:04:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:04:10 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:04:10 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:58 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:58 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:57 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:57 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:55 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:48 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:48 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:46 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 23:03:46 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 28-06-2022 10:59
Good Morning @boryssts, thanks for your posts, and I'm sorry to hear of the faults you've been experiencing.
Check out the purple envelope in the top right hand corner for a private message from me and I'll have an engineer visit arranged for you.
Kindest regards,
David_Bn
