Johnhy
Message 1 of 10
IPTV not working through broadband
My iptv services are not connecting through my home broadband but all working fine on 4g phone so problem with my router blocking? Only happened last couple days
  • 11.71K
  • 778
  • 3.44K
Message 2 of 10
Re: IPTV not working through broadband
Depending on the service, UK ISP's are blocking IPTV connections that stream illegal content. Its more difficult on 4G. SO at a guess that's the issue. Unless you are going to tell me you have a totally legal IPTV stream that's blocked, in which case I can escalate for you.
Click to learn more about VIP
Use Kudos to say thanks
Johnhy
Message 3 of 10
Yes it's a legal stream that just doesn't work for hours then might come back on. But is ok through 4g. Same with Netflix it will have problems streaming for a while no matter what we do.
  • 11.71K
  • 778
  • 3.44K
Message 4 of 10
Kay can you PM me the details of the IPTV streams and Ill check my end and escalate with VM
Also-
So we can help us to help you, can you
Go to your Superhub Log in screen
Do NOT log in.
Little button top right.....
Can you post Upstream, Downstream and Network logs.
Screen caps are nice, C&P will do- Don't stress about formatting if you C&P. Someone will get a look and see if there's anything obvious amiss.
Gareth1987
Message 5 of 10
Same problem can you help please
  • 11.71K
  • 778
  • 3.44K
Message 6 of 10
As per the above, can you provide the details requested?
burkan
Message 7 of 10
my stream is perfectly legal as far as i know please escalate for me because it has been working perfectly fine for the last 2 years only when i upgraded it 3 days ago it all went dead .
please help.
thanks
  • 1.82K
  • 179
  • 427
vircom
Super solver
Message 8 of 10
What did you update 3 days ago?
Have you provided the requested information?
burkan
Message 9 of 10
because some of the channels were not working and what information is required from me to supply
Semahmonkey
Message 10 of 10
Hi did you get this sorted
