on 21-11-2022 10:16
Would anyone recommend using the Hub5 in modem mode and using a different router? As the Hub5 is new - is it best to stick with it?
I have a TP-Link AX1800 gigabit wifi-6 router which I used with my Hub2 in modem mode when I started getting internet issues. But when I got the Hub5 I took it back out of the equation.
Would that router even work with the Virgin wi-fi pods?
Just wondering.
Cheers.
Answered! Go to Answer
on 21-11-2022 16:54
on 21-11-2022 16:54
on 29-11-2022 09:32
Thanks for your reply. Yeah, I really need to use the pods, but I didn't realise I could use the TP-Link as a bridge, so I'll look at that.
Thanks for the guidance, much appreciated.
on 01-12-2022 14:26
Hi Spangles1972,
Thanks for your post and welcome back to the community.
Apologies for the issues faced, our team should've recommended that Pods are compatible with the Hub in router mode.
Can I ask how many Pods do you have?
Regards,
on 05-12-2022 12:21
Ooh, interesting... I might have to try that. Especially if I still get issues with these Hubs.
Engineer just came this morning and replaced my new Hub5 with another new Hub5 so I'm changing all my wi-fi devices again. I'd have to do it yet again, if I add my TP-Link router back in. And I'm totally tired of messing about with it all. New router still has errors galore. I'll post again in my other post about that if it doesn't settle down.
I have 3 pods and I'm currently still waiting for them all to come back online after the engineer visit this morning.
