on 17-04-2023 23:48
Can a staff member please check if a noise problem exists in my area.
I will post information here.
1 | 331000000 | 6.5 | 42 | QAM 256 | 25 |
2 | 139000000 | 5.7 | 41 | QAM 256 | 1 |
3 | 147000000 | 5.7 | 41 | QAM 256 | 2 |
4 | 155000000 | 5.6 | 41 | QAM 256 | 3 |
5 | 163000000 | 5.6 | 41 | QAM 256 | 4 |
6 | 171000000 | 5.4 | 41 | QAM 256 | 5 |
7 | 179000000 | 5.4 | 41 | QAM 256 | 6 |
8 | 187000000 | 5.7 | 41 | QAM 256 | 7 |
9 | 195000000 | 6.3 | 41 | QAM 256 | 8 |
10 | 203000000 | 6.6 | 42 | QAM 256 | 9 |
11 | 211000000 | 6.6 | 42 | QAM 256 | 10 |
12 | 219000000 | 6 | 42 | QAM 256 | 11 |
13 | 227000000 | 5.6 | 42 | QAM 256 | 12 |
14 | 235000000 | 5.6 | 42 | QAM 256 | 13 |
15 | 243000000 | 6 | 42 | QAM 256 | 14 |
16 | 251000000 | 6.2 | 42 | QAM 256 | 15 |
17 | 259000000 | 6.4 | 42 | QAM 256 | 16 |
18 | 267000000 | 6.4 | 42 | QAM 256 | 17 |
19 | 275000000 | 6.4 | 42 | QAM 256 | 18 |
20 | 283000000 | 6.2 | 42 | QAM 256 | 19 |
21 | 291000000 | 5.9 | 42 | QAM 256 | 20 |
22 | 299000000 | 5.8 | 42 | QAM 256 | 21 |
23 | 307000000 | 6.2 | 42 | QAM 256 | 22 |
24 | 315000000 | 6.8 | 42 | QAM 256 | 23 |
25 | 323000000 | 7 | 42 | QAM 256 | 24 |
26 | 339000000 | 6.1 | 42 | QAM 256 | 26 |
27 | 347000000 | 5.5 | 42 | QAM 256 | 27 |
28 | 355000000 | 5.4 | 42 | QAM 256 | 28 |
29 | 363000000 | 5.7 | 42 | QAM 256 | 29 |
30 | 371000000 | 6 | 42 | QAM 256 | 30 |
31 | 379000000 | 6.3 | 42 | QAM 256 | 31 |
1 | Locked | 42 | 0 | 0 |
2 | Locked | 41 | 0 | 0 |
3 | Locked | 41 | 0 | 0 |
4 | Locked | 41 | 0 | 0 |
5 | Locked | 41 | 0 | 0 |
6 | Locked | 41 | 0 | 0 |
7 | Locked | 41 | 0 | 0 |
8 | Locked | 41 | 0 | 0 |
9 | Locked | 41 | 0 | 0 |
10 | Locked | 42 | 0 | 0 |
11 | Locked | 42 | 0 | 0 |
12 | Locked | 42 | 0 | 0 |
13 | Locked | 42 | 0 | 0 |
14 | Locked | 42 | 0 | 0 |
15 | Locked | 42 | 0 | 0 |
16 | Locked | 42 | 0 | 0 |
17 | Locked | 42 | 0 | 0 |
18 | Locked | 42 | 0 | 0 |
19 | Locked | 42 | 0 | 0 |
20 | Locked | 42 | 0 | 0 |
21 | Locked | 42 | 0 | 0 |
22 | Locked | 42 | 0 | 0 |
23 | Locked | 42 | 0 | 0 |
24 | Locked | 42 | 0 | 0 |
25 | Locked | 42 | 0 | 0 |
26 | Locked | 42 | 0 | 0 |
27 | Locked | 42 | 0 | 0 |
28 | Locked | 42 | 0 | 0 |
29 | Locked | 42 | 0 | 0 |
30 | Locked | 42 | 0 | 0 |
31 | Locked | 42 | 0 | 0 |
on 17-04-2023 23:49
0 | 49600000 | 42.8 | 5120 | QAM 32 | 1 |
1 | 43100000 | 42.8 | 5120 | QAM 32 | 2 |
2 | 36600000 | 42 | 5120 | QAM 32 | 3 |
3 | 30100000 | 41.5 | 5120 | QAM 32 | 4 |
4 | 23600000 | 41.3 | 5120 | QAM 32 | 9 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 17-04-2023 23:49
17-04-2023 23:01:35 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
17-04-2023 23:01:31 | notice | US profile assignment change. US Chan ID: 10; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 23:01:26 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 23:01:22 | notice | TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 23:01:20 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 23:01:18 | notice | Honoring MDD; IP provisioning mode = IPv4 |
17-04-2023 23:00:59 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 23:00:41 | critical | Cable Modem Reboot via RG reboot command |
on 17-04-2023 23:50
Prior to this upstream's were always QAM64, then 11pm had the "Cable Modem Reboot via RG reboot command"
Now they are rotating between QAM16 and QAM32. (QAM32 at time of this post).
on 20-04-2023 14:10
Hi chrcoluk,
Thanks for posting, I've had a look at things from our side and everything looks to be within the specifications we would expect.
Are you experiencing any connect issues currently?
Let us know if you are.
Alex_Rm
20-04-2023 17:18 - edited 20-04-2023 17:21
@Alex_RM wrote:Hi chrcoluk,
Alex_Rm
Hi, luckily the connection still performs fine. I didnt know QAM32 is within spec.
Because its still performing ok I wont push it now.
22-04-2023 21:11 - edited 22-04-2023 21:18
Alex_Rm
Had an outage earlier whilst watching a stream, had to go out, but checked logs when I came back, and seen the following lines, they do coincide with the outage, which is also visible on my tbb ping graph, which I will add as well. These indicate an issue with the 3.1 channel though. The 3.0 channels are now back on QAM64..
22-04-2023 14:37:35 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 14:37:35 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 14:33:34 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 21:12 - edited 22-04-2023 21:17
0 | 49600000 | 43 | 5120 | QAM 64 | 1 |
1 | 43100000 | 42.8 | 5120 | QAM 64 | 2 |
2 | 36600000 | 42.3 | 5120 | QAM 64 | 3 |
3 | 30100000 | 41.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 41.5 | 5120 | QAM 64 | 9 |
graph
on 25-04-2023 09:08
Hi @chrcoluk
Thanks for your response
The BQM doesn't actually show any alarming signs asides from the one short dropout - noise doesn't seem to be a problem as per the BQM graph. How has your connection been since Saturday?
