on 15-12-2021 14:37
I had a wifi pod delivered to clear up a blackspot which worked perfectly with my hub3, i have just upgrade my package to 1gb and got the hub 4, have unplugged and replugged in the pod to try to get it to connect to the new hub4 but the light constantly flashes and doesnt turn off like it did with the hub3 and the blackspot is now back. The connect app doesnt work with the hub4 either so i cant try to set it up that way. Any help please?
on 15-12-2021 14:47
15-12-2021 14:54 - edited 15-12-2021 14:55
Is that just if the hub4 isnt working? because that is and i now have the faster speeds, its just the pod that won't connect to it? On phone to them now anyway to check, she said they should just auto pair and when i said it wasn't and its been like 45 mins she she's gone to check something and put me on hold
on 15-12-2021 15:09
on 15-12-2021 15:10
after a while on hold she came back and said plug it into power and then connect to the new hub for an hour with an Ethernet cable and that should reset it so we shall see.
Thanks for giving me the correct contact number and option though 🙂
on 20-12-2022 16:42
@ClassicWebby - I'd love to know if leaving the WiFi Pod connected to the Hub with an ethernet cable completed the pairing process or not. I've got a new Hub and need to solve the same problem.
