on 06-01-2021 17:22
I have an iPhone ProMax running IOS14.3. I am new to Virgin and have recently set up WIFI. My phone connects to the WIFI but doesn't appear to actually be using it as it is incredibly slow. When I disconnect from WIFI it speeds up. I never had this issue with my old provider BT!
Has anyone else had this issue and managed to find a fix?
Answered! Go to Answer
on 06-01-2021 18:04
on 06-01-2021 17:39
Are you connecting to your Wifi network and not the public hotspot one?
on 06-01-2021 17:47
Alas definitely the private one!
on 06-01-2021 17:50
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3, Hub 4 is similar.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Check the Wi-Fi speeds on both SSIDs.
on 06-01-2021 18:04
