on 24-08-2022 18:16
I've posted on here before with regards to wifi and poor router placement. I'm trying to work out which would be more beneficial and which I could set up myself. Very much a novice when it comes to wifi
My options are to use the hub 3 in modem mode and use a tp link archer c80 as the router. Or use the c80 as an access point in the middle of the house. But I don't know which would be easier to do. Which would do the better job
I currently have a wifi extender plugged in the hall which is tp link. I set the same ssid as the router. But it doesn't seem to have improved. Is it because its the same ssid? Is it causing conflict? I want the same ssids because I don't want devices to be stuck on a poor wifi signal if I call the extender a different ssid when the router signal is stronger. If I set the hub 3 in modem mode the c80 will still be in back corner of the house so will that alone significantly improve wifi? Apologies for the lack of knowledge. The wifi extender was originally the same ssid with _ext at the end but I changed it to the exact same ssid. It may not work this way but I expect if the ssid is the same then devices will get whichever is the strongest signal. From the extender or the router
on 24-08-2022 18:34
on 24-08-2022 18:51
They do look good but I have already had the archer c80 for a good year or two so I want to put it to good use. Would the extender work better for now with a different ssid? I'd set the c80 up this weekend if I knew how to set it all up. Do you think the router in modem mode and c80 as router or c80 as an access point would give better coverage? Can I have it as an access point with the same ssid or will that cause problems?
on 24-08-2022 19:05
Yes the Archer c80 is a decent introductory router and according to the blurb - has the one range mesh range extender connectivity. Is that on the extender you have ? If so you can buils a Mesh system
The TP-Link router wiil be far better than the Hub's - so yes - use that in modem mode with the C80 routing and then see what you need to set up a Mesh from it
on 24-08-2022 19:23
The extender I have is a cheap tp link plug in wifi extender. Is it complicated to set the c80 up as a router. I want the same ssid I already have so I don't have to reconnect every device and will it automatically switch between 2.4 and 5ghz? It's when it gets onto all the channels and stuff it starts getting in depth
on 24-08-2022 20:35
