jairo
Just joined
I can't connect my pc to wireless or ethernet.
Hello there, apparently I am the only one who can't have access to the wifi or ethernet. it goes with this yellow sign saying everything is set up correctly but microsoft.com can-t connect. I tried everything on the internet and still the same problem.
I can connect my iphone to wifi, and everyone in the flat can have access too.
Also I can connect my pc to my mobile phone data, or any other wifi/ethernet but this one at my place.
Any ideas? I'm thinking that somebody is blocking my access from the router? or there's some incompatibility between my pc and this router, thinking about getting another router.. what do you thinks?
  • 25.98K
  • 1.1K
  • 4.23K
Re: I can't connect my pc to wireless or ethernet.
that sounds like a problem with your pc.
  • 14.59K
  • 432
  • 46
Moderator (Retired) Ralph_R
Moderator (Retired)
Agreed, sounds like a PC problem, some specified or security options perhaps interfering, what operating system you using?
Are you able to browse to the Hubs GUI on 192.168.0.1?
Cheers
Ralph_R
Forum Moderator
  • 4.43K
  • 297
  • 742
Roger_Gooner
Community elder
If you have a Windows PC run the network troubleshooter.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
