  • 5
Robbierobbo
I have to keep rebooting super hub
I have a super hub, and for a while now I have to reboot it several times a day as no device in the house receives a wifi signal. What could be causing this?
thanks
  • 19.29K
  • 1.68K
  • 4.23K
Re: I have to keep rebooting super hub
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots..
if using a hub3 Visit http://192.168.0.1/ and login with your password (located on the bottom of your hub).
In the menu on the left, navigate to Advanced Settings > Wireless > Wireless Signal.
At the bottom of the page you will find the “Smart WiFi” section. Here tick the box labelled “Disable Channel Optimization” and apply the changes.
Click to learn more about VIP
Use Kudos to say thanks
